Asturiano25
    Gijon
    Audi a4 1.8t 150cv
Logros de Asturiano25
Rookie
Rookie (2/14)
  1. Gracias por las aclaraciones, cuando tenga un rato le cambiare el aforador y la valvula n75, por cierto dicha valvula que es lo que hace?
  2. Buenas, me an dejado un vagcom 12.12 y ya que no me funcionaban un par de cosas me puse a mirar con el, estos son los errores que detecte: Friday,01,May,2015,12:22:53:30570 VCDS Version: Release 12.12.3 (x64) Address 17: Instruments Labels: 8D0-919-0xx-17.lbl Control Module Part Number: 8D0 919 033 P Component and/or Version: B5-KOMBIINSTRUMENT__D11 Software Coding: 00142 Work Shop Code: WSC 54321 VCID: 356751960F361CB678B-5072 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-10 - Open or Short to Plus - Intermittent ---------------------------------------------------------------------------------------- Friday,01,May,2015,12:41:55:30570 VCDS Version: Release 12.12.3 (x64) Address 15: Airbags Labels: 8A0-959-655.lbl Control Module Part Number: 8A0 959 655 B Component and/or Version: Airbag V AUDI D00 Software Coding: 00766 Work Shop Code: WSC 06313 VCID: 326D6A8AFE580B8E5D9-5072 1 Fault Found: 00588 - Airbag Igniter; Driver Side (N95) 32-00 - Resistance Too High ---------------------------------------------------------------------------------------------- Friday,01,May,2015,12:45:55:30570 VCDS Version: Release 12.12.3 (x64) Address 08: Auto HVAC Labels: Redir Fail! Control Module Part Number: 8D0 820 043 D Component and/or Version: A4-KLIMAVOLLAUTOMAT_D63 Software Coding: 00043 Work Shop Code: WSC 06313 VCID: 214F95C6ABBE8016B43-2566 Fault Codes have been Erased 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-00 - Blocked or No Voltage -------------------------------------------------------------------------------------------------- Friday,01,May,2015,12:55:48:30570 VCDS Version: Release 12.12.3 (x64) Address 01: Engine Labels: 058-907-55X-AEB1.LBL Control Module Part Number: 8D0 907 557 Component and/or Version: 1,8l R4/5VT MOTR HS D05 Software Coding: 04001 Work Shop Code: WSC 00000 VCID: EDD739F6A7E61476C0B-4A3A 1 Fault Found: 01262 - Solenoid Valve for Boost Pressure Control (N75) 26-00 - Output Open Readiness: N/A ------------------------------------------------------------------------------------------------------- si alguien sabe como se puede solucinar alguno de ellos se lo agradeceria. Un Saludo.
  3. Perfecto encuanto tenga un poco de tiempo libre desmontare el cuadro y are esas comprobaciones, respecto al vag-com voy a buscar informacion de cucal comprar y como hacerle un chequeo a las agujas, muchas gracias. Un saludo.
  4. La unica foto que tengo del cuadro es de noche y no se aprecian los marcadores que no funcionan. No obstante mañana le hago otra foto si esta no sirve, siento marearos de esta manera. Un Saludo.
  5. pues el numero es WAUZZZ8DZTA Un Saludo.
  6. la fecha de la matriculacion es 02/07/96 Tipo (G) AEB Un Saludo.
  7. Buenas compañeros, como bien dije no hace ni una semana que me compre un A4 B5 1.8T, la cuestión es que el cuadro no me marca varias cosas. Temperatura Motor - No marca Temperatura Aceite - No Marca Nivel Gasolina- No Marca En definitiva solo me marca las revoluciones y la velocidad, la consola me controla la media y eso pero no me sale la autonomia del deposito. Por otra parte en el marcados los chivatos que comento no se encienden cuando circulo de noche no se ven, el cuenta revoluciones y el velocimetro se ven a la perfección. ¿Esto a que puede ser debido?, pregunto por que no quiero ir a comprar el primer cuadro que encuentre por cualquier sitio para que luego el fallo sea de otra parte. Un saludo y gracias a todos por vuestro tiempo.
  8. Estas son algunas fotos del interior, como podeis ver no son asientos de cuero sin fundas y el volante tal y como dije antes es desplazado cosa que quiero cambiar lo antes posible por uno con airbag. Un Saludo.
  9. Haber espero subir bien las fotos, la calidad no es demasiado buena, ya cuando le haga una limpieza general le sacare fotos con la camara en vez de con el movil. Al coche tengo que comprobarle el Aforador y el Cuadro ya que no me marca la gasolina, el mismo dia que lo compre lo lleve a cambiar el aceite ya que no me fiaba, y le instale un radio cd ya que el coche venia sin radio cd alguno, tambien tengo que buscarle un volante de serie con airbag ya que viene con uno desplazado y ya repararle algunos detalles poca cosa para mi gusto, asi que os ire comentando las mejoras y publicando fotos siempre que modifique algo. Un Saludo y muchas gracias a todos por la bienvenida.
  10. Buenas a todos, hace unos pocos dias eh adquirido un audi a4 b5 1.8t de 150Cv del año 1996 con 135.000 km, y buscando por internet encontre este foro y me gustaria formar parte de vuestra familia y ir aprendiendo cosas sobre esta marca y intentar aportar todo lo que pueda. ya adjuntare alguna foto del pequeño cuando se las haga. Un Saludo.
