Muy buenas, hoy me ha empezado a parpadear el testigo de calentadores lo he conectado al cable y hecho test y me hadado esto, si alguien me sabe decir que es lo que me falla y como solucionarlo.
Friday,11,April,2025,12:40:55:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8R4AA111339 License Plate:
Mileage: 356600km-221580mi Repair Order:
Chassis Type: 8R (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8R4AA111339 Mileage: 356600km/221580miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 NH HW: 03L 906 022 B
Component: R4 2.0l TDI H04 9978
Revision: 11H04---
Coding: 01210023180F2120
Shop #: WSC 06067 005 1048576
ASAM Dataset: EV_ECM20TDI03L906022NH A01010
ROD: EV_ECM20TDI03L906022JT.rod
VCID: 78FF0E6BC32690DEAC3-802D
2 Faults Found:
4515 - Radiator Fan (V7)
P1950 00 [039] - Movement Restricted / Jammed
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 356601 km
Date: 2025.04.11
Time: 12:32:20
4892 - EGR Valve (N18)
P0403 00 [175] - Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 356561 km
Date: 2025.04.10
Time: 20:17:22
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104) Labels: 8R0-907-379.clb
Part No SW: 8R0 907 379 L HW: 8R0 907 379 L
Component: ESP8 quattro H07 0010
Revision: -------- Serial number: --------------
Coding: 0C1540
Shop #: WSC 06335 000 00000
VCID: 4999BBAFE04CD95603D-801C
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0328
Revision: 00002001
Coding: 030500
VCID: 8109E38F18FC51161BD-80D4
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0070
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM
Component: KLIMA 1 ZONE H08 0180
Revision: A0000000 Serial number: 01130520100032
Coding: 34010000
VCID: 7CF7127BFF1EBCFEC8B-8029
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 5
Reset counter: 75
Mileage: 355446 km
Time Indication: 0
Date: 2025.01.18
Time: 19:55:52
Freeze Frame:
Temperature: 8.0 C
RPM: 2440 /min
Speed: 0.0 km/h
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H29 0380
Revision: 09029001 Serial number: 00000000665210
Coding: 260050914034AF010001000000001D0D0F1C070802010101000000
VCID: 3A7BD463B5AA42CE9A7-806F
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 100428 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 58
Reset counter: 99
Mileage: 338542 km
Time Indication: 0
Date: 2023.10.30
Time: 22:05:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941013005364
Coding: 100005
VCID: 489FBEABFB46205E1C3-801D
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 E HW: 8R0 959 655 E
Component: AirbagVW-AU10 H41 0610
Serial number: 003GND0G1792
Coding: 30423331313030303030554A304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 002004
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4683B093F952362EEEF-8013
Crash sensor for side airbag; driver side:
Serial number: 6334MSME520536600
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME53314135%
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME0761342CC
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME4D5D4C36
Crash sensor for front airbag; driver side:
Serial number: 63732SME0B61341E$
Crash sensor for front airbag; passenger side:
Serial number: 63832SME0A611F3E7
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JEA000KH
Coding: 000017
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H04 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 D HW: 8R0 920 930 D
Component: KOMBIINSTR. H11 0255
Revision: 00400000 Serial number: CJL46NV4A
Coding: 0F44220002000008050000
Shop #: WSC 06335 123 12345
VCID: 3561C75F9CB4ADB6775-8060
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 321070 km
Time Indication: 0
Date: 2022.11.28
Time: 11:01:57
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G105078401
Coding: 00C303
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010631515
Coding: 011D02205000440004
VCID: 4581B79FCC543D36E75-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0130107571
Coding: 013A0620203900C00520053280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F6DF5377EE897663D9-807A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010632122
VCID: 4487AA9BC76E043EF0B-8011
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000513432
Shop #: WSC 00000 000 00000
VCID: 3467FA5B97CEB4BE40B-8061
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H07 0350
Revision: 00000011 Serial number: AUZ5Z6J1401983
Coding: 0502008201058500015B070000
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000104202667
Coding: 010C02204000240004
VCID: 428BAC83DD7A0A0EC27-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000104200348
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005189962
Coding: 0010350
VCID: 3B75D1677A907BC6811-806E
End ---------------------------------------------------------------------
