ferjo
    Alemania
    Audi a3 8p
545 visitas al perfil
Logros de ferjo
Aprendiz
Aprendiz (3/14)
  1. lo acabo de solucionar con el código 0205757 muchas gracias por responder. por aquí pongo el código que encontré por alguna wed alemana. Coding 0?xxxxx: Model 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) 0x?xxxx: Treble Speaker Monitoring inactive 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet) 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet) 0xx?xxx: Sound Characteristic 0 = Sound Characteristic linear 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sound System 0xxx?xx: Telephone/Telematic 1 = Telephone not installed (Remote Feed Voltage for Microphone active) 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive) 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive) 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive) 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive) 6 = Telematic US (Remote Feed Voltage for Microphone inactive) 7 = Base Plate diagnostic capable with Comfort Control 0xxxx?x: Equipment I 1 = Tuner not installed 2 = Digital-Radio installed 3 = Satellite-Radio installed 4 = Satellite and Digital-Radio installed 5 = Analog Input (AUX) installed 7 = Satellite-Radio & Analog Input (AUX) installed 0xxxxx?: Equipment II 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed 2 = TV-Tuner installed 3 = CD-Changer installed 4 = TV-Tuner and CD-Changer installed 5 = Multi-Function Steering Wheel installed 6 = TV-Tuner and Multi-Function Steering Wheel installed 7 = CD-Changer and Multi-Function Steering Wheel installed 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
  2. El problema estaba codificado para un Audi A4 por eso no se apagaba al quitar el contacto de la llave. El auxiliar ya esta activado funcionando perfectamente pero el problema de ahora es el modulo de radio y navegador dice que esta mal codificado "Unidad de control mal codificada " mi codigo es el siguiente 0205755 pero quizas mañana pruebe de nuevo con el 0205255.
  3. Dirección 37: Navegación Etiquetas: EST\8E0-035-192-RNSE.clb N°. de Parte SW: 8P0 035 192 HW: 8P0 035 192 Componente: RNS-E HIGH EU H44 0720 Versión: 03S N° de Serie: AUZBZ7D0003165 Codificación: 0205755 Nº Taller: WSC 26701 136 03157 VCID: 6CD771B74F8BFEE989-8038 1 Avería detectada: 01044 - Unidad de control mal codificada 000 - - Cuadro Congelado: Estado de Avería: 01100000 Prioridad de Avería: 7 Frecuencia de Avería: 1 Reseteos del Contador: 177 Kilometraje: 200310 km Indicación de Tiempo: 0 Fecha: 2022.03.26 Tiempo: 18:15:53 Dirección 56: Radio Etiquetas: EST\8E0-035-192-RNSE.clb N°. de Parte SW: 8P0 035 192 HW: 8P0 035 192 Componente: RNS-E HIGH EU H44 0720 Versión: 03S N° de Serie: AUZBZ7D0003165 Codificación: 0205755 Nº Taller: WSC 26701 136 03157 VCID: 6CD771B74F8BFEE989-8038 1 Avería detectada: 01044 - Unidad de control mal codificada 000 - - Cuadro Congelado: Estado de Avería: 01100000 Prioridad de Avería: 7 Frecuencia de Avería: 1 Reseteos del Contador: 177 Kilometraje: 200310 km Indicación de Tiempo: 0 Fecha: 2022.03.26 Tiempo: 18:15:53 Coding 0?xxxxx: Model 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) 0x?xxxx: Treble Speaker Diagnosis / Optical Parking Aid +1 = Front Treble Speaker Diagnosis inactive +2 = Optical Parking Aid installed/active 0xx?xxx: Sound Characteristic 0 = Sound Characteristic linear 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sound System 0xxx?xx: Telephone Preparation 1 = Telephone Preparation NOT installed 2 = Telephone Preparation without Comfort Functionality 3 = Telephone Preparation (Aftermarket Retrofit) 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive) 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive) 6 = Telephone Preparation for North American Region (NAR) 7 = Telephone Preparation with Comfort Functionality 0xxxx?x: Equipment I +1 = Standard/Basic Value - Add to the Sum of Options below +1 = Audi Music Interface (AMI/PR-UF7) installed +2 = Satellite Radio (SIRIUS/XM) installed +4 = Analog Input (AUX/PR-UF0/UF1/UF2) installed 0xxxxx?: Equipment II +1 = Standard/Basic Value - Add to the Sum of Options below +1 = TV-Tuner (PR-QV1/QV9) installed +2 = CD-Changer or iPod/USB-Interface (PR-7A2/7A5/UF1/UF2) installed +4 = Multi-Function-Steering Wheel (MFSW) installed Buenas tardes. el codigo que tengo puesto es el siguiente : 0205755 Mas que le doy vueltas y vueltas siempre aparecen esos dos errores . mi audi a3 8p es del 2012 para mas información cambie el navegador básico al RNS e mi coche trae manos libres de serie y el comando de voz. yo creo que esta perfectamente los codigos ya que funciona todo perfectamente y ahora con la toma aux operativa.
  4. Muchísimas gracias. Cuando tenga un rato me pondré en ello. Tengo mi último problema al quitar el contacto del coche se queda encendido y lo tengo que apagar manualmente y al encender el coche lo tengo que encender manualmente. Alguna solución? Encontré un Post que decía quitar y poner la batería. Pero sigue igual.
  5. Para los que tenga el mismo problema acabo de descubrir que tenemos que cambiar tres cables y buscar el adaptador de 32 pines Pin 01 del conector azul a pin 22 del conector 32 Pin 03 del conector azul a pin 21 del conector 32 Pin 07 del conector azul a pin 06 del conector 32 Solo me queda activar el aux con la vagcom Seguiré actualizando
  6. Tienes razón. Ahora acabo de pedir el conector de 32 pines para ponerlo en la posición correcta por aquí ya casi esta solucionado. Tengo los últimos mapas para actualizar el navegador. Por último me queda meterme en el vag com para activar el aux. Mi nueva pregunta es la siguiente. Es muy complicado activar el aux ? Ya investigaré un poco quizás tenga un poco de suerte. Gracias por las respuestas
  7. Me pasa lo mismo. Intentaré desconectar la batería una noche. Haber si tenemos suerte
  8. Tengo algun que otra pregunta, cambie de audi navegation a audi navegation plus, como ya vi en este foro solo era cambiar los cables. el problema que tengo es el siguiente. la entrada auxiliar donde tenia conectado el jack para el movil no esta en el navegador, mirando por eBay venden una auxiliar para la clavija que esta vacía, pero mi audi navegation normal tenia entrada jack y funcionaba bien . teneis alguna idea ? de momento me estoy bajando los mapas actualizados para actualizar el navegador. que cable y que programa nececito para el vag com ?
  9. RNS E ya esta montada. el problema que tengo es la entrada aux que no la detecta el navegador. el usb funciona sin problemas y la radio tambien sin problemas. estoy pensando en comprar algun cable vag quizas sea problema de los codigos.
  10. Yo tengo el mismo problema. Y la misma duda. Alfinal que hiciste. ?
  11. Si exactamente.
  12. hola tengo un audi A3 sportback 2012 con el navegador A3-8P/A4B7/TT-Mk2: BNS 5.0 mi pregunta es la siguiente. no encuentro información sobre las actualizaciones MMI. -Puedo yo actualizar el sistema? -hay mapas actualizados?(los que tengo son del 2012) otra pregunta. -Tiene entrada USB pero no logro reproducir las carpetas y no mas de 99 canciones (es como si fuera un cargador de discos) gracias por todo
  13. ferjo
    Quiero vuestra opinión
    hola buenas tardes tengo pensado en comprar el siguiente Audi A3 Primera matriculación noviembre 2012 Kilómetros 93.524 km 1.968 cm³(140 CV) Tiene el famoso 2.0TDI Diesel Ultimo mantenimiento en casa oficial 89.000km Ruedas de invierno incluida Precioa 13.990 (algo seguramente bajare)
  14. hola buenas tardes vivo en Alemania y dentro de poco quiero comprar un AUDI espero vuestra opinión en mi futura compra y intentare ser lo mas activo en este foro gracias por todo y buenas tardes shur
