concorde306
Todo lo publicado por concorde306
  1. Hola foreros.....Ayer me llego el cable con el VAG-COM de pandatti y hoy he hecho un test al coche y me salen los siguientes errores: VAG-COM Version: Release 311.2-N Chassis Type: 8N - Audi TT Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 8N0 906 018 AQ Component: 1.8L R4/5VT 0002 Coding: 11500 Shop #: WSC 01236 TRUZZZ8NX21036055 AUZ5Z0B5066014 1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8N0 907 379 G Component: ESP FRONT MK60 0101 Coding: 0019469 Shop #: WSC 01236 No fault code found. Address 08 ------------------------------------------------------- Controller: 8N0 820 043 A Component: TT-KLIMAVOLLAUTOMAT D03 Coding: 00040 Shop #: WSC 01236 1 Fault Found: 00603 - Footwell/defroster Flap Positioning Motor (V85) 41-10 - Blocked or No Voltage - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8N1 920 930 Q Component: KOMBI+WEGFAHRS. M73 D14 Coding: 00044 Shop #: WSC 26832 TRUZZZ8NX21036055 AUZ5Z0B5066014 2 Faults Found: 01304 - Radio 49-10 - No Communications - Intermittent 01305 - Databus for Infotainment 37-10 - Faulty - Intermittent Address 35 ------------------------------------------------------- Controller: 8N8 962 267 Component: Zentralverrieg. D06 Coding: 06755 Shop #: WSC 01236 1 Fault Found: 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent Address 55 ------------------------------------------------------- Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D004 Coding: 00009 Shop #: WSC 01236 No fault code found. Address 56 ------------------------------------------------------- Controller: 4B0 035 186 G Component: concert II GRO 0008 Coding: 00000 Shop #: WSC 01236 4 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 00852 - Loudspeaker(s): Front 36-10 - Open Circuit - Intermittent 00856 - Radio Antenna 36-10 - Open Circuit - Intermittent 01305 - Databus for Infotainment 49-10 - No Communications - Intermittent End ------------------------------------------------------- Tengo entendido que el primero es normal y que no tiene nada que ver con un problema...pero los demas............no se como solucionarlos, alguien me podria decir como se solucionan?esque son bastantes, y ademas, la radio funciona bien, pero me aparece error en los altavoces delanteros, y no se como solucionarlo.Gracias
  2. OK, intentare bajarmela a ver si funciona. Muchas gracias
  3. concorde306
    Resolucion pantalla ETKA?
    Hola a todos, mi problema es que al instalar el ETKA me dice que necesito una resolucion de 1280x1024 y mi ordenador la maxima es de 1280x800, que se puede hacer??Mi ordenador es una caca? La verdad es que no se que hacer, si a alguien se le ocurre algo le agradeceria que me lo diga. Un saludo
  4. Hola franky65, me refiero a que si basta con conectar el manos libres tal cual con los isos que trae , y si asi me funcionaria, porque en el buscador he encontrado un post que dice que hay que cortar los cables naranjas y hacer conexiones, pero como mi equipo no es bose no se si es necesario....no se si me explico...............Tengo miedo de cargarme el manos libres....................ai madre............que coche mas complicado!Hoy ya he colocado el micro y el aparatito con los botones......y solo me falta conectarlo....
  5. Hola a tod@s. Anes de nada, decir que no estoy seguro si esto se debe postear aqui, y si no es asi disculpas de antemano. Mi duda es que tengo un manos libres parrot, que lo tenia instalado en un 306 y ahora tengo un TT del 2002 y quiero montarlo, pero me han dicho (en un taller) que si lo monto tal cual, es decir, conectando los isos como hice en el 306, no se que pasa que se puede quemar el manos libres porque hay un cable de la radio que saca corriente y que hay que cortar..... Mi radio es la concertII y el equipo no es bose, por lo que mi duda, es si esto es cierto o me lo ha dicho el taller para que me lo monten ellos, ya me entendeis. He buscado en el buscador y no he encontrado nada acerca de esto del cable, y no se porque tampoco puedo ver las fotos de los montajes. Si alguien puede ayudarme se lo agradeceria.... Y ya puestos a pedir, me gustaria saber para que sirve el VAG-Com del que hablais, para que sirve y que podria hacer con el, asi donde encontrarlo y donde comprar el cable. Muchas gracias de antemano y saludos a tod@s!!!
  6. Ok, muchas gracias
  7. Nadie puede ayudarme?
  8. Hola a tod@s. Anes de nada, decir que no estoy seguro si esto se debe postear aqui, y si no es asi disculpas de antemano. Mi duda es que tengo un manos libres parrot, que lo tenia instalado en un 306 y ahora tengo un TT del 2002 y quiero montarlo, pero me han dicho (en un taller) que si lo monto tal cual, es decir, conectando los isos como hice en el 306, no se que pasa que se puede quemar el manos libres porque hay un cable de la radio que saca corriente y que hay que cortar..... Mi radio es la concertII y el equipo no es bose, por lo que mi duda, es si esto es cierto o me lo ha dicho el taller para que me lo monten ellos, ya me entendeis. He buscado en el buscador y no he encontrado nada acerca de esto del cable, y no se porque tampoco puedo ver las fotos de los montajes. Si alguien puede ayudarme se lo agradeceria.... Y ya puestos a pedir, me gustaria saber para que sirve el VAG-Com del que hablais, para que sirve y que podria hacer con el, asi donde encontrarlo y donde comprar el cable. Muchas gracias de antemano y saludos a tod@s!!!
