Todo lo publicado por Super-Raton
nuevo a4, en vez de suspension s line, me encasquetan la deportiva
Super-Raton responde a GNOMO1979 de discusión en Audi A4 / Allroad B8 (2008-2015)
E0W = Special edition 7A3 = CD player 4UF = Drivers and front passenger air bag with front passenger air bag deactivation 6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated 5SL = Left exterior mirror: aspherical 5RU = Right exterior mirror: convex (large viewing field) 1KW = Disc brakes, rear J0B = 520 A (92 Ah) battery 1LY = Disc brakes, front 1AS = Electronic stabilization program (ESP) 1BV = Sports suspension/shock absorption 3FA = Without roof insert (standard roof) 5TQ = Decorative titanium inserts 7X1 = Park distance control F0A = No special purpose vehicle, standard equipment 8GU = Alternator 140 A 0Q1 = Label for brake-proportioning values 0YE = Weight range 5 installation control only, no requirement forecast 0JD = Weight category front axle weight range 4 TM4 = 4-cylinder diesel engine 2.0 l unit 03L.M 3NZ = Rear seat bench unsplit, backrest split folding 8BP = Bi-functional headlight with gas discharge lamp U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer X3B = National sales program Spain (FBU) 1N3 = Speed-related variable steering assist (Servotronic) 1XW = Leather trimmed multi-function sports steering wheel 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving) 9GB = Interior light with switch-off delay anddoor pillar switch 8Z4 = Moderate hot country D94 = 4-cyl. turbo diesel engine 2.0 l/100 kW (4V) TDI common rail, base engine: TG3/TJ3/TH3/TU3/TL4/TM4/TP4/TP5/TM3/TW3 7Q0 = Without navigation device C8S = Alloy wheels 8J x 18 7K0 = Without tire pressure warning light 4X3 = Side air bag front with curtain air bag 2K1 = Reinforced bumpers 3L3 = Manual height adjustment for front seats 4KC = Side and rear windows in heat-insulatingglass 3Y0 = Without roll-up sun screen 4K4 = Radio remote controlled central locking 5D7 = Carrier frequency 868 MHz without panic button 1SA = Without additional engine guard 7MG = Emission standard EU5 Q1D = Sports front seats 4GF = Windshield in heat-insulating glass -
Hola ferjat, Yo tengo la resolucion 400x234 y me ocupa la pantalla completa... En el archivo SYS.txt tengo lo siguiente... por si te sirve... [rawdisplay] screen_x=400 screen_y=234 highres=0 class="landscape" Saludos!
Hola ferjat , Creeme cuando te digo que eso que pones, nos suena familiar a unos pocos por aqui... Supongo que habras leido este post... (es larguiiiiiisimo pero interesante...) http://www.audisport-iberica.com/foro/index.php?showtopic=216273 Saludos!
Hasta donde yo se, el tope no, pero los muelles s'i. Yo tengo montados en deportiva unos que tambien sirven para S-Line en otros modelos y otros codigos de peso... Te lo miro hoy... Saludos! -
ferjat, Ese navegador no ocupa toda la pantalla... tienes puesta la resolucion correcta? Respecto a la luminosidad habria que ver una foto con un buen sol fuera... Como lo ves los dias de mucha luminosidad? (por Malaga muchos... ) Saludos!
Hola Gnomo, Mi opinion es que lo unico a lo que te puedes "agarrar" es a las referencias de lo topes que, como te ha comentado Pablo, son tipo S-Line (-30mm) en el eje delantero y tipo Deportiva (-20mm) en el eje trasero... Para afinar con las demas referencias deberiamos ver los codigos de peso de tu pegatina de PRs... ya que sabemos que el mismo muelle se usa para determinadas versiones S-Line (1BV) y tambien para otras con suspension Deportiva (1BE)... en funcion de otros equipamientos... En las fotos que has colgado yo lo veo bien, a simple vista no me parece mas alto que cualquier otro S-Line aunque las fotos siempre engañan un poco... Por ultimo, eso que te han comentado en el taller de que lo nuevos han cambiado en algo... Si, por el motivo que sea AUDI ha cambiado los codigos de peso de determinados modelos entonces el caos ya es total... Podrias poner una foto completa de tu pegatina de PRs para poder hacer un analisis completo de tu caso... je je... suena a consulta del médico... Saludos! PD: Fiate de paul que ha pasado miles de horas mirando esos codigos... -
NAVEGADOR IGO BT DVD TDT TACTIL PARA A4 A5 Q5 NEW
Super-Raton responde a mikia4plata de discusión en Electricidad Audi A4 B8
Hola Esteban, Vamos a ver si el forero ferjat nos contesta algo que parece que la tiene instalada... http://www.audisport...0&gopid=3195338& El link que pones es solo el modulo GPS... Tiene buena pinta pero habría que añadirle un interface (tipo Xcar-Link) para que se viera por pantalla... Saludos! Aqui el conjunto... http://gsmserver.es/shop/navigation_pack_for_audi_a4_a5.php Saludos! -
Este parece un buen repuesto para la camara trasera... con tirador incluido... http://gsmserver.es/shop/rear_view_camera_for_audi_a4l.php Saludos! -
Hola Esteban, Vamos a ver si el forero ferjat nos contesta algo que parece que la tiene instalada... http://www.audisport-iberica.com/foro/index.php?showtopic=256456&st=0&gopid=3195338& El link que pones es solo el modulo GPS... Tiene buena pinta pero habría que añadirle un interface (tipo Xcar-Link) para que se viera por pantalla... Saludos! -
Hola ferjat, Como instalaste esa pantalla tactil en el coche? Has notado reduccion de la luminosidad de la pantalla? reflejos? Puedes poner algunas fotos del resultado? Gracias. Saludos!
Estare atento ya que mi pantalla al igual que la vuestra da muchos reflejos, un salu2. La pantalla ya esta de viaje. En cuanto la reciba pondré unas fotos... Cuando la tenga instalada creo que lo ideal seria quedar con jAVIVI o Rushifuru para comprobar la diferencia (si la hay)... Me han mandado un mail con instrucciones de instalacion pero no hay nada reseñable... para conseguir la posicion correcta y no ponerla al reves me dicen que el cable debe quedar abajo a la derecha (el cable no va centrado)... Saludos! hola super, como te fue lo de la pantalla? ya lo instalaste. Hola alex82, Pues sí... ya recibi la pantalla y fue un fracaso total... :crying_anim: Funcionaba bien con el GPS pero era demasiado grande, no la pude adaptar y no tenia pinta de que fuera a mejorar mucho la visibilidad... En fin... habra que seguir buscando... Saludos! que lastima super. yo compre una vez una cosa de ebay y me gaste 70€ y no vea que mal me sento cuando vi que no valia. habra que seguir investigando. un saludo Alguien se anima con esta...? http://gsmserver.es/shop/car/6_5_8243_touch_glass.php Saludos! -
Neumático 235 45 R18
Super-Raton responde a paul2008 de discusión en Audi A4 / Allroad B8 (2008-2015)
Puede ser buena idea. A ver como queda la llanta de protegida...??? Sin animo de desilusionarte, el paso de rueda lo vas a "llenar" en 8 milimetros... que es lo que aumenta el radio del conjunto... y el techo del coche ira 8 milimetros mas alto... no? Respecto al neumatico, en el taller que fuimos el otro dia, comentaron que el Goodyear F1 Asymetric era bueno en eso, pero me parece tan dificl y tan subjetivo ese tipo de valoraciones que no se muy bien que opinar. Sí te puedo decir que el Michelin es ruidoso, por experiencia... Saludos! -
No hay de que Super, con haber conseguido mejarlo ya es algo. Seguire pensando en ello aunque yo ya no tengo nada de nada. Esteban, cuando dices que la pantalla se descalibraba sola, a que te refieres?? a que cada vez que encendias el interface te pedia calibrar? Si es asi, a mi tambien me lo hizo hasta que lo arregle y era porque no leia la tarjeta que es donde guarda algun dato de la calibracion para que no la vuelva a pedir la procima vez que se encienda. Le puse el sabado a superraton dos ferritas en la alimentacion del interface y se ha solucionado mucho su problema con las interferencias. Una iva en el cable amarillo y otra en el rojo. Yo puse solo una en el amarillo y se quitaron las que tenia. Abriendo el interface, podrias mirar las soldaduras de los pìnes de la alimentacion por si se han soltado de la placa o hay alguna soldadura frai. A Cendri le tuvieron que resoldar muchos contactos de la placa del interface porque estaban de pena y le funcionaba masl. Espero des con el problema. Un Saludo!! Han vuelto... Esta mañana fiesta de interferencias...!!!:crying_anim: :crying_anim: Voy a probar a quitar la ferrita del rojo y dejar solo la del amarillo, como lo llevas tu... Saludos! -
Cuanto os cuesta el sello del ayuntamiento?
Super-Raton responde a julio548 de discusión en Audi A4 / Allroad B8 (2008-2015)
+1... 137 euros tambien para un TDI 143CV... Salduos! -
QUE MEDIDA DE SEPARADORES MONTO?????
Super-Raton responde a bonevil de discusión en Mecánica Audi A4 B8
Y alguien los ha montado...? Marca? Anchura? Saludos! -
QUE NEUMATICOS RECOMENDAIS
Super-Raton responde a Ajusta de discusión en Audi A4 / Allroad B8 (2008-2015)
Si haces muchos km, le das "tralla" y no quieres tener problemas, Michelin es una apuesta segura... que se paga, claro... Esa es mi experiencia con este y otros coches... Saludos! -
CAMBIO CUBIERTAS 235/45/17 GOOD YEAR
Super-Raton responde a lorenmarin de discusión en Audi A4 / Allroad B8 (2008-2015)
Y el motivo...? Yo habia pensado en las goodyear para mi proximo cambio... Ahora llevo Michelin HP Primacy 225/50/17 con 20.000 km y ningun problema... pero creo que las goodyear me van mas por el numero de km al año que hago (menos de 15.000) y por se menos ruidosas... Y encima cuestan casi la mitad... Llevas servotronic? Saludos! -
Experiencia Audi A4
Super-Raton responde a BarraoA4 de discusión en Audi A4 / Allroad B8 (2008-2015)
Hola Barrao! Bienvenido al foro. Veo que es tu primer mensaje... Tambien hago viajes largos un par de veces al año y estoy de acuerdo con tu impresiones... cuando el viaje pasa de 800 Km, notas la diferencia con otros coches... en cuestion de cansancio y sensaciones... Buena musica o buena conversacion y es un placer hacer kilometros... Esperamos algunas fotos de ese rojito... Saludos! -
MINI QUEDADA FORO A4 B8
Super-Raton responde a Super-Raton de discusión en Audi A4 / Allroad B8 (2008-2015)
Se ve mucho mejor así... gracias Pablo! Saludos! -
Hola! javivitf, a ver si te acuerdas de pasarme ese menu sencillito que comentamos ayer... GRACIAS!!! Rushi, gracias por las ferritas que me intalaste ayer. Todavia se escucha algo pero ha mejorado muchísimo!!!! GRACIAS!!! Esteban, una pena que te haya pasado eso... Si te puedo ayudar en algo, me dices... Sigo investigando sobre las pantallas tactiles... Os contaré... Saludos! -
MANUAL INSTRUCCIONES EN PDF
Super-Raton responde a ze pequeño de discusión en Audi A4 / Allroad B8 (2008-2015)
Gracias! Buen aporte!!! http://www.megaupload.com/?d=N5CPB4YG Saludos! -
Notese la marca negra para ocultar a dos de los foreros "mas buscados" por AUDI... :lol2: Lo he pasado muy bien... :notworthy: Saludos! -
Perdon por la calidad de las fotos... son de movil... Vista general, aunque no salen todos lo coches... Falta Cuasar, Jero y Batallas que quedan fuera de este plano... De izquierda a derecha: Cuasar (maletero abierto), javivitf, paul2008 (de culo...:ranting2: ), Chity, Rafis, Super-Raton, vwgolf y Rushifuru... Saludos! -
Algunas fotos... En esta podemos ver ademas: - Azul Aruba de VWGolf con suspension normal y llanta 16" - Azul Mar de Super-Raton con suspension deportiva y llanta 17" - Azul Aruba de Rafis con suspension S-Line y llanta 18" En la variedad está el gusto... Saludos! -
je je je... muy bueno Aquelarre... :laugh: Mega-Raton! Giga-Raton! Tera-Raton! etc... Hay mucho margen de mejora...
