-16891/P0507/001287 - Idle Control System RPM: Higher than Expected. Possible Symptoms
Malfunction Indicator Lamp (MIL) activePossible Causes
Throttle Valve Control Module (J338) dirty/faulty
Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Vacuum Leak
Possible Solutions
Check Throttle Valve Control Module (J338)
Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Check Intake System for Leaks
Special Notes
When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather ValveIf the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
-17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Secondary Air Injection for Leaks
Check Vacuum Lines for Leaks
Special Notes
Fuel Trim Info
When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Check Brake Booster and Hoses
Check Electric Vacuum Pump ( If Applicable )
Check Crankcase Ventilation System for faulty components. When the PCV or Crankcase Ventilation System is faulty, vacuum is typically present under the oil cap and misfire faults are common.
-16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Turbocharger faulty
Diverter Valve faulty
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
Check Turbocharger
Check Diverter Valve
Special Notes
When found in 2.0l TFSI:Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).RoW vehicles see: TPI 2016331 for details.
NAR vehicles see: TSB 01-07-70 or 2013392 for details.
When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: P2279, P1136, P1297, P1093 and/or P0507.
If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):Verify the mechanical part of the Exhaust Valve Control Module (J883) is not seized or binding.
When found in Audi A4/S4/RS4/Cabriolet (8K): 2.0l (CAEB):See TPI 2031245/6 - turbocharger excessive waste-gate play
