rotty
Todo lo publicado por rotty
  1. Le he pasado el vag antes de salir a dar una vuelta y me han salido todos estos fallos, me imagino que muchos de los que salen sera por haberse quedado sin corriente de golpe, no? La bateria, la verdad es que ya no anda del todo fina y esta pidiendo un cambio, puede ser por la bateria??? VAG-COM Version: Release 704.1 Data version: 20070422 Saturday,14,May,2011,17:21:18:59303 Chassis Type: 1M - Seat Leon/Toledo Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56 Mileage: 142670km/88651miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-012.LBL Part No: 038 906 012 AT Component: 1,9l R4 EDC 0000SG 2815 Coding: 00002 Shop #: WSC 06441 1 Fault Found: 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-10 - - - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL Part No: 1C0 907 379 D Component: ASR FRONT MK60 0103 Coding: 0021505 Shop #: WSC 00001 1 Fault Found: 00668 - Supply Voltage Terminal 30 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 1M0 820 043 D Component: 1M-CLIMATRONIC X0605 Coding: 00043 Shop #: WSC 00134 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL Part No: 6Q0 909 605 A Component: 1L AIRBAG VW5 0A 0006 Coding: 12620 Shop #: WSC 06441 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: None Part No: 1M0 920 801 B Component: S5-KOMBIINSTR. VDO V03 Coding: 05122 Shop #: WSC 03530 Part No: IMMO Component: IDENTNR: SEZ7Z0Y0835281 IMMO-IDENTNR: SEZ7Z0Y0835281 1 Fault Found: 01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901.LBL Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 06441 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.LBL Part No: 1J0 959 799 AH Component: 76 Zentral-SG Komf. 0001 Coding: 04097 Shop #: WSC 06441 Part No: 1J0959801F Component: 76 Tõrsteuerger. FS0002F Part No: 1J0959802G Component: 76 Tõrsteuerger. BF0002B Part No: 1J4959811C Component: 76 Tõrsteuerger. HL0002H Part No: 1J4959812C Component: 76 Tõrsteuerger. HR0002H 8 Faults Found: 00953 - Interior Light Time limit 25-10 - Unknown Switch Condition - Intermittent 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01331 - Door Control Module; Driver Side (J386) 52-10 - Supply Voltage Too High - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - - 00913 - Window Regulator Switch; Front Right Driver (E81) 27-10 - Implausible Signal - Intermittent 01332 - Door Control Module; Passenger Side (J387) 52-10 - Supply Voltage Too High - Intermittent 01333 - Door Control Module; Rear Left (J388) 52-10 - Supply Voltage Too High - Intermittent 01334 - Door Control Module; Rear Right (J398) 52-10 - Supply Voltage Too High - Intermittent End --------------------------------------------------------------------------------------------------
  2. Hola a todos: Seguro que muchos no me conoceis ya que por aqui no posteo casi nada, ya que ando todo el dia metido en el subforo de A4 B7 Os cuento mi aventura con el coche de mi mujer, que aunque no sea un A3, es un leonI y comparte muchisimas cosas con el A3. Estas son las cosas raras que me han pasado estos dias, a ver si alguien le ha pasado algo parecido o sabe por donde van los tiros El otro dia iba por la autovia y cuando daba a los intermitentes para cambiar de carril, se me apagaba la radio, menudo coñazo :ranting2: , cuando llegue a casa volvi a coger el coche y no lo volvio a hacer, no le di mas importancia Pero pasados tres o cuatro dias, lo llevaba mi mujer y al dar al boton de warning para poner los intermitentes de emergencia, se le apago el cuadro y se le paro el coche, quitamos el contacto, volvimos a arrancar y sin problemas. Y hoy sin tocar nada, se a parado y se a apagado el cuadro, cuando lo hemos vuelto a arrancar en el cuadro estaba la luz de los calentadores encendida (fija) y se a apagado al vover a arrancar. A modo de informacion os comento que el rele 109 lo cambie hace 6 meses por que se paraba el coche sin motivo alguno y al cambiarlo funcionaba correctamente, hasta estos dias que me esta pasando esto???? Alguien sabe por donde empiezo a mirar que es lo que me puede estar pasando?????
  3. ARITZETXE también va en envio conjunto del prc Bilbao
  4. no te apuntas a la conjunta?? no me jodas txooooooooooo Ya sabes que si hay una conjunta, me apunto!!!!!! :clap1: Por cierto, el envio a los miembros del PRC Bilbao, que solo sea un envio y luego ya lo repartimos en el PRC Creo que turbo1.8, quattro-t, juankir y yo, estaremos de acuerdo
  5. Debido a la presion que estoy sufriendo por parte de algunos integrantes del PRC Bilbao, me apunto para dos muelles mas Copio y pego la lista y con el permiso de quattro-t le apunto a el tambien con sus 4 muelles Xavi10 Turbo1.8 Audiete Fersan Juankir Avant130 Jhr Lex_bcna meatloaf Quattro-T (4 muelles) Rotty
  6. te digo!! Gracias tineo son 20€ menos!!! Hoy mismo se lo estaba comentando a turbo1.8, ya que yo cuando necesite el hidrahulico del capot del seat leon, lo compre en oscaro y costo baratillo, en comparacion de si lo hubiera comprado en el conce
  7. Un gran brico!!!!! Como ya te comente en el clubseatexeo, despues de ir viendo tu brico, ya me suponia que mucha gente de por aqui se iba a apuntar a la apertura automatica!! Gran trabajo Albert
  8. Yo llevo lo mismo que tu pero ET 35 y no he tenido el mínimo problema
  9. Mandale un mp a quattro-t que el hizo ese cambio
  10. Yo cuando tuve el radio cd alpine y una pantalla de un din, tenia que tener un adaptador phonocar para que funcionen los traseros. Lo tengo tirado por algun sitio, ya que ahora llevo el rnse y no me hace falta, si lo necesitas, hablamos
  11. Pero tu llevas el adaptador phonocar???? Es que yo cuando llevaba el radio cd alpine lo tenia puesto, ya que si no, no se oian los traseros
  12. Yo llevo las TRW y van perfectas Del espesor no te puedo ayudar, pero Asi las ferodo duraran algo mas
  13. El enlace del forero aritzetxe no lo encuentro, seria cuestion de mandarle un MP, pero el de Quattro-t AQUI TE LO DEJO
  14. Se usan las mismas pastillas para los discos de 245mm y 255mm de diametro
  15. De los que me vienen a la cabeza que tienen alguna para vender, son QUATTRO-T y ARITZETXE
  16. El mio es un Tdi de 140 y llevo ESTAS Número de PR : 1KD;1KP
  17. Bienvenido a ti y a tu furgo!!!!! Bonito cacharro
  18. Y cuanto es barato? Por que por el foro andan las concert III, por poco mas de 100 euros, y esas seguro que te valen, seguramente la del exeo también, pero eso ya es cuestión de gustos.
  19. Si no recuerdo mal fueron sobre los 1200
  20. Yo te recomiendo lo que yo llevo montado Una KW V2, y estoy encantado, la compre y monte en romisport
  21. Los que he pedido yo son los rojos ahumados, como los de sline21 Los pidió ayer y me dijo que igual los podía tener para finales de la semana que viene
  22. El color rojo smoke en el dorado no lo tienen ya que solo es rojo y negro y pienso que en negro es muy truñing, los rojos son los que se ven en el post 5 montados. No se si esperar a que traigan el nuevo modelo ya que me gusta el dectane rojo smoke , sabes si el Dorado los va a traer? Un saludo. Vengo de autoseldorado y lo que he visto y me ha contado es lo siguiente Hay 4 colores de pilotos para los B7 avant, me refiero a los que tambien llevan el intermitente con leds Son estos Negro (interior del piloto negro y cristal transparente), Este lo he visto en la tienda y no me hace mucha gracia Rojo (interior rojo y cristal transparente), seran los que monto Loisete en su dia Negro smoke (interior negro y cristal ahumado) Rojo smoke (interior rojo y cristal ahumado), estos creo que son los que monto Sline21 Deciros que aunque no los tenga en la pagina, los puede pedir, ya que a mi me traera en breve los rojos ahumados, Lo que no se si traera tambien los negros ahumados para tenerlos, yo en cuanto los vea os comento lo que sepa Respecto a los otros que son mas OEM, me ha dicho que lo va a mirar y en cuanto esten disponibles en la pagina de dectane, tambien los pondra el en la suya Y claro esta que a mejor precio que en la pagina de dectane
  23. Los de dectane y los de eldorado son los mismos Respecto a los que se nombran por aqui, ya se lo he comentado a el de eldorado, por si los va a traer. Yo creo que la diferencia mas apreciable entre unos y otros, es que en los ultimos hay menos separacion de leds entre el piloto de la aleta y el orton y el que ya se ha montado en este foro, tine antiniebla, marcha atras e intermitente con leds Por cierto, en el nuevo modelo, tambien hay color smoke?????
  24. En la 5ª respuesta de este post, tienes un enlace para pinchar e iras al post donde salen ya montados en dos foreros de aqui
