Dr. West
Todo lo publicado por Dr. West
Que tal compañeros, necesito que por favor me echéis un cable con unos fallos del A5 de una amiga que le salen al meter el vagcom. Estos son los fallos... Address 01: Engine (J623-CAMA) Labels: 059-907-401-CAP.clb Part No SW: 8K1 907 401 HW: 8K0 907 401 Component: 2.7TDI EDC17 H01 0005 Revision: --H01--- Coding: 0114002C02070128 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM27TDI8K1907401 A01005 ROD: EV_ECM27TDI8K1907401.rod 1 Fault Found: 5231 - Fuel Rail/System Pressure: Too Low P0087 00 [036] - Cannot Be Tested at this Time Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 20 Mileage: 182035 km Date: 2014.04.29 Time: 18:43:38 ------------------------------------------------------------------------------------------------------------ Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 289 C HW: 8K0 907 289 C Component: BCM2.01 H38 0253 Revision: 00002001 Coding: 010000 Shop #: WSC 06435 000 00000 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H34 0050 Part No SW: 8K0 905 852 A HW: 8K0 905 852 A Component: ELVAUDIB8 H33 0039 1 Fault Found: 00955 - Key 1 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 ------------------------------------------------------------------------------------------------------------------ Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 289 C HW: 8K0 907 289 C Component: BCM2.01 H38 0253 Revision: 00002001 Serial number: 0106187303 Coding: 0100068000390400012000 Shop #: WSC 06435 000 00000 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 Time: 18:00:55 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 Time: 18:33:56 Gracias de antemano!!! :thumbsup:
Que tal compañeros, necesito que me echéis un cable con unos fallos del A5 de una amiga que le salen al meter el vagcom. Estos son los fallos... Address 01: Engine (J623-CAMA) Labels: 059-907-401-CAP.clb Part No SW: 8K1 907 401 HW: 8K0 907 401 Component: 2.7TDI EDC17 H01 0005 Revision: --H01--- Coding: 0114002C02070128 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM27TDI8K1907401 A01005 ROD: EV_ECM27TDI8K1907401.rod 1 Fault Found: 5231 - Fuel Rail/System Pressure: Too Low P0087 00 [036] - Cannot Be Tested at this Time Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 20 Mileage: 182035 km Date: 2014.04.29 Time: 18:43:38 ------------------------------------------------------------------------------------------------------------ Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 289 C HW: 8K0 907 289 C Component: BCM2.01 H38 0253 Revision: 00002001 Coding: 010000 Shop #: WSC 06435 000 00000 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H34 0050 Part No SW: 8K0 905 852 A HW: 8K0 905 852 A Component: ELVAUDIB8 H33 0039 1 Fault Found: 00955 - Key 1 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 ------------------------------------------------------------------------------------------------------------------ Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 289 C HW: 8K0 907 289 C Component: BCM2.01 H38 0253 Revision: 00002001 Serial number: 0106187303 Coding: 0100068000390400012000 Shop #: WSC 06435 000 00000 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 Time: 18:00:55 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 219 Mileage: 181149 km Time Indication: 0 Date: 2014.04.04 Time: 18:33:56 Gracias de antemano!!! :thumbsup:
Hola Kike, tienes un mp. ...
Airbag 3 radios A6 4F en A6 A7 2011 +
Dr. West responde a mistersamu de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Hola, yo compre el volante con el airbag incluido, pero no te puedo decir si le vale al tuyo. Un saludo. ... -
Que valor de Resistencia poner??
Dr. West responde a kike77 de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Yo también puse resistencias de 100W y se calientan lo suyo. He intentado hacer varias combinaciones de resistencias para que se caliente lo menos posible y no lo he conseguido aún. ... -
Muy buen motor, yo también llevo en la cabeza ese motor desde hace algún tiempo. Y como dice gonchito no se le conocen apenas problemas a este coche excepto algunas unidades que tuvieron problemas con la bomba de agua. Me suena que hubo una campaña de sustitución. ...
Llantas nuevas / no me convencen
Dr. West responde a alberto28 de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Yo llevo 255/35/20 y la verdad es que no tengo nada de rumorosidad. Comprueba el estado de los neumáticos o llevalos a un taller especializado de confianza a que los comprueben y si te dicen que estan bien, esta claro que es la marca o modelo del neumático. -
NO BUSCO MAS EL MANDO EN EL GARAJE
Dr. West responde a carnacas de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Bueno por fin he sacado un hueco y ya soy otro más que se une a llevar el mando del garaje integrado en el coche. Muy bien brico!!! ... -
Impresionante Jordi, enhorabuena y que lo disfrutes!!! Un abrazo!!! :drool:
Que tal chavales, acabo de llamar a recambios Audi dando la referencia 4F0 959 903 del pulsador de persiana y me dicen que no existe. Me podéis confirmar que esto es cierto o después de tanto tiempo la referencia es otra? Muchas gracias!!! ... -
Yo veo bien lo del escrito, firmado por los compañeros que quieren ayudar. Quizás no consigamos nada, pero por lo menos ruido hacemos. + 1 a esa idea. +2 Domin +3... Totalmente de acuerdo!!!
Consejos en compra A6 4F 2.7 TDI MULTITRONIC
Dr. West responde a tabis de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Que tal tabis, que vida llevas? Bueno del tema del coche no te voy a aportar nada que ya no se haya dicho por aquí. Lo único decirte sobre el coche que te vas a pillar que al ser de un compraventa te andes con ojo. Comprueba sobretodo que tiene libro de revisiones de la casa oficial y que te certifican los kms y la no siniestralidad. Por lo demás espero verte pronto con ese buga. Un abrazo ... -
Las llevo conectadas como antinieblas ya que el antinieblas como tal no lo suelo usar. En cuanto a la itv... Los antinieblas delanteros no son obligatorios por lo tanto con pasarla con los leds desconectados es suficiente. ...
Sigo dándole vueltas a la falta de intensidad de los faros de xenon
Dr. West responde a Estornino de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Hola Buho, aqui tienes el enlace de donde compraron los compis los proyectores. yo tambien me estoy planteando pillarmelos, si hubiese una nueva compra conjunta seria cojonudo. http://www.theretrofitsource.com/components/projectors/morimoto-evox-r-bi-xenon-projectors.html#.UtgRzPuOdZ9 -
poner llanta de 20???
Dr. West responde a Patrese de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Nada, con la suspensión neumática sigo yendo muy cómodo, aunque si es verdad que intento no pillar baches y bordillos más que nada por cuidar las llantas. ... -
Cambio de llantas AYUDA
Dr. West responde a raulete30 de discusión en Audi A6 / Allroad C6 (2005 - 2011)
Yo llevo ET 35 y creo que es lo mínimo que se puede llevar, con un ET inferior te rozara seguro. ... -
Que tal chavales, como aludido os respondo Jejejejeje... Efectivamente de serie empece con unas 18" y me cambie a unas Rotor réplica en 19"... Una de las llantas tenía muchas vibraciones y acabe harto de ello, aparte de que como bien decís me parecían pequeñas, no se sí sería porque al ser oscuras las hace más pequeñas o era obsesión mía. Finalmente en eBay Alemania localicé estas rotor en 20" con neumáticos 255/35/20. Al no ser equivalentes ya que el perfil debería de ser 30, las he homologado por un módico precio de 87 euros + 35 euros de la tasa de la itv y solucionado. Ahora disfruto de tener un coche sin vibraciones y en cuanto a prestaciones no he notado tan apenas nada. Tengo que deciros también que al llevar suspensión neumática es una ventaja ya que no he perdido en comodidad incluso llevándola en modo dynamic. En cuanto al sobrecoste que puedan tener los neumáticos... Unos 50-60 euros por rueda aprox. Estéticamente estoy encantado y de momento no encuentro otro modelo de llanta que me guste más. Eso si.... Aparco con un cuidado que hasta a veces me pitan jajajajaja... ... -
Audi TT 2.7 V6 375 CV /el mejor TT q nunca llego !!!
Dr. West responde a ingerasro de discusión en Audi TT Mk1 (1999-2006)
Muy bueno el artículo!!! Que pena que no saliese al mercado. ... -
Montar motor BAT de A6 en vez del BBK al S4
Dr. West responde a Alexgti de discusión en Audi S / R / RS
Menuda currada te estas pegando, es para quitarse el sombrero. Enhorabuena y que pronto te veamos rodar con ese S4 que te esta quedando de cine. ... -
me sirve este volante para el a6 de 2008?? es de un a5
Tendrás que comprobar que el cable es el mismo, de lo contrario pones el que llevas actualmente en el volante nuevo y solucionado. ... -
Enhorabuena Jordi!!! Muy guapo, al final has vuelto a lo bueno Jejejejeje... Bueno que lo disfrutes mucho tiempo, un abrazo. ...
Eso es, efectivamente la ITV te obliga a llevarlas soldadas y no sujetas con tornillos ni abrazaderas. Aunque como ya sabeis cada ITV es un mundo y no todas siguen un mismo criterio.
Pues sí compi es raro lo que hace. Al final se los compre al mismo vendedor que tu, te cuerdas que te pregunte verdad? Y la verdad que con el vendedor todo perfecto, y lo que comentaba, que han ido perfectos hasta ahora. Pues entonces rezaré para que no me fallen Ahora en serio, me da que el problema pueda venir de las conexiones. Cuando hicistes la instalación soldastes los cables no?
Hola ulala, vaya faena no? Cómo bien dicen los compis revisa las conexiones no vaya a ser que se te haya ido alguna y te este dando guerra. Ya nos vas contando. Un saludo. ...
