hola buenas amigos alguien sabe lo que significa estos fallos gracias por su atencion un saludo
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 C
Component: 1,8L R4/5V MOTR HS D06
Coding: 04001
Shop #: WSC 00000
3 Faults Found:
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 8 ö8D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 C
Component: B5-KOMBIINSTRUMENT D03
Coding: 00142
Shop #: WSC 19411
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0S2296688 D76
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
End -------------------------------------------------------
