Hola buenas tengo un problema con mi audi a3 tdi 130cv, el turbo no salta cuando debe y se quedan las luces de averia y esp encendidas.
Aqui os pongo un log hecho con vag com, por favor ayudenme que estoy totalmente perdio gracias de antemano!!
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1477
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L22A048013 AUZ5Z0AN260175
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435
2 Faults Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
01435 - Brake Pressure Sensor 1 (G201)
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Component: A
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900 M
Component: KOMBI+WEGFAHRS. M73 D07
Coding: 04140
Shop #: WSC 02231
No fault code found.
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 K
Component: ZV-Pumpe, Funk D11
Coding: 12864
Shop #: WSC 06435
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00958 - Key 4
09-00 - Adaptation Limit Surpassed
End -------------------------------------------------------
