PLATHY
Todo lo publicado por PLATHY
  1. ESs como has puesto de ejemplo 66666 +2= 66668 asi cambias la configuracion
  2. Windows Based VAG/VAS Emulator VCDS Version: Release 10.6.4 Data version: 20110418 www.Ross-Tech.com 1 Fault Found: 18017 - Crash Shut-Down Activated P1609 - 001 - Upper Limit Exceeded Readiness: 0010 0001 Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Thursday,13,October,2011,11:23:31:10074 VIN: WAUZZZ8E45A423521 License Plate: Mileage: Repair Order: Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E45A423521 Mileage: 70700km/43930miles-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B Component: 1.8L R4/5VT G 0010 Coding: 0011581 Shop #: WSC 33278 133 00032 VCID: 7F0907CF576D -------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 159 B HW: 01J 927 156 HT Component: V30 01J 1.8l5VT RdW 0010 Revision: 00000006 Serial number: 00000000840513 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 285BFC93E263 4 Faults Found: 18201 - Transmission Output Speed Sensor 2 (G196): No Signal P1793 - 000 - - 17137 - Shift Solenoid 1 (N88): Circuit Failure P0753 - 007 - Short to Ground - Intermittent 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 000 - - 17134 - Shift Solenoid 1 (N88): Malfunction P0750 - 000 - - - Intermittent ------------------------------------------------------------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 2 VIN: WAUZZZ8E45A423521 License Plate: Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004872 Shop #: WSC 06335 000 00000 VCID: 2647F2ABE877 -------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2728 Coding: 00000 Shop #: WSC 06335 VCID: 69DDB99739E9 -------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 J Component: int. Lastmodul ECE 0303 ----------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS
  3. Windows Based VAG/VAS Emulator VCDS Version: Release 10.6.4 Data version: 20110418 www.Ross-Tech.com 1 Fault Found: 18017 - Crash Shut-Down Activated P1609 - 001 - Upper Limit Exceeded Readiness: 0010 0001 Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Thursday,13,October,2011,11:23:31:10074 VIN: WAUZZZ8E45A423521 License Plate: Mileage: Repair Order: Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E45A423521 Mileage: 70700km/43930miles-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B Component: 1.8L R4/5VT G 0010 Coding: 0011581 Shop #: WSC 33278 133 00032 VCID: 7F0907CF576D -------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 159 B HW: 01J 927 156 HT Component: V30 01J 1.8l5VT RdW 0010 Revision: 00000006 Serial number: 00000000840513 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 285BFC93E263 4 Faults Found: 18201 - Transmission Output Speed Sensor 2 (G196): No Signal P1793 - 000 - - 17137 - Shift Solenoid 1 (N88): Circuit Failure P0753 - 007 - Short to Ground - Intermittent 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 000 - - 17134 - Shift Solenoid 1 (N88): Malfunction P0750 - 000 - - - Intermittent ------------------------------------------------------------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 2 VIN: WAUZZZ8E45A423521 License Plate: Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004872 Shop #: WSC 06335 000 00000 VCID: 2647F2ABE877 -------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2728 Coding: 00000 Shop #: WSC 06335 VCID: 69DDB99739E9 -------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 J Component: int. Lastmodul ECE 0303 Coding: 00001 Shop #: WSC 06335 VCID: 397D29D709C9 -------------------------------------------------------------------------------Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H10 3230 Revision: 91H10323 Serial number: 0036M000NG1S Coding: 0033622 Shop #: WSC 06335 000 00000 VCID: 3B7133DF03F5 1 Fault Found: 01587 - Igniter 2 for Airbag; Drivers Side (N250) 001 - Upper Limit Exceeded - Intermittent - MIL ON ------------------------------------------------------------------------------- No fault code found. 1 Fault Found: 01304 - Radio 004 - No Signal/Communication No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 3 VIN: WAUZZZ8E45A423521 License Plate: Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 00041 Shop #: WSC 06335 VCID: 418D41376119 -------------------------------------------------------------------------------Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 Q HW: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0020 Revision: 0020 Serial number: AUX6Z0D0447840 Coding: 0004141 Shop #: WSC 00160 572 63401 VCID: 326F1EFBD4BF -------------------------------------------------------------------------------Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: EBD1439FB315 ------------------------------------------------------------------------------- Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0205 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 4 VIN: WAUZZZ8E45A423521 License Plate: Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BM Component: Komfortgerát T3B 2431 Coding: 06266 Shop #: WSC 06335 VCID: 7DF5FDC75D61 2 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 00915 - Window Regulator Switch; Rear Right; Driver (E55) 27-10 - Implausible Signal - Intermittent End ----------------------------------------- estos son los fallos que me a salido a pasar el autscan, despues de ver los allos que me salen como airbag, instrumentos, y demas cosas mi duda es que pasos e de seguir para poder quitar estos fallos ya que no tengo ninguna idea del vag, hasta hay llego no toco nada por si borro algo. gracias de antemano
  4. Os cuento mi caso en la ultima revision que pase en jarmauto, 480 euros por la revision, dejo en coche y me dicen que tardaran como un par de horas, cojo el autobus hacia mi casa y el trayecto dura unos 20 minutos fue llegar a mi casa y me suena el movil la revision ya estaba echa voy a reocger el coche y el susto 480 euros en 20 minutos, pero mi sorpresa es cuando abro el capo y empiezo a ver los niveles, anticogelante ni lo tocaron, flitro no lo cambiaron y encima lo pusieron mal estaba negro como lo c*** de un grillo, liquido de freno ni lo tocaron, con las mismas a discutir toco. la ultima revision que le e echo yo comprando todo flitros, aceite en el repuesto del barrio 90 euro.
  5. Perdona por la tardanza Berlines, tecuento el aleron lo compre por ebay me salio a 150 puesto en casa y con el mismo color de la carroceria, Guille siempre andaba con que lo tenia que enmansilla, pues aprovechando que tenia que pintar el coche se lo comente al pintor y que cuanyo me llevaba por hacermelo y como pagaba el seguro me digo que nada que gratis que ya le habia metido buen palo al seguro . creo que no tiene que ser nada dificil hacerlo mucha paciencia y un buen lijado despues, y dando masilla poco a poco tampoco es mucho trabajo si se hace despacio y con buena letra, si quereis alguna foto mas me lo decir y las pongo, y otra vez mil disculpas berlines por la tradanza en la contestacion
  6. asi e dejado yo el mio tres piezas enmansillado a la carroceria
  7. Ya se lo que voy a pedir para mi cumpleaños jajajajajajajaj, los de fondo negro para mi coche viene ni que pintados
  8. PLATHY
    spoiler
    Los que tenemos que hacer para septiembre es quedar el coslada city y echarnos unas cervecitas, que no se te ve el pelo joia que andas siempre liao
  9. PLATHY
    spoiler
  10. PLATHY
    spoiler
    haber si sale la foto, asi es como queda ya enmansillado
  11. PLATHY
    spoiler
    esto es lo unico que encontrado de donde lo compre haber si os puede servir cgi/ebay.es/peint-pour, es una tienda en francia pero te lo mando los chinos a casa
  12. PLATHY
    spoiler
    es llegar y poner viene con dos piras por pieza quitas el precinto y pegar al coche nada mas, haber si encuentro la paguina y os la pongo.
  13. PLATHY
    spoiler
    vega mira por las fotos de mi coche hay veras el mio tres piezas RS enmansillado, no se ahora en que paguina lo compre, te lo mandan pintado del color de tu coche y me salio por unas 150 euro.
  14. buenas yo tengo el mismo modelo de coche que tu con la mismo motorizacion y llevo 670000km y sin problemas el coche acaba de hacer ahora los 6 años, de vez en cuando echo un vistazo a las correas y te puedo decir que estan como el primer dia, en el libro pone a los 120000km pero yo no soy partidario de esperar a tantos kilometros, pero a los 90000 o 100000 si que seria conveniente cambiarla tanto correa como bomba de agua, no te preocupes y a disfrutar del coche que aun le queda para la distribuccion. un saludo.
  15. Buenas no soy muy entendido del tema pero lo que tu dices solo con los equipos que monta audi, cuando monte el mio me digeron que siendo otra marca tambien se podia pero que me fuera preparando el bolsillo con lo que costaba.
  16. Buenas Piedra, cpmp has leido yo tambien tengo el mismo problema con la tarjeta del cambio, yo llevo asi con el un par de meses, me podrias decir algun sintoma de que este dañando el cambio, que no entre marcha atras o se quede en una marcha que es lo que por el foro se comenta, te hizo a ti alguno de estos sintomas. muchas gracias de antemano, pero me has dejado acojonado lo que cuenta el cambio .
  17. supongo que llevas cambio multitronic, siento mucho decirte esto pero tienes la tarjeta del cambio rota, supongo que andaras por los 60000 70000 puedes seguir asi yo llevo ya dos meses el problema se agraba mas y cuando no entra la marcha atras o se queda en una marcha y no cambia, lo mejor al taller contra antes eso si 1500 euros la reparacion. un saludo
  18. PLATHY
    vag en madrid
    Waje te necesito si controlas el vag tengo que quitar la alarma de airba y de frenos tu sabes hacerlo me voy a comprar esta semana el vag pero me da miedo liarme con el sin saber, tengo que pasar la itv la semana que viene y tengo que quitarselos
  19. ojala fuera Ojala fuera otra cosa sin importancia pero son los sintomas de la unidad de control del cambio ami me pasa lo mismo llevo asi ya varios meses.
  20. Tienes todos los síntomas de ser la unidad de control de cambio, es el fallo del cambio multitronit, preparación de la unidad 1500euros , yo estoy haber si la cambio el mes que viene,hay dias que fallara y otros no lo peor es cuando no entre la marcha atrás o se que en una velocidad, hay que tener cuidado y no dejar llegar a ese punto sino tocaría caja de cambio
  21. Pues asi es como se hace yo personalmente nunca lo e abierto pero todo el mundo los abre asi poco a poco y con paciencia que ya veras como logras abrirlos
  22. No como bien dice el compañero una pistola mejor que el horno y se abre, despues lo mismo calor y se queda como nuevo, sin problema que es fácil ya veras eso aqui los companero lo tienen mas que logrado
  23. Waje si quieres te dejo la mia de repuestos y ya con la tuya son dos put*da seria pinchar, pero quien dijo miedo llevando un Audi jajajajaj
  24. Muchas gracias por vuestros comentarios, el tema de la roscada era la sorpresa que tenia preparada para Talavera pero la cosa se a torcido ya que se me esta empezando a estropear la centralita del cambio y es una averia que no se puede dejar que valla a mas, asi que primero es lo primero aunque espero acabar el año con la roscada ya montada tenia pensado una kW V2. Entre como veo el coche ahora recien pintado y vuestros comentarios estoy que no entro en el coche jajajajajaj, Muchas Gracias de nuevo compañeros.
  25. El alerón miralo por eBay haber si encuentro el sitio fueron 150 creo le das el código de color y te lo mandan ya pintado con el color exacto
