PMorales
Todo lo publicado por PMorales
  1. Bueno, este ha sido el primer autoscan desde verano del aaño pasado: VCDS Version: Release 10.6.4 (x64) Data version: 20110418 Friday,04,May,2012,19:37:27:10074 Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 182140km/113176miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 058-907-557-ADR.lbl Part No: 8D0 907 557 C Component: 1,8L R4/5V MOTR HS D08 Coding: 04001 Shop #: WSC 00000 VCID: 306B14F3DAB3 1 Fault Found: 00561 - Mixture Adaptation 15-10 - Adaptation Limit (Add) Not Reached - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl Part No: 4D0 907 379 D Component: ABS BOSCH 5 7402 Shop #: BB 37402 VCID: 2F69178FC78D No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 8D0 820 043 H Component: A4-KLIMAVOLLAUTOMAT_D65 Coding: 00040 Shop #: WSC 06315 VCID: 2545F5A79571 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8A0-959-655.lbl Part No: 8A0 959 655 B Component: Airbag V AUDI D00 Coding: 00766 Shop #: WSC 06315 VCID: 326F1EFBD4BF 1 Fault Found: 01025 - Trigger for On Board Diagnostic Lamp; Malfunction 31-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-919-0xx-17.lbl Part No: 8D0 919 033 P Component: B5-KOMBIINSTRUMENT__D11 Coding: 00142 Shop #: WSC 00001 VCID: 356525E725D1 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Part No: 4A0 953 234 Component: IMMO AUZ9Z0T0637947 D76 Coding: 00000 Shop #: WSC 00000 VCID: DFC9274F77AD 1 Fault Found: 01176 - Key 07-10 - Signal too Low - Intermittent End --------------------------------------------------------------------- Limpio errores y ahora pongo el segundo autoscan.
  2. Colocado en el culete:
  3. Esta tarde iré a hacerle el primer log al coche. Lo pondré aqui los fallos que me dé
  4. Ves? Catalizador o silenciador Pa una que doy en el clavo...
  5. Edu, con perdon pero en la foto no se ve un carajo. Mañana hazle una que de dia se vera mejor
  6. Graaasias hamijo! Unete al club!! Aun no he montado nada porque me he dado cuenta que para poner las luces led es un coñazo desmontar la tulipa. Asi que me espero a tener los leds, ponerselos y luego cerrar la tapa y a correr
  7. Lo de las rpm es posible que sepa de lo que es. Un exforero de aqui tenia el mismo sonido. El decia que era un tubo de escape nuevo pero en una de estas me confesó que tenia el catalizador jodido. Es posible que no veas nada roto ni haya ninguna fuga a nivel exterior, pero a nivel interior puede ser que tengas el catalizador o el silenciador roto. Si pones un video del sonido, te lo puedo decir con claridad
  8. Yo tengo 65 mb de ADSL reales. ................ ¿ es bastante ? Saludos. Yo tengo igual y se me queda pillao a veces. El otro dia le compré un juego a mediafire y en 1 hora y media lo tenia en mi casa... Son rapidos eh! :shocked:
  9. En el volvo S40 de mi padre tambien estan los leds estos. Yo lo noto mucho al entrar en los tuneles o al hacerse de noche. No se ve nada de la palanca de cambios. Sin embargo, en el volvo, cuando vas de noche ves un poco y quieras que no, se agradece.
  10. No es que sea mas pequeño, es que el original lleva un cuadro de metal que le puse. Es una larga historia ya que el sustituto del original fue el de un seat y este lo llevaba. Al yo no necesitarlo en mi coche, se lo puse al original para guardarlo en algun lao. Como comprenderás (ya pondré una foto) el plafon del seat está muy jodido y hay zonas que estan derretidas... Vamos, que esta to pensao y que no me he gastao 50€ a lo loco... Edito: acabo de compararlos porque tampoco lo veia claro y son iguales. Completamente iguales de tamaño
  11. Para el plafon hay que cambiar el conector de la luz. Cuando esté en el ordenador te dejo un brico que encontré en un foro de Seat para poner este plafon. Ademas hay que robar electricidad del fusible de las luces de posicion para que al dar luces, los leds rojos se enciendan.
  12. En ebay costaba con portes y todo entre 54 y 65€ dependiendo del vendedor. En el conce (aparte de tenerlo al dia siguiente) estaba a 53,49€ con bombillas incluidas y todo cosa que el de ebay no lo aseguraba. Asi que me he ido al conce y mas facil...
  13. Ya me ha llegado el plafón del Passat W8: Tengo que decir que los botones se notan hundidos porque lo he abierto para cambiarle las bombillas en LED. El de arriba era el original. Se nota la diferencia? Ah, y esto va para Athabasqueaux y Duke: Me he unido al club de los coches putis Este plafón tiene 2 leds para ambiente (p***o) y para iluminar la zona central.
  14. Como que no? Mira: http://www.ebay.es/sch/i.html?_nkw=audi+sticker+door&_sacat=0&_odkw=audi+sticker&_osacat=0&_trksid=p3286.c0.m270.l1313
  15. Habia quedado mas maricona la excusa de antes :crying_anim: era más bonita... Pero luis tiene razón. Ahora no gasto gasolina. Gasto suelas de zapato.... :crying_anim:
  16. Estoy en el movil. Athabasqueaux: Nop, aun sigo sin seguro. Ya te digo que mi Padre echó 20€ de 95 y cuando acabo el viaje, la aguja estaba en el mismo sitio que antes de rellenar. Luislucena: Solo la pegatina? Venga hombre, que habrá algo mas que te guste del coche Vix: Claro, es que consume menos porque estais todos los del foro empujandome el coche en las cuestas
  17. Valvula de descarga? Que anticuado... Ponle el Ares, que ese si que te descarga!!
  18. El consumo es cuando meto el coche en el garaje y hago maniobras. Eso de acelerar/frenar/ vuelve a acelerar gasta muchisimo. Por lo demas, se hizo el viaje Malaga - Cadiz con 20€ de gasolina. Unos 15/17 litros en 245 km Ya habrá mas fotos, pero ahora mismo estoy esperando dos cositas
  19. Iros a ebay y poned "Audi logo sticker" Hala, un saludo
  20. PMorales
    KIT ASI
    Kit ASI colocado Gracias a Duke
  21. Actualizo esto: El arañazo es un extra. Aunque parezca que está la pegatina doblada, lo medi con una cosa de esas que tienen la burbujita y estaba recto Como veis, el coche tenia m**** y como afuera estaba lloviendo pues... LAVADO GRAHHTIIIHHH!!! Ea, ahi va mi coche con el portamatriculas Dato curioso: Como mi coche no tiene la franja europea con la E, la matricula es un poco más pequeña que el portamatriculas, por lo cual hubo que centrarlo Paradita a mitad de camino para Cádiz Y ya en Cádiz metiendo el coche en el garaje... Creo que me sale un poco caro aparcar, no? :crying_anim: Ah!! y se me olvidaba. MAÑANA O PASAO ME LLEGA EL VAGCOOOOOMM!!!! :roll1: Party hard!!
  22. Ya empezamos como la otra vez............... Eso ya lo sabia yo!
  23. Las fotos del motor, aunque no te lo creas, es una TARTA DE BODAS. Yo me quedo con la tapa de balancines, lo demas pa vosotros Y las otras fotos a las que me referia mas atras, ya las veras
  24. Sata, te aconsejo que no vengas a Andalucia. Podrias acabar gamba marinada
