lucachd
997 visitas al perfil
Logros de lucachd
Explorador
Explorador (4/14)
  1. Hello my friend! I'm Luca and i have an audi A5 3.0tdi stronic quattro my 2014 optional: - H&R -90mm - Ceramic brake 400x38mm front - Ceramic brake 370mm rear - Recaro sitze and much more
  2. I have control with the program: this 1K0 907 530 AD is GATEWAY on VCDS is 17 (right?) this 8P0 907 279 K is BORDNETZ on VCDS is 09
  3. Do you want change the bordnetz right? for exemple codified the headlight, menù comfort, AFS 'fendinebbia' or other right? if yes you must buy the BORDNETZ 8P0 907 279 K 1K0 is for gateway or bordnetz VW not audi. ;-)
  4. Hello! I have change the "bordnetz" in italian "rete di bordo" 17byte to 23 byte (F) (the first change) to 30byte (K) last change. is not difficult to change. don't warry. you must remove the connector + of the battery (or -) and change che bordnetz. after you connect the connector of battery and with VAG or VCDS you copy the 'long coding' old on this new bordnetz. if you have error on CDB control all the byte if are right or wrong. because if you buy the bordnetz used is already codified and some bit you must change. sorry for my english.
  5. hello! new photos with my friend! BIXENON MOD. A6 VS BIXENON MOD. RS6 front and back brake: audi rs5 NEW 365mm 8pistons made on 27/5/2010!! back: 312mm audi tts and I want install the new TACHO: (I have just buyed ;-) )
  6. hola! gracias a todos! asientos RS4 cabrio! ;-) asientos S3 no eléctricos, Estos son: electricidad, calefacción, colchones de aire se infla con! LOVE!!
  7. new fotos!
  8. muchas gracias! Los encuentro en ebay, si usted señala la
  9. No entendí .... con 225 también. son el límite ... con 235 hombro fue 85mm... 225: 78mm + bajo + remolcador!
  10. Yo había visto a esas redes ya realizados en ebay ..... Tengo que ver si hay más ....
  11. c***, pues yo es precisamente lo primero que quitaría del coche de Luca, y detrás iban los retrovisores. Los cromados para la jabonera de la ducha s2, g. es como comparar mi Audi a un excusado!!! medidas: 225/35 r19 con 8,5x19 et 43 original ;-) Los próximos cambios: asientos recaro RS4 cabrio (bucket seats)
  12. news: 19'' rs6!
  13. Éste clima es como el de luca, el italiano de los leds de RS6, no? por no decir que es el suyo, porque también creo que tenía iluminación en blanco y los botones del MMI ahí incrustaos (que quedan de miedo, he de decir, lo que no sé es cómo irán) saludos, g. Es que casi seguro que es el clima de lucachd (el italiano), ya que el tambien lleva los triangulos tapizados con costuras en blanco, y mucha casualidad que hayan dos personas con el mismo clima modificado y los mismos triangulos tapizados El caso seria preguntarle el porque lo vende. este es mi Clima! Lo cambié por uno nuevo que los asientos con calefacción. ;-)
  14. klimatronic 2 din MMI 120557349790
