RubenAsekas
    Madrid
    Audi A3 1.9 TDI 110 CV
Logros de RubenAsekas
Novato
Novato (1/14)
  1. hola,soy nuevo en este foro,y tengo un audi a 3 tdi 110cv del año 99.el otro dia meti el vag com para averiguar que problemas podia tener,pero claro no entiendo nada jeje el caso es que mi coche suelta humo negro cuando entra el turbo y luego deja de funcionar el turbo.sabriais decirme de que puede ser?os dejo tambien aqui el informe del vag com. AIRBAG VAG-COM Version: Release 311.2-N Control Module Part Number: 8L0 959 655 F Component and/or Version: Airbag 7 Audi 0505 Software Coding: 00104 Work Shop Code: WSC 06313 2 Faults Found: 00589 - Airbag Igniter 1: Passenger Side (N131) 32-00 - Resistance too High 00655 - Seat Belt Tensioner Igniter: Passenger Side (N154) 32-00 - Resistance too High ABS VAG-COM Version: Release 311.2-N Control Module Part Number: 1J0 907 379 H Component and/or Version: ABS/EDS 20 IE CAN 0001 Software Coding: 13304 Work Shop Code: WSC 06435 1 Fault Found: 00283 - Front Left ABS Wheel Speed Sensor (G47) 35-00 - - ENGINE VAG-COM Version: Release 311.2-N Control Module Part Number: 038 906 018 BP Component and/or Version: 1,9l R4 EDC 0000SG 2110 Software Coding: 00002 Work Shop Code: WSC 06313 1 Fault Found: 17958 - Charge Pressure: Control Deviation P1550 - 35-00 - - AUTOSCAN VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 018 BP Component: 1,9l R4 EDC 0000SG 2110 Coding: 00002 Shop #: WSC 06313 No fault code found. Address 03 ------------------------------------------------------- Controller: 1J0 907 379 H Component: ABS/EDS 20 IE CAN 0001 Coding: 13304 Shop #: WSC 06435 1 Fault Found: 00283 - Front Left ABS Wheel Speed Sensor (G47) 35-00 - - Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 15 ------------------------------------------------------- Controller: 8L0 959 655 F Component: Airbag 7 Audi 0505 Coding: 00104 Shop #: WSC 06313 2 Faults Found: 00589 - Airbag Igniter 1: Passenger Side (N131) 32-00 - Resistance too High 00655 - Seat Belt Tensioner Igniter: Passenger Side (N154) 32-00 - Resistance too High Address 17 ------------------------------------------------------- Controller: 8L0 919 860 D Component: AB-KOMBIINSTR. VDO D10 Coding: 06140 Shop #: WSC 00000 IMMO-IDENTNR: AUZ7Z0W0767238 No fault code found. Address 35 ------------------------------------------------------- Controller: 8L0 862 257 L Component: ZV-Pumpe D10 Coding: 00032 Shop #: WSC 06313 2 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 00991 - Interior Lights 28-00 - Short to B+ End ------------------------------------------------------- muchisimas gracias de antemano.un saludo
