Veng
    Denmark
    AUDI A4 B8 S-Line 170TDI AVANT
482 visitas al perfil
Logros de Veng
Novato
Novato (1/14)
  1. PR Code Group Description 0G1 GES Gearshift lever 0JD GKV Weight category front axle weight range 4 0YF GKH Weight range 6 installation control only, no requirement forecast 1AS BRS Electronic stabilization program (ESP) 1AT BRS Electronic stabilization program (ESP) 1BV DAE Sports suspension/shock absorption 1KW BAH Disc brakes, rear 1LT BAV Disc brakes, front 1N3 LEN Speed-related variable steering assist (Servotronic) 2K7 SFS Reinforced bumpers 2PU LRA Leather trimmed multi-function sports steering wheel 3FA DEI Without roof insert (standard roof) 3LS TSV Door and side trim panel in Alcantara 3NZ HIS Rear seat bench unsplit, backrest split folding 3YD TAV Door pocket, front right 4GF WSS Windshield in heat-insulating glass 4K4 TKV Radio remote controlled central locking 4KC SSH Side and rear windows in heat-insulatingglass 4UE AIB Air bag for driver and front seat passenger 4X3 SAB Side air bag front with curtain air bag 5D7 TRF Carrier frequency 868 MHz without panic button 5SL ASL Left exterior mirror: aspherical 5TG EIH Decorative aluminum inserts, dulling 6TS ASR Right exterior mirror: aspherical, large viewing field 6XD ASE Exterior mirrors: electrically adjustable/heated 7A3 CDW CD player 7K6 RDK Flat tire indicator 7MB AGM Emission standard EU 4 plus 7Q0 NAV Without navigation device 7X4 EPH Park distance control, front and rear 8BP HSW Bi-functional headlight with gas discharge lamp 8GU GEN Alternator 140 A 8Q3 LWR Automatic headlight-range adjustment dynamic (self-adjusting while driving) 8Z5 MKU Not hot country 9Q4 MFA Multi-function display/on-board computerwith check control C8S RAD Alloy wheels 8J x 18 D93 MOT 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3 E4J AAU "S-line" F0A FZS No special purpose vehicle, standard equipment J1U BAT Battery 450 A (95 Ah) Q1D VOS Sports front seats TH3 GMO 4-cylinder diesel engine 2.0 L unit 03L.B U2A INS Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
  2. Hi Marrones. On that stamp is both 1AS AND 1AT and that make sound strange. The cars is with TMPS from start.. but one of the first B8 from 2008. EPS :: 8K0 614 51 7BT VZ BOJ 0 265 235 092 081016/5/0678 I will take a good look on your link. Thank You. I can feel, translate on this fine site will be my best frind.. Gracias... dos cervezas para usted my friend :-)
  3. Hi AUDISPORT-iberica Hope to have Your opion on: HILLBRAKE on my car ?? AUDI A4 B8 2008/2009 6GEAR 170TDI AVANT INFO: Have this info: 1AT BRS Electronic stabilization program (ESP) 1AS BRS Electronic stabilization program (ESP) 7K6 RDK Flat tire indicator With this part number: 8K0 614 51 7BT VZ BOJ 0 265 235 092 081016/5/0678 ?? Hope it is possible.. Very best regards Keld Veng
  4. Hi AUDISPORT-iberica Hope to have Your opion on: HILLBRAKE on my cars ?? INFO: Have this info: 1AT BRS Electronic stabilization program (ESP) 1AS BRS Electronic stabilization program (ESP) 7K6 RDK Flat tire indicator With this part number: 8K0 614 51 7BT VZ BOJ 0 265 235 092 081016/5/0678 ?? Hope it is possible.. Very best regards Keld Veng
