Victor MC
Todo lo publicado por Victor MC
  1. esto es lo que me dice el Vagcom. No tengo ni idea, pero de la presion del aceite no veo nada...
  2. Sunday,29,December,2013,20:54:13:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 VIN: TRUZZZ8JX81048910 Mileage: 145770km/90577miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8J0 907 115 N HW: 8J0 907 115 Component: 2.0l R4/4V TFSI 0010 Revision: 5BH16--- Serial number: AUX7Z0H3FNP0QW Coding: 0113000318070060 Shop #: WSC 00191 264 15243 VCID: 377735054656A51 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8J0-614-517.lbl Part No SW: 8J0 614 517 HW: 8J0 614 517 Component: ESP MK60E1 0130 Revision: 00H52001 Coding: 0017424 Shop #: WSC 01236 785 00200 VCID: EAD15C71C564489 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8J0 820 043 AF HW: 8J0 820 043 AF Component: J255 Klima 1 Zone 0080 Revision: 00H08005 Serial number: 00000001089196 Coding: 1572868 Shop #: WSC 01236 785 00200 VCID: 6AD1DC714564C89 1 Fault Found: 00710 - Defroster Flap Positioning Motor (V107) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 254 Reset counter: 13 Mileage: 137133 km Time Indication: 0 Date: 2013.06.14 Time: 07:56:21 Freeze Frame: Voltage: 14.30 V Temperature: 23.0°C (no units): 40.0 (no units): 31.0 Temperature: 21.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl Part No SW: 8P0 907 279 K HW: 8P0 907 279 K Component: Bordnetz-SG H54 2501 Revision: 00H54000 Serial number: 00000008349477 Coding: A1060E8280141C004F1800001800000000095E075C210802000000000000 Shop #: WSC 01236 785 00200 VCID: 458B4FCD0CBAC71 Subsystem 1 - Part No: 8J1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer AU354 H07 0070 Coding: 00064784 Shop #: WSC 01236 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8J0-959-655.lbl Part No SW: 8J0 959 655 HW: 8J0 959 655 Component: -s Airbag 9.43 H02 0020 Revision: 93H02002 Serial number: 0036K002N57N Coding: 0011635 Shop #: WSC 01236 785 00200 VCID: F9F3733DB0C2F31 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H36 0070 Coding: 0002011 Shop #: WSC 01236 785 00200 VCID: 41835BDD1892EB1 Part No: XXXXXXXXXXX Component: E0221 H06 0030 1 Fault Found: 01304 - Radio 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb Part No SW: 8J0 920 930 E HW: 8J0 920 930 E Component: KOMBIINSTR. VDO H23 0150 Revision: D0H23003 Serial number: 2243H003117125 Coding: 0004128 Shop #: WSC 80093 222 69422 VCID: 2E591061B90C649 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 P HW: 1K0 907 951 Component: J533__Gateway H16 0192 Revision: H16 Serial number: 2500K084088060 Coding: E9801F061002024100 Shop #: WSC 01236 785 00200 VCID: 346D020957204E9 1 Fault Found: 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 15 Reset counter: 161 Mileage: 142588 km Time Indication: 0 Date: 2013.08.07 Time: 11:29:46 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8J0 920 930 E HW: 8J0 920 930 E Component: KOMBIINSTR. VDO H23 0150 Revision: D0H23003 Serial number: AUX7Z0H3FNP0QW Shop #: WSC 00000 000 00000 VCID: 2E591061B90C649 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl Part No SW: 8J8 959 801 D HW: 8J8 959 801 D Component: Tuer-SG H02 0060 Coding: 0004149 Shop #: WSC 01236 785 00200 VCID: 3E792021696C949 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 8J1 909 143 C Component: EPS_ZFLS Kl.157 H08 1903 Shop #: WSC 01236 785 00200 VCID: 30650E19A338729 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Mileage: 145740 km Temperature: 24.0°C Voltage: 7.70 V Voltage: 7.50 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8J0-959-433.lbl Part No: 8J0 959 433 B Component: KSG H11 0080 Coding: 1890300201182D298505488AD677 Shop #: WSC 01236 785 00200 VCID: 356B3F0D5C5A571 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Part No: 8J0 951 177 Component: DWA-Sensor H03 0020 1 Fault Found: 00849 - S-contact at Ignition/Starter Switch (D) 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8J0-035-223.lbl Part No SW: 8J0 035 223 B HW: 8J0 035 223 B Component: J525 Amp Std H03 0120 Revision: 00H03001 Serial number: 93802005284406 Coding: 0106114 Shop #: WSC 01236 785 00200 VCID: 234FF155E2CED91 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: None VCID: 55AB9F8DBC1A771 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached End --------------------------------------------------------------------- Sunday,29,December,2013,20:58:58:32264 VCDS Version: Release 11.11.3 Data version: 20120401 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 VIN: TRUZZZ8JX81048910 Mileage: 145770km/90577miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8J0-614-517.lbl Part No SW: 8J0 614 517 HW: 8J0 614 517 Component: ESP MK60E1 0130 Revision: 00H52001 Coding: 0017424 Shop #: WSC 01236 785 00200 VCID: EAD15C71C564489 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8J0 820 043 AF HW: 8J0 820 043 AF Component: J255 Klima 1 Zone 0080 Revision: 00H08005 Serial number: 00000001089196 Coding: 1572868 Shop #: WSC 01236 785 00200 VCID: 6AD1DC714564C89 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl Part No SW: 8P0 907 279 K HW: 8P0 907 279 K Component: Bordnetz-SG H54 2501 Revision: 00H54000 Serial number: 00000008349477 Coding: A1060E8280141C004F1800001800000000095E075C210802000000000000 Shop #: WSC 01236 785 00200 VCID: 458B4FCD0CBAC71 Subsystem 1 - Part No: 8J1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer AU354 H07 0070 Coding: 00064784 Shop #: WSC 01236 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8J0-959-655.lbl Part No SW: 8J0 959 655 HW: 8J0 959 655 Component: -s Airbag 9.43 H02 0020 Revision: 93H02002 Serial number: 0036K002N57N Coding: 0011635 Shop #: WSC 01236 785 00200 VCID: F9F3733DB0C2F31 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H36 0070 Coding: 0002011 Shop #: WSC 01236 785 00200 VCID: 41835BDD1892EB1 Part No: XXXXXXXXXXX Component: E0221 H06 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb Part No SW: 8J0 920 930 E HW: 8J0 920 930 E Component: KOMBIINSTR. VDO H23 0150 Revision: D0H23003 Serial number: 2243H003117125 Coding: 0004128 Shop #: WSC 80093 222 69422 VCID: 2E591061B90C649 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 P HW: 1K0 907 951 Component: J533__Gateway H16 0192 Revision: H16 Serial number: 2500K084088060 Coding: E9801F061002024100 Shop #: WSC 01236 785 00200 VCID: 346D020957204E9 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8J0 920 930 E HW: 8J0 920 930 E Component: KOMBIINSTR. VDO H23 0150 Revision: D0H23003 Serial number: AUX7Z0H3FNP0QW Shop #: WSC 00000 000 00000 VCID: 2E591061B90C649 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl Part No SW: 8J8 959 801 D HW: 8J8 959 801 D Component: Tuer-SG H02 0060 Coding: 0004149 Shop #: WSC 01236 785 00200 VCID: 3E792021696C949 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 8J1 909 143 C Component: EPS_ZFLS Kl.157 H08 1903 Shop #: WSC 01236 785 00200 VCID: 30650E19A338729 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8J0-959-433.lbl Part No: 8J0 959 433 B Component: KSG H11 0080 Coding: 1890300201182D298505488AD677 Shop #: WSC 01236 785 00200 VCID: 356B3F0D5C5A571 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Part No: 8J0 951 177 Component: DWA-Sensor H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 8J0-035-223.lbl Part No SW: 8J0 035 223 B HW: 8J0 035 223 B Component: J525 Amp Std H03 0120 Revision: 00H03001 Serial number: 93802005284406 Coding: 0106114 Shop #: WSC 01236 785 00200 VCID: 234FF155E2CED91 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 8J8 959 802 D HW: 8J8 959 802 D Component: Tuer-SG H02 0060 Coding: 0004148 Shop #: WSC 01236 785 00200 VCID: 3F875D256E669D1 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached End ---------------------------------------------------------------------
  3. Pues eso, desde hace dos días se me enciende la luz roja de la presión del aceite, al principio se encendía pitaba y después se quitaba. El nivel del aceite esta perfecto y el coche va ok, no hace nada anomalo... A alguien se le ocurre algo??? Gracias
  4. A mi me parece horroroso también
  5. Que wapo!!!!!!!!!!!!!!
  6. Ha quedado muy bien, no se aprecia nada raro.
  7. Yo he puesto Bridgestone Potenza 255/35/19
  8. tengo 145.000 km
  9. Habia leido tu post. Pero no se que poner con la s-line, quiero algo duro y no puedo bajr mas la suspension porque me toca la rueda si lo hago....
  10. quería ponerla un poco mas dura que la de serie por aquello de q cuando va el coche cargado pueda rozar. Imagino que si pongo Bilstein B6 ira bien. No???
  11. Ya he visto que hay que cambiar muelles. Me da miedo que baje mas mi coche y me rocen las ruedas
  12. Oye y los B8 con los muelles s-line de serie como iran, porque no quiero cambiar muelles ni bajar mas el coche. Gracias
  13. Yo llevo 9,5j ET45 en 19 pulgadas y he tenido que ensanchar medio cm las aletas, haciendo curvas fuertes ya no me toca, pero en algún bache fuerte si me da, yo si llevo la sline y es cierto que los amortiguadores ya hace falta cambiarlos. Imagino que en cuanto cambie amortiguadores ya no tocará nunca.
  14. Me van a ensanchar un poco las aletas traseras, pero poco, a final de semana os cuento como queda la película..
  15. Gracias. He estado hoy de ruta y cuando tomo curvas fuertes me roza, lo que no se si es en el guarnecido en la aleta por dentro o en la inserción con el parachoques trasero, no parece que sea mucho, pero tengo que solucionarlo. Alguna idea...
  16. La rueda queda al ras de la aleta.
  17. Ha quedado muy bien
  18. La medida de la llanta es 9,5j et 45 19. Llevo sline y cuando pilo baches me toca sobre todo atrás, voy a intentar solucionarlo, creo que cortando el guarnecido de dentro solucionare algo y cambiando amortiguadores que tienen 142.000km lo terminare de arreglar, eso espero
  19. Bueno pues lo prometido es deuda
  20. Oye soy de Madrid, lo mismo podemos quedar y lo ves personalmente
  21. yo tengo sline, en cuanto me den el coche (jueves, viernes) pongo unas fotitos y te mido lo que me digas.
  22. No podía ser yo. Llevo sin coche casi dos meses...
  23. Bueno, al parecer mis llantas han llegado hoy. Como tienen que hacerme un par de arreglillos de chapa calculo que el jueves ya tendré mi coche. En cuanto lo tenga prometo subir fotos. Saludos.
  24. Jajajajajaja Lo de mis llantas parece la obra del escorial, tendrían que haberlas mandado el viernes pasado pero me han dicho que llegaran el jueves... En fin... aburrido estoy ya... confío en que a mediados de la semana que viene ya estará todo ok.. Os mantengo informados
  25. Si te gustan igual... No lo cambies de color.
