redfly
713 visitas al perfil
Logros de redfly
Aprendiz
Aprendiz (3/14)
  1. redfly
    Rejilla antiniebla rs4 b7
    Buenas tardes , me han robado la rejilla de la antiniebla derecha del paragolpes rs4 modelo b7 , no la tienen en la audi , me dicen que está descatalogada. Sabéis algún sitio donde podría comprarla? Un saludo
  2. al pasar el vag me sale esto VIN: WAUZZZ8EX6A032276 Mileage: 220140km/136788miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 910 401 K HW: 8E0 907 401 AJ Component: 3.0L V6TDI G000SG 0030 Revision: --H01--- Serial number: Coding: 0011111 Shop #: WSC 06325 000 00000 VCID: 2756F9C2A9B70224 1 Fault Found 005488 - Engine Start Blocked by Immobilizer P1570 - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Time Indication: 0 Freeze Frame: RPM: 882 /min Torque: 206.7 Nm Speed: 0.0 km/h Duty Cycle: 12.0 % Voltage: 11.48 V Bin. Bits: 00001100 Torque: 1035.3 Nm Readiness: 0 0 1 1 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL Component: ESP8 quattro H04 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004425 Shop #: WSC 06435 000 00000 VCID: 2952FFFABFA33454 1 Fault Found 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 40 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0222 Hex Value: 0x0024 Hex Value: 0x018F Hex Value: 0x0001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2831 Coding: 00000 Shop #: WSC 00000 VCID: 69D2BFFA7F23F454 2 Faults Found 01206 - Signal for Duration of Ignition Off Time 27-00 - Implausible Signal 00474 - Control Module for Immobilizer 49-00 - No Communications ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 L Component: int. Lastmodul ECE 0504 Coding: 01021 Shop #: WSC 00000 VCID: 3B7E35B2453FB6C4 1 Fault Found 00474 - Control Module for Immobilizer 49-00 - No Communications ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H11 3530 Revision: 91H1135 Serial number: 0036M005CVD6 Coding: 0034622 Shop #: WSC 06335 000 00000 VCID: 3B7E35B2453FB6C4 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0801 Coding: 02041 Shop #: WSC 06435 VCID: 4182475A27D3DC14 1 Fault Found 00474 - Control Module for Immobilizer 49-00 - No Communications ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H12 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0004141 Shop #: WSC 03565 572 92637 VCID: 2648F4C6AEBD1B2C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CA Component: Komfortgerát T3B 3332 Coding: 07802 Shop #: WSC 06335 VCID: 72E0D89652F5378C Part No: 8E1959801H Component: Tõrsteuer.FS BRM 0406 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 3 Faults Found 00955 - Key 1 35-10 - - - Intermittent 00956 - Key 2 35-10 - - - Intermittent 00933 - Electric Window Motor; Passenger Side (V148) 62-00 - No or Incorrect Adjustment ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 D Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000005 Shop #: WSC 06335 000 00000 VCID: 3B7E35B2453FB6C4 No fault code found. End ---------------------------------------------------------------------
  3. redfly
    Fallo cuadro
    Buenas , estoy intentando casar otra llave y al casar la tercera llave me ha salido en el cuadro Lo 3-3 y no consigo salir de esa codificación Y encima se me han desprogramado las otras dos llaves
  4. Se podia cambiar la centralita del airbag y poner la del b6, que esta solo llevaba un detonador?
  5. ya lo he probado y me da error en el cuadro de airbag
  6. este es el conector
  7. volante
  8. hola compañeros, he conseguido un volante de un audi s4 modelo b8, y lo quiero poner en mi a4 b7. el problema que tengo es que el volante del s4 lleva solo un detonador y el del b7 lleva dos. He probado a juntar los cables de los detonadores y na, me da error de airbag. No se si se podra configurar con el vag com para decir q es un airbag con un detonador
  9. redfly
    audi a4 b7
    hola compañeros , tengo un audi a4 b7 negro y queria cambiarme a 19, pero no se cual poner , si las del rs4 o las del rs6 antiguas si teneis alguna foto del alguna a4 negro con estas llantas, para ver como quedan saludos
  10. no he cambiado las pastillas ni los neumaticos ¿esos sensores miden la velocidad? porque los probe con el vag com y marcaban los cuatro la misma velocidad
  11. hola compañeros, ultimamente cuando ando por ciudad y piso el freno al estar parado noto como vibra los freno , como si estuviese actuando el abs., El coche parado totalmente que puede ser...........
