matiascr
    Piera
    A3 1.6
Logros de matiascr
Rookie
Rookie (2/14)
  1. Bueno chicos, le he pasado el cable al coche y me pone eso en el log de errores, pero no se que es, se que es algo de los sensores de admision, que fallan pero poco más. VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 11.11.3 Data version: 20120401 www.Ross-Tech.com Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Wednesday,18,June,2014,12:40:24:32264 VIN: License Plate: Mileage: 139550km-86712mi Repair Order: Chassis Type: 8L - Audi A3/S3 Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 Mileage: 139550km/86712miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06A-906-019-AEH.lbl Part No: 06A 906 019 BG Component: 1.6l R4/2V SIMOS HS2440 Coding: 04000 Shop #: WSC 06313 VCID: 69D3A37D1362C31 3 Faults Found: 00557 - Pressure Switch; Power Steering (F88) 29-10 - Short to Ground - Intermittent 00515 - Camshaft Position (Hall) Sensor (G40) 27-10 - Implausible Signal - Intermittent 00520 - Air Mass / Air Flow Sensor (G70)/(G19) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 G Component: ABS 20 IE CAN 0001 Coding: 03504 Shop #: WSC 06435 VCID: 356B3F0D0F5A571 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 D Component: A3 KLIMAVOLLAUTOMAT_D75 Coding: 03140 Shop #: WSC 06313 VCID: 2953E37DD3E2031 2 Faults Found: 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to Plus 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent -------------------------------------------------------------------------------
  2. supongo que el mando a distancia oem pasa por cambiar la llave no? a eso te refieres cambiar el contacto no?,
  3. Mil gracias, mi a3 no lo traia
  4. En cuanto a tus dudas: Si puedes poner mando a distancia, necesitas una llave con mando y cambiar la bomba del cierre centralizado, tambien añadir un cable que hace de antena. Conservaras todas las funciones que tienes cierre de ventanillas, cierre centralizado.....etc. Busca un poco de info que hay mucho escrito sobre el tema del FIS, pero de ser tu coche del 98 tendras el cuadro con las lamparas. El cierre centralizado es en parte neumatico y en parte electrico. Hay una bomba que se activa y dependiendo de lo que hace cerrar o abrir, aspira o empija el aire, pero todos los señales que llegan a esa bomba son electricos. En lo que se refiere a la alarma no puedo ayudarte. Veo que eres de la zona si tienes dudas sobre como montar el cuadro o el mando a distancia, no hay problema de echarte una mano. Muchas gracias zanusix, se agradece, porque estoy un poco verde, lo que no he entendido es lo de cambiar la bomba del cierre centralizado. la que viene no sirve? ejemplo, si instalo una alarma, y la conecto a la bomba original no funcionará, lo digo para tener mando.
  5. bueno ahi va mi pregunta, se que la numeracion del velocimetro es 8lo--- que es el modelo, 919-----, que es la numeracion que dice que no tiene cambus, 960---- que es que no tiene fix, y la E------, que significa que es gasolina, hasta aqui lo que he averiguado. yo necesito un 8LO-919-980 E, pero si en vez de E es otra letra qu no sean las de los diesel me serviria?
  6. cierto, yo de echo, no tenia ni idea, ni de reestyling, etc, ahora que me he metido aqui, voy comprendiendo y haciendo cosillas, la lista es larga. Faros reestyling, fis completo, alarma, tengo mucho trabajo por delante.
  7. gracias por la ayuda!!!
  8. Recientemente me he comprado un a3 1.6 de segunda mano, es del 98 y tengo un monton de preguntas. 1- El mio es del 98, solo tengo una llave, sin mando, mi pregunta es si tiene mando a distancia este coche porque lo desconozco, tiene cierre, eso si, y si mantengo la llave cierra las ventanillas. 2- no se si tengo medio fix o no, tengo el mas basico creo, y mi preginta es si le puedo poner fis completo, la numeracion de mi cuadro de revoluciones y velocidad es: 8LO919860 E, mi pregunta es si puedo poner fis completo. 2- No se si el cierre es neumatico o electrico, (el centralizado), por el tema de ponerle una alarma. Muchas gracias a todos y espero que con vuestra experiencia me saqueis de mis dudas.
  9. Hola a todos, recientemente me he comprado un a3 1.6 de segunda mano del 98. Saludos.
