Grozdanov
Todo lo publicado por Grozdanov
  1. Grozdanov
    Mileage to KM
    How do I change the display to read KM instead of Miles using VagCom?
  2. Have you already tried in the A3 forum?. No...
  3. Please send me the scheme for the original subwoofer Nokia for Audi A3 8L
  4. Thank's but this is for the reset service interval Nothing for my car
  5. This is for the reset service interval. I want to change oil interval, not to reset :ranting2:
  6. This is for the reset service interval. I want to change oil interval, not to reset
  7. How to change oil interval with vag-com? I go to [17-Instruments], [10-Adapatation] and I go to 43 Channel, but there I can't change the value P.S. The car is Audi A3 1.8T 2001
  8. How To Install Original PDC of Audi A3 8L
  9. This function is only possible to activate with VAG-COM on dashboard since 2002!! Ok, but how?
  10. ¿Qué más? No puedo inmovilizador tren y coche no puede iniciar. What more? I can not train immobilizer and car can not start. ¿Tienes el Login-Code del cuadro de instrumentos? Lo tengo Login-Code En el manual que te he puesto antes te sale toda la información que necesitas para casar el cuadro. Thank you
  11. ¿Qué más? No puedo inmovilizador tren y coche no puede iniciar. What more? I can not train immobilizer and car can not start.
  12. My dashboard is with immo2, but I bought dashboard from S3 with FIS, and it is with immo3 and I can not let him go. Can someone help me?
  13. Hola, He comprado un póster de S3 con pantalla FIS, pero se encontró en immo3, no immo2 como yo. ¿Cómo se puede estimular nuevas bordo? Atentamente, Grozdanov
  14. This function is only possible to activate with VAG-COM on dashboard since 2002!! Ok, but how?
  15. Quiero que cuando me dan un contacto con el tablero de luces que se incluirán automáticamente, no cuando las luces a su vez. Quiero activar esta función con VAG-COM.
  16. but your car that year? my S3 even with the lights off leads the table on?? a greeting uncle My car is 2001 year. Yes when I switch contact - table lights activated, not when includes headlights. and you do not understand it, the car started without the lights on, if I ami illuminates the table. is that what you want to know? a greeting Guzman No, I want when I give a contact of the dashboard lights to be included automatically, not when lights turn. I want to activated this function with Vag-Com
  17. but your car that year? my S3 even with the lights off leads the table on?? a greeting uncle My car is 2001 year. Yes when I switch contact - table lights activated, not when includes headlights.
  18. I want to do when the switch contact of the dashboard lights to be activated without having to be turned lights. Please help me
  19. I have all necessary materials for this procedure, I have and all diagrams for the electronics, but I expect may be problems. When I finished with installation I will created pdf file and I will uploaded this file there. Greetings
  20. Ok, I will waiting your new post. Thanks again
  21. Thanks, I searching instructions for installation about A3 2001 facelift, not for model 96-00 becouse the PIN connecter are different.
  22. I don't speak spanish, sorry. Use http://translate.google.com
