templario88
Todo lo publicado por templario88
  1. No tengo manos libres, multifuncion si he borrado fallos y he vuelto hacer el scan y me salen los siguientes errores Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 3400K094160B4C Coding: E9801F06500202000100 Shop #: WSC 06314 000 00000 VCID: 37762982791792A4 3 Faults Found 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 9 Reset counter: 36 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:05:17 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:15:27 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 74 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:15:27 Address 56: Radio Labels: None Part No SW: 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU EU H06 0220 Revision: 0000012S Serial number: AUZBZ7LD220322 Coding: 0205755 Shop #: WSC 10935 000 10485 VCID: 346C1E8E686179BC 2 Faults Found 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:06:30 Freeze Frame: Mileage: 75550 km Count: 1902 Clock: 21:06 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 75551 km Time Indication: 0 Date: 2013.02.19 Time: 21:06:24 los que estan en negro los doy por normales pero los rojos no entiendes porque me aprecen en el modulo 17 intruments channel 62 es posible que no lo tenga o deveria de aparecer siempre?
  2. si eso de los amplificadores de la radio lo se y bueno el conector de la antena GPS tampoco le doy importancia el GPS va bien lo que lo he conectado y desconectado 1000 veces y por eso saldra el fallo igual que el del micro que micro no tengo pero me marca un fallo
  3. Me aparecen los siguientes errores a ver si alguien con eso sabe por donde puedo buscar.. Address 37: Navigation Labels: None Part No SW: 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU EU H06 0220 Revision: 0000012S Serial number: AUZBZ7LD220322 Coding: 0205755 Shop #: WSC 10935 000 10485 VCID: 346C1E8E686179BC 9 Faults Found 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:25:29 Freeze Frame: Mileage: 655350 km Count: 65535 Clock: 255:255 00856 - Radio Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:44:10 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 3 Reset counter: 30 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:53:31 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 18:44:10 Freeze Frame: Mileage: 75430 km Count: 1702 Clock: 00:00 00878 - Connection to Speaker Front Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 2 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 20:13:54 00879 - Connection to Speaker Front Right 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 20:13:54 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Time Indication: 0 Date: 2013.02.17 Time: 13:20:59 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 30 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:53:25 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 70 Time Indication: 0 Date: 2013.02.17 Time: 13:21:15 Freeze Frame: Bin. Bits: 10111011 Bin. Bits: 10 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 S HW: 1K0 907 951 Component: J533__Gateway H16 0210 Revision: H16 Serial number: 3400K094160B4C Coding: E9801F06500202000100 Shop #: WSC 06314 000 00000 VCID: 37762982791792A4 4 Faults Found 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 154 Reset counter: 33 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 16:52:16 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 23 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 17:00:06 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 31 Reset counter: 72 Mileage: 75437 km Time Indication: 0 Date: 2013.02.16 Time: 17:00:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG Component: KlimavollautomatH09 0100 Revision: 000420 Serial number: 8P0820043BG Shop #: WSC 00000 000 00000 VCID: 72E0D89652F5378C 1 Fault Found 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 70 Mileage: 75438 km Time Indication: 0 Freeze Frame: Voltage: 8.30 V el primero de la CAN Gateway ya me salia creo que desde que compre el coche asi que yo creo que ese lo descartaria
  4. no hay manera de configurar el RNS-E me da fallos al hacer un scan y no me entra en adaptation instruments para configurar
  5. no, es un A3 restyling
  6. sabrias decirme la referencia de la getway? lo que mas me mosquea esque no me deja configurar el RNS-E desde vagcom por mucho que intento no puedo tu pudiste configuralo bien?
  7. no soy de barna pero estoy bastante cerca a unos 50km lo que tampoco entiendo es que no me detecta el RNS-E me sale fallo pero si me deja entrar en el modulo 37
  8. la verdad que no estoy muy seguro de si esta bien condificado el RNS-E no encuentro mucha informacion sobre eso en pricpio es en el modulo 37 y ya esta no? la bateria aun no tenia ni 4 años es la de origen por eso, pero bastante seguro que es el RNS-e ya que mucha casulidad que lo monto hace 2 dias y me quedo sin bateria justo cuando no uso el coche, ademas cuando cierro el coche el RNS-e se apago pero creo que se queda en modo stanby porque con el coche parado puedo encenderlo cosa que con la concert III no podia
  9. del 2009 y el rns-e del 2012.
  10. he entrado en el modulo 37 no me aparece el globito pero esta codificado correctamente, en otro foro tambien he visto eso de cambiar la getway pero he leido que alguien con un a3 lo ha hecho y nada sigue igual. lo de los conectores que dices de 192 no se a que te refieres he mirado los conectores del RNS-E y parece estar todo bien
  11. te refieres a codificar el RNS-E? si es asi desde donde se condifica ?
  12. Hola beunas tardes Hace unos dias compre una radio RNS-E de las nuevas la instale y todo bien las indicaciones en FIS funciona bien pero hoy he ido arrancar el coche y no tenia bateria.. intentado configurarla bien por vag en el modulo 37 me entra pero no me aparece el globo con la info de los codigos He visto por el foro varias cosas que se pueden hacer pero no se cual es la correcta uno decia que cortando el pin 16 lo he hecho y nada la radio sigue encendidose cuando esta el coche parado.. otros dicen que cambiando la centralita getway tambien he visto que cortado en cable mute eso no lo he probado pero no tiene mucho sentido Alguien sabe la solucion para que no descargue la bateria y pueda configudar con vag ?? gracias!
  13. es la bateria, el RNS-E me la chupado toda ni con pinzas he conseguido arrancar el coche la tenia a 9V.. he tenido que comprar una nueva y arrancado a la primera mi coche es del 2009 retyling no he configurado aun nada por el vag mirare a ver que pasa
  14. Hola buenos dias necesitaria ayuda Hoy estaba en el coche lo he ido arrancar y no arranca suena como a un rele o algo un tacataca.. la intensidad de las luces del climas fis y todo es mas debil he deducido que seria la bateria lo que intento arrancar con las pinzas con otro coche y aun asi sigue haciendo lo mismo la mirilla de la baeria que te dice esta muerta o no esta en rojo en pricipio es en amarillo que es cuando esta muerta a ver si alguien podria encharme una mano no se que hacer.. gracias edito para decir que hace un par de dias puse el RNS-E el nuevo modelo se que habia algun modelo que decarga la bateria pero no se si es este o que..
  15. En norauto por ejemplo? Si yo las compre en norauto viene un pack de 5 o 6 llaves de mas pequeña a mas grande creo que unos 12€
  16. Si en pricipio si miras un poco entre el plastico y si lleva las 2 patillas esque deveria de llevar un fusible, si ves que solo lleva la patilla de abajo o solo la de arriba esque ahi no va niguno ya que la pieza metalica que viene de la bateria hace puente para alimentar otras no se si me explicado bien saludos
  17. muy bonito el coche! por cierto la ultima foto da la sensacion que lleves un super aleron por el coche de atras :lmfao:
  18. yo no cambie ruleta solo los espejos, prueba perimero cambiar espejos o codificar con vag a ver si los intermitentes siguen funcionado saludos
  19. toma aqui el brico http://www.autobild....de-aparcamiento no son los sensores oem pero mas o menos
  20. la corriente yo la cogi de la luz de la marcha atras, para desmontar el tapizado es un tornillo torx que esta en la rejilla del plastico y luego estirar el resto de las grapas
  21. Yo uso el 5-30 edge recomendado por audi y castrol es el loglife y para el DPF que el mio lo lleva. El professional no se que diferencia tendra pero si tiene DPF el coche tiene que llevar aceite con normativa 507 o algo asi que hace menos ceniza que los demas en la pagina de castrol te dice que aceite tiene que llevar tu coche aqui
  22. Precioso! feliz año y que montes muchas mods mas
  23. templario88
    codigo elsawin4.0
    Hola buenos dias Me baje elsawin 4.0 pero no encuentro el numero de serie alguien podria decirme cual es?? gracias!
  24. no se que are no me esperaba que fuera tanta cosa lo que me echa para atras son los muelles y amortiguadores, esto tiene que cosatar encontrarlo y que esten en buen estado..
