amigos tengo los siguientes dramas que marca el auto todos ya los borre una vez y vuelven ah aparecer :/
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AC
Component: 1.8L R4/5VT G 0002
Coding: 0004581
Shop #: WSC 66565
12 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 002 - Lower Limit Exceeded - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 01J 927 156 ET
Component: V30 01J 1.8l5VT RdW 3011
Coding: 00001
Shop #: WSC 04926
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04499
Shop #: WSC 06435
3 Faults Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
P1857 - 35-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
01809 - Actuating Motor for Temperature Flap: Left (V158)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 07790
Shop #: WSC 06324
18 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01331 - Door Control Module: Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01811 - Supply Voltage for Door Controller: Drivers Side (J386)
37-10 - Faulty - Intermittent
01802 - Door Warning Lamp: Pass Side (W36)
57-10 - Electric Circuit Failure - Intermittent
01332 - Door Control Module: Passenger Side (J387)
01812 - Supply Voltage for Door Controller: Pass. Side (J387)
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
01333 - Door Control Module: Rear Left (J388)
01813 - Supply Voltage for Door Controller: Rear Left (J388)
01804 - Door Warning Lamp: Rear Right (W38)
01334 - Door Control Module: Rear Right (J398)
01814 - Supply Voltage for Door Controller: Rear Right (J389)
00935 - Electric Window Motor: Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
alguna orientacion porfavor estaria muy agradecido.
