powersampo
Todo lo publicado por powersampo
ya encontrado el cable verde azul y lo e conectado al pin 5 del conector B en el 15 hay uno de color rojo pero cuando le doy al 37 del vag-com no me encuentra nada ni 56 el el 17 de intrumentos 10 adaptacio 62 mesale el valor 5 VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 CG Component: 1,9l R4 EDC G000SG 1366 Coding: 00002 Shop #: WSC 63351 WAUZZZ8EZ1A184705 AUZ6Z0A0071861 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04255 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 00000 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent Address 09 ------------------------------------------------------- Controller: 8E0 907 279 B Component: int. Lastmodul RDW 1412 Coding: 00011 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 J Component: Lenksáulenmodul 0204 Coding: 00041 Shop #: WSC 63351 1 Fault Found: 01330 - Central Control Module for Central Convenience (J393) 49-10 - No Communications - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 900 E Component: KOMBI+WEGFAHRS. RB4 D14 Coding: 00100 Shop #: WSC 00028 WAUZZZ8EZ1A074705 AUZ6Z0A0078861 No fault code found. Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0503 Coding: 00001 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AJ Component: Komfortgerát T9F 0619 Coding: 06762 Shop #: WSC 00321 6 Faults Found: 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01561 - Left Rear Door 61-00 - Won't De-Safe 01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent 01562 - Right Rear Door 61-00 - Won't De-Safe 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01332 - Door Control Module: Passenger Side (J387) 49-10 - No Communications - Intermittent Address 55 ------------------------------------------------------- Controller: 4B0 907 357 C Component: dynamische LWR D06 Coding: 00060 Shop #: WSC 63351 No fault code found. End ------------------------------------ como lo tengo que hacer para que me reconozca el 37 rns-e-
Muchas gracias adresttitto voy a probar en el conector 15 tengo uno rojo
Me falta el cable k line No esta ni en c7 ni en el c5 Tengo un a4 b6 8e con un rns-e Y tengo varios cables que no están conectados a ningún sitio uno de ellos es marron y ralla gris tengo canbus Pero con el vagcom no me reconoce el modulo 37 ni el 56 Que solucion hay? Alguien me puede pasar el esquema eléctrico de un a4 b6 del 2002 pues como he dicho antes tengo cables que están encintados y no se lo que son
NECESITO ESQUEMA ELECTRICO AUDI A4 B7
powersampo responde a RJ32 de discusión en Electricidad Audi A4 B6/B7
Alguien puede volverlo a subir pues megaupload esta cerrada yo necesito saber cual es el cable k-line pues es para entar en el vag-com en el modulo 37 tengo un rns-e y quiero activar la camara de macha atras el problema es que en el conector b5 o en el c7 no esta y tengo unos encintados pero no se cual es el k-line ni se el color que es tengo un a4 b6 8e gracias -
No tengo conectado nada ni en PIn verde 7 ni en azul 5 Como se cual es el cable? Tengo varios sin conectar están sueltos y encintados Alguien sabe de que color es el cable de Kline que viene del coche a4 b6 8e
Nadie sabe nada
Al mi también le falta el cable k line No esta ni en c7 ni en el c5 Tengo un a4 b6 Y tengo varios cables que no están conectados a ningún sitio uno de ellos es marron y ralla gris tengo canbus Pero con el vagcom no me reconoce el modulo 37 ni el 56 Que solucion hay?
Archivos a modificar para activar el sds
powersampo responde a carlosrate de discusión en Car Audio / Navegadores
el mio es un rns-e -
Nadie lo tiene o me puede decir donde descargarmelo
Activación VIM y SDS para RNS-E
powersampo responde a yakutake de discusión en Car Audio / Navegadores
hola alguien me puede pasar los archivos para hacer VIM Y SDS pues no los encuentro -
Perdona pero sigo sin encontralo y no sera que no e leido -
Una pregunat una vez instalada la camara teneis que modificar algo con el vag-com para que cuando pongas la marcha atras salga directa en el rns-e? yo tengo instalado un interface de video pero cuando circulo a las de 5 kilometros se corta la imagen. tendria que modificar algo para que cuando ponga la marcha atras se vea directa la camara?
yo necesito hacer video en movimiento por que mi interface no es activo
yo me apunto si alguien lo tiene pues no encuentro los enlaces
Alguien me los puede pasar a mi tambien pues ya no los encuentro y quisiera hacer vim y sds -
hola alguien me puede pasar los archivos para hacer VIM Y SDS -
He actualizado mi RNS-E a 0660 para poner VIM
powersampo responde a Freestylero de discusión en Car Audio / Navegadores
Hola alguien me puede pasar el sotfware del VIM y como tengo que hacerlo si no donde esta el enlace. tengo un rns-e y pone: sotfware :0650 Hardware: H56 Targeta: 8P0919884_AT_EUW Un saludo -
Hola quisiera saber donde conseguir el sotfware y instruciones para poner el video en movimiento en mi rns-e Tengo un A4 B6 sotfware :0650 Hardware: H56 Targeta:8P0919884_AT_EUW Muchas gracias
Desbloquer imagenes en movimiento
powersampo responde a alex3.2 de discusión en Car Audio / Navegadores
yo tambien estoy interesado en ese cd. pues tengo un interface puesto y me estaba funcionando pero de repente me ha dejado de funcionar en movimiento solo si estoy parado . un saludo -
Guía de instalación del Bluetooth Audi
powersampo responde a dehyb de discusión en Car Audio / Navegadores
hola me podeis decir donde puedo encontar el cable pues en la paguina que hay puesta ya no hay vendedor y me interesa el que no tengo que poner terminales. que numeracion es si la tienen en la casa oficial? muchas gracias
