raulorenzo
Inactivo
Todo lo publicado por raulorenzo
  1. raulorenzo
    PROBLEMAS SERIOS.
    se me olvido indicaros que indico en el cuentakilometros error en gestor de carga. y no por ello la menos grave de todas al arrancar suena los empujadores hidraulicos de las valvulas del lado derecho.
  2. raulorenzo
    PROBLEMAS SERIOS.
    VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 Data version: 20130910 www.Ross-Tech.com Dealer/Shop Name: Workshop Code: 000 00000 000000 Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 VIN: WAUZZZ4E14N005334 License Plate: Mileage: 349690km-217287mi Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 37 38 42 46 47 4F 52 53 55 56 61 62 69 72 76 77 VIN: WAUZZZ4E14N005334 Mileage: 349690km/217287miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- No fault code found. Readiness: 0 0 X X X No fault code found. Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 2 VIN: WAUZZZ4E14N005334 License Plate: Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGMª0020 Revision: <> Serial number: AUX3Z0C4116844 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 -------------------------------------------------------------------------------Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 J HW: 09E 927 156 A Component: AG6 09E 4,0LTDI RdW 0010 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 29591B2F800CF956E3D-807C -------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 A Component: ESP 5.7 allrad H29 0420 Coding: 0008557 Shop #: WSC 00033 000 00000 VCID: 2149030FF83C3116BBD-8074 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - -------------------------------------------------------------------------------Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H02 0120 Revision: 01203602 Serial number: AUX3Z0C4116844 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D ------------------------------------------------------------------------------- Subsystem 1 - Part No: 4E0 910 609 Component: Bedienteil MMI H41 0010 Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Time Indication: 15 VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 3 VIN: WAUZZZ4E14N005334 License Plate: Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 P HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 343FQ037517663 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 3979CB6F70AC49D693D-806C Subsystem 2 - Serial number: 301F2037521020 Subsystem 3 - Serial number: ÿÿ26.06.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ 2 Faults Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 161 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 00:42:48 ------------------------------------------------------------------------------- Freeze Frame: Voltage: 12.30 V VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 4 VIN: WAUZZZ4E14N005334 License Plate: Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 015 0240 Revision: 00000017 Serial number: 00000000019814 Coding: 1316881 Shop #: WSC 02311 785 00200 VCID: DABBF4E315EA22CE3A7-808F 1 Fault Found: 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 9 Reset counter: 202 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 01:23:24 ------------------------------------------------------------------------------- 2 Faults Found: 02601 - Drivers Side Footwell Light (W9) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 164 Mileage: 349690 km Time Indication: 0 Date: 2003.02.27 Time: 00:00:38 No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 5 Subsystem 1 - Part No: 4E1 910 113 B Component: Wischer WWS D3 H50 0400 Coding: 00000030 Shop #: WSC 02311 VIN: WAUZZZ4E14N005334 License Plate: Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0010001 Shop #: WSC 02311 785 00200 VCID: 2A5BE423850AF24EEA7-807F 02602 - Passenger Side Footwell Light (W10) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 164 Mileage: 349690 km Time Indication: 0 Date: 2003.02.27 Time: 00:00:38 -------------------------------------------------------------------------------Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGSª0020 Revision: <> Serial number: AUX3Z0C4116844 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 23450907E2202306A91-8076 ------------------------------------------------------------------------------- No fault code found. Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 No fault code found. 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 204 Mileage: 349690 km Time Indication: 0 Date: 2003.02.27 Time: 00:00:40 VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 6 VIN: WAUZZZ4E14N005334 License Plate: Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H09 0940 Coding: 0430707 Shop #: WSC 02313 785 00200 VCID: E3C5C90722A0E306691-80B6 -------------------------------------------------------------------------------Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H09 0030 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: E5C1D71F2C949D36875-80B0 -------------------------------------------------------------------------------Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 900 F Component: KOMBIINSTR. VDO H42 0070 Revision: D08 Serial number: AUDID3C5001731 Coding: 0000103 Shop #: WSC 23875 000 1048576 VCID: DCB7F2FB1FDEDCFE28B-8089 ------------------------------------------------------------------------------- No fault code found. No fault code found. No fault code found. Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 7 VIN: WAUZZZ4E14N005334 License Plate: Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 HW: 4E0 815 069 D Component: Heizgeraet H06 0290 Revision: 0000000F Serial number: 00000009001484 Shop #: WSC 00000 000 00000 VCID: D9B9EBEF10EC29D633D-808C -------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0050 Revision: 07 Serial number: 13003036110BCD Coding: FDFEFFC62B3104 Shop #: WSC 25077 000 1048576 VCID: E5C1D71F2C949D36875-80B0 -------------------------------------------------------------------------------Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B55E1274AF0EB46111-807E -------------------------------------------------------------------------------Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H02 0120 Revision: 01203602 Serial number: AUX3Z0C4116844 Coding: 0262144 Shop #: WSC 02311 785 00200 VCID: D8BFEEEB6BE630DE0C3-808D ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 8 VIN: WAUZZZ4E14N005334 License Plate: Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 Component: KLIMA-STG. FOND 015 0200 Revision: 00000012 Serial number: 00000000008040 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: E1C9C30F38BCF1167BD-80B4 1 Fault Found: 01866 - Rear Right Air Outlet Motor Position Sensor (G350) 010 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- 4 Faults Found: 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 165 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 00:44:31 VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 9 VIN: WAUZZZ4E14N005334 License Plate: Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015520 Shop #: WSC 02313 785 00200 VCID: 2541171FEC14DD36C75-8070 01437 - Control Position not Learned 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 161 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 00:44:31 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 7 Reset counter: 168 Mileage: 349673 km Time Indication: 0 Date: 2003.02.27 Time: 01:29:19 01397 - Venting Solenoid for Level Control (N111) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 168 Mileage: 0 km Time Indication: 0 VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 10 VIN: WAUZZZ4E14N005334 License Plate: ------------------------------------------------------------------------------- 3 Faults Found: 02261 - Data Medium 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 7 Fault Frequency: 15 Reset counter: 164 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 00:44:43 Freeze Frame: Hex Value: 0x3E5D Hex Value: 0x5534 Hex Value: 0x0000 Hex Value: 0x1144 03183 - Data Media not Compatible 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 36 Reset counter: 165 Mileage: 349672 km Time Indication: 0 Date: 2003.02.27 Time: 01:23:01 Freeze Frame: Hex Value: 0x3E5D Hex Value: 0x5DC3 Hex Value: 0x0000 Hex Value: 0x9494 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 37 Reset counter: 205 Mileage: 349672 km VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 11 VIN: WAUZZZ4E14N005334 License Plate: Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H41 1060 Revision: 00000000 Serial number: 305FQ037536097 Shop #: WSC 02313 785 00200 VCID: 3B75D1677A907BC6811-806E Time Indication: 0 Date: 2003.02.27 Time: 00:44:41 Freeze Frame: Hex Value: 0x3E5D Hex Value: 0x5D0B Hex Value: 0x04FF Hex Value: 0x0000 No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:25:62939 Page 12 VIN: WAUZZZ4E14N005334 License Plate: -------------------------------------------------------------------------------Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0080 Serial number: 00000316000056 Coding: 0003072 Shop #: WSC 02313 785 00200 VCID: 1D313FFFC44415F69F5-8048 1 Fault Found: 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 164 Mileage: 262136 km Time Indication: 0 Date: 2003.02.27 Time: 00:00:00 -------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM005 0100 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: DEB3F8F309C2CEEE46F-808B ------------------------------------------------------------------------------- Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 2 Faults Found: 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 180 Reset counter: 164 Mileage: 347949 km Time Indication: 0 Date: 2020.06.30 Time: 15:22:55 No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:26:62939 Page 13 VIN: WAUZZZ4E14N005334 License Plate: Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040306300018 Coding: 0000088 Shop #: WSC 02311 785 00200 VCID: 275D1D179618CF26F59-8072 01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 204 Mileage: 349690 km Time Indication: 0 Date: 2003.02.27 Time: 00:54:32 -------------------------------------------------------------------------------Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 L HW: 4E0 035 223 Component: Amp.-Basis H42 0290 Revision: 00000000 Serial number: 00000037515494 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 264310139112D62ECEF-8073 ------------------------------------------------------------------------------- No fault code found. No fault code found. No fault code found. No Faults Found or DTCs not supported by controller or a communication error occurred No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:26:62939 Page 14 VIN: WAUZZZ4E14N005334 License Plate: Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 HW: 4E0 907 280 A Component: ILM Beifahrer H07 0070 Revision: Serial number: 00000000017539 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: DDB1FFFF04C4D5F65F5-8088 -------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM005 0100 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: DEB3F8F309C2CEEE46F-808B -------------------------------------------------------------------------------Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000431 Shop #: WSC 00033 572 88584 VCID: 1D313FFFC44415F69F5-8048 -------------------------------------------------------------------------------Address 55: Xenon Range Labels: None VCID: 55A167DFBCF48DB6975-8000 -------------------------------------------------------------------------------Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304FI037535640 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3169F34FA8DC81962BD-8064 ------------------------------------------------------------------------------- No fault code found. No fault code found. No fault code found. No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:26:62939 Page 15 VIN: WAUZZZ4E14N005334 License Plate: Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0160 Revision: 00000000 Serial number: 00000000009124 Shop #: WSC 00000 000 00000 VCID: DDB1FFFF04C4D5F65F5-8088 Subsystem 1 - Part No: 000 915 105 DL Component: von VA0 3607011320 Coding: 303030393135313035444C56413033363037303131333230 Shop #: WSC 00033 572 88584 -------------------------------------------------------------------------------Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0090 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: DDB1FFFF04C4D5F65F5-8088 -------------------------------------------------------------------------------Address 69: Trailer Labels: 4E0-910-383.lbl Part No SW: 4E0 910 383 A HW: 4E0 907 383 A Component: ANHAENGERELEKTR H01 0010 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 224B0C03FD3A2A0EA27-8077 -------------------------------------------------------------------------------Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0090 Coding: 0003872 Shop #: WSC 02311 785 00200 VCID: DDB1FFFF04C4D5F65F5-8088 ------------------------------------------------------------------------------- No fault code found. No fault code found. VCDS Self-Diagnosis Log Friday,31,July,2020,23:05:26:62939 Page 16 VIN: WAUZZZ4E14N005334 License Plate: Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0011008 Shop #: WSC 02313 785 00200 VCID: E0CFC60B33B6F81E743-80B5 -------------------------------------------------------------------------------Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 B Component: TELEFONMODUL EU 0770 Revision: 00000001 Serial number: 00000000000000 Coding: 0000004 Shop #: WSC 00000 000 00000 VCID: 224B0C03FD3A2A0EA27-8077 End ---------------------------------------------------------------------
  3. raulorenzo
    PROBLEMAS SERIOS.
    Como bien define el titulo de este post, esto va en serio…. Recientemente adquirí un a8 4.0 tdi año 2003 y creo que encontré el que más problemas tenía: Paso a detallaros los problemas que me he encontrado en 7 meses que lo tengo y tras 3000 km. El primero y como era de esperar la batería ko ya me lo comento el vendedor que estaba en las ultimas los primeros 165€. Varta 110ah. Codificada con éxito. Le pase el vagcom 12 y encontré diversos problemas como: El pulsador del pedal del freno para las luces. El botón de los espejos. Dvd ko (planteándome si lo compro o no) Consumo de batería que no consigo localizar, dejando el coche por la noche con un 70% y encontrarlo a 50% a la mañana siguiente. Problema pulsador cerradura conductor no enciende las luces al abrir ni indica que la puerta está abierta. Tarea pendiente. Ventana copiloto con grillos al abrir o cerrar. Tarea pendiente Quitaron el cargador de Cd e instalaron ami (sonido con un pendrive) Teléfono no está solo tengo la base. Si crees que es suficiente te equivocas aun hay más. Realice un viaje el fin de semana pasado de 1000km y Salí con un 40% de batería lo normal es que en un viaje de ida y vuelta se cargara al 100% pero no fue así solo llego al 80 % lo primero que podemos pensar es que la batería no admite la carga que debería o que el alternador no de el voltaje correcto. Nada más lejos de la realidad si el coche lo dejo arrancado media hora o una hora máximo la carga llega al 100% ¿Como esto puede ser posible? Para colmo de males falla la suspensión estos días. Los 2 chivatos encendidos tras pillar un bache normalito pero se queda en la segunda posición y tras 24 horas parado no baja ningún lado del vehículo pero no deja cambiar de posición. A los 2 días se puso en automático y sorpresa morro al suelo. He cambiado el segmento del compresor y limpiado interiormente la misma válvula n111 incluida. Tras darle muchas vueltas y tras probar con 2 maquinas distintas no deja borrar los errores y aparece el fallo de regulador luces. Con el vag com puedo borrar los fallos pero si vuelves a entrar ay están de nuevo. El compresor arranca y manda aire a la caja de válvulas, pero solo la parte trasera coge una altura de 74 mientras la delantera 64 aprox. He probado a meterle presión a los amortiguadores con un mini compresor desde la caja de válvulas y mantienen la presión sin perderla. Pero el compresor no arranca a no ser que lo fuerces con el programa. Posibles causas algún nivelador de altura y por eso no da orden al compresor o caja de válvulas mal y por eso indica error de la n111. (Cuando el compresor si funciona si lo pides con el programa) Se enciende el testigo de la dirección pero se borra si circulas 10 metros con él. Y no vuelve a aparecer. Indica 2 luces de los pies mal por ponerle a todo el coche led (posibles bombillas defectuosas creo) Y problema regulador de trampillas aire traseras, pendientes de revisar. Os subo un log de todos los errores que ha dado el coche Y solicito a todos los que entren en este post que si conocen a alguien que pueda echarme un cable le pasen un mensaje en forma de solicitud desesperada de ayuda.
  4. es una de las normas no escritas en los foros. si te ayudan intenta explicar con detalle cualquier paso que no este en la explicacion o en la ayuda prestada. al igual de uso obligatorio una vez reparado el problema explicar cual era y los diferentes pasos que has dado. asi se van completando las soluciones a problemas que nos van surguiendo. quiza asi la proxima vez encuentres directamente solucion a tu problema
  5. esta en aleman pero tienes la opcion de traducirlo al castellano
  6. haber si con esto lo solucionamos
  7. comparto con vosotros los errores que me da mi coche, (no puedo subir fotos) tambien quisiera comentaros que se ha quedado la suspension en dinamic y lleva 2 dias parado el coche y la altura de todas las ruedas es similar 68cm (desde el suelo a lo mas alto de la aleta) no ha bajado en estos 2 dias. he realizado el test y el compresor funciona pero no sube ningun lado ni se escucha silvido alguno en ninguna rueda. tras varios intentos da el error 1577 de exceso de temperatura. 3 1042 66 565 1866 1577 1400 1583 2261 3183 2927 1134 1565 1134 526 RESULTADO TEST front left -62mm 4.5 bar front right -49mm 4.56 bar vehicle is being leveled -62 mm -49 mm -41 mm -35 mm rear left -41 mm 4.56bar rear right -35mm 4.56 bar pressure accumulator being tested 4.56 bar he visto que muchos ponen un listado del vag com pero no se como se saca el listado para compartirlo
  8. podrias indicar como se vacia el sistema de aire para los no iniciados..jj
  9. puedes decirnos cual de los dos es cada uno ya que las fotos no se ven y vienen identificadas con numeros no con letras ni colores
  10. me sigue apareciendo este error 2596 implausible signal 008 ya abri y cerre las pastillas tambien le puse el tamaño de las pastillas comprobe configuracion alguna pista.
  11. necesitaria el codigo para mi coche a8 d3 año 2003 es una varta 110ah con 920 para arranque.
  12. he montado esta misma bateria pero no tengo el codigo puedes pasarmelo
  13. raulorenzo
    Vag-com a8
    estaria muy bien asi los nuevos poseedores podrian activar nuevas cositas
  14. es posible que asi sea.............pero lo desconozco porque ya lo havian desmontado anteriormente a mi adquisicion para cambiar la botonera de las ventanas, al igual que faltaban un par de grapas que imagino se les romperian anteriormente.
  15. ya consegui desmontarla. los videos que e encontrado son todos de un a6 para desmontar el panel de la puerta del a8 ay que quitar la moldura de la madera que sale levantado desde la parte del retrovisor hasta la cerradura atras del todo lleva unas pestañas que saldria la moldura hacia delante. cuidado no romperlas. ay se encuentra un tornillo de cabeza de 8mm. una vez quitado lleva tetones de plastico a presion por todo el perimetro de la puerta levantar desde una esquina de la parte de abajo haciendo palanca con un destornillador y ya sale completa. consegui solucionar 2 problemas cambiar selector espejos retrovisores y reparar guantera poniendo un tornillo y tuerca desde la guantera hasta el resorte del muelle, apenas se aprecia el tornillo y se soluciona el problema. eso si colmaros de paciencia y un par de bridas de plastico para su posterior montaje de los 40 tornillos que hay que quitar.
  16. buenos dias a todos. estoy intentando desmontar el panel de la puerta delantera izquierda. pero soy incapaz de saber como se desmonta el dichoso panel. alguien podria ilustrarme. prometo subir fotos del proceso para cambiar interruptor espejos y cambio altavoz.
  17. tengo los siguientes errores adress 5 acc/start auth 00171 intermitente adress 08 auto hvac 66 intermitente 65 intermitente adress 11 engine II 17426 intermitente adress 15 airbag 591 intermitente adress 19 can gateway 1207 intermitente adress 25 inmovilizer 171 intermitente adress 34 level control 1772 intermitente adress 37 navigation 2261 data medium 014 defective 2927 dvd rear error 000 intermitente 3183 data media no compatible adress 38 roof electronic 2141 control circuit for front right makeup mirror light 012 adress 53 parking brake 02596 rear brake pads worn 008 implausible
  18. todavia andamos en ello. tengo los siguientes errores adress 5 acc/start auth 00171 intermitente adress 08 auto hvac 66 intermitente 65 intermitente adress 11 engine II 17426 intermitente adress 15 airbag 591 intermitente adress 19 can gateway 1207 intermitente adress 25 inmovilizer 171 intermitente adress 34 level control 1772 intermitente adress 37 navigation 2261 data medium 014 defective 2927 dvd rear error 000 intermitente 3183 data media no compatible adress 38 roof electronic 2141 control circuit for front right makeup mirror light 012 adress 53 parking brake 02596 rear brake pads worn 008 implausible
  19. corrigo lo dicho anteriormente si me deja entrar en el modulo muchas gracias por la info.
  20. en busca de gurus de vagcom encontre estos errores 2596 2273 2261 3183 2927 3 por lo que he visto tengo la ultima version del mmi y mi coche salio de la casa con cd pero ahora no lo tiene y si tiene audi sistem interface es posible que instalaran mal la actualizacion y dejara inabilitado el dvd y por eso saldrian esos errores tengo el cd original pero no lectora de cd el dvd no lo reconoce como podria solucionarlo
  21. en busca de gurus de vagcom encontre estos errores 2596 2273 2261 3183 2927 3 por lo que he visto tengo la ultima version del mmi y mi coche salio de la casa con cd pero ahora no lo tiene y si tiene audi sistem interface es posible que instalaran mal la actualizacion y dejara inabilitado el dvd y por eso saldrian esos errores nota obtenidas por este post como lo soluciono si no tengo lector de cd tengo el disco original
  22. pues como no sea la factura de compra del vehiculo usado....jjjj ya venia con ese fallo.
  23. Que tenis planeado en fabrero no he visto nada de quedadas
  24. puentes de la fibra optica. para descartar errores. o si eliminas un componente cierras el circuito de fibra optica.
  25. ya tengo dos frentes abiertos el a3 que pronto pondre algun otro post. y este del a8. que ya tengo unas cuantas peticiones de ayudaaaaa aqui os dejo unas fotitos de las ultimas compras que tenia que hacerle para ponerlo a punto.
