Buscar en la comunidad
Mostrando resultados para las etiquetas 'esto me ha dado el vagcom'.
Encontrado 1 resultado
Alguien puede ayudarme? el nivel de aceite sube solo
dosega publicó una discusión en Audi A6 / Allroad C6 (2005 - 2011)
VCDS Version: Release 805.0 Data version: 20080529 Sunday,06,October,2013,12:16:12:21461 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 61 62 72 VIN: WAUZZZ4F15N055452 Mileage: 122620km/76192miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Cannot be reached 1100 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door,Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 401 A HW: 4F0 907 401 A Component: 3.0L V6TDI G000AG 0020 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 66565 257 00032 3 Faults Found: 001025 - EGR System: Insufficient Flow P0401 - 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01110010 Fault Priority: 0 Fault Frequency: 240 Mileage: 90145 km Time Indication: 0 Date: 2012.07.16 Time: 05:54:38 Freeze Frame: RPM: 2163 /min Torque: 156.0 Nm Speed: 121.0 km/h Duty Cycle: 54.8 % Duty Cycle: 20.9 % Mass Air / Rev.: 575.8 mg/str Duty Cycle: 48.5 % 012597 - Intake Manifold Runner Control: Lower Stop not Reached P3135 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Mileage: 90474 km Time Indication: 0 Date: 2012.07.16 Time: 10:23:19 Freeze Frame: RPM: 1176 /min Torque: 171.6 Nm Speed: 5.6 km/h Voltage: 13.38 V Duty Cycle: 88.8 % Duty Cycle: 80.9 % Duty Cycle: 80.9 % 013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction P3348 - 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 4 Mileage: 115680 km Time Indication: 0 Date: 2013.07.10 Time: 17:30:35 Freeze Frame: RPM: 1680 /min Torque: 280.8 Nm Speed: 40.3 km/h Temperature: 90.9°C Duty Cycle: 68.3 % Voltage: 13.60 V Duty Cycle: 12.6 % Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F0 910 156 H HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0080 Revision: --H01--- Serial number: 0055816 Coding: 0000001 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 E HW: 4F0 614 517 A Component: ESP8 quattro H03 0010 Revision: 00000000 Serial number: 00000000000000 Coding: 0004488 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0220 Revision: 31050601 Serial number: 10600300071584 Coding: 0000003 Shop #: WSC 00317 572 87327 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H43 0070 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: None Part No SW: 4F1 910 732 D HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 350IT047539525 Coding: 0030004 Shop #: WSC 00000 000 08192 Part No: 4F0 910 609 Component: Bedienteil MMIC6H07 0870 1 Fault Found: 00658 - Control Head 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 177 Mileage: 121754 km Time Indication: 0 Date: 2013.09.26 Time: 13:43:25 Freeze Frame: Bin. Bits: 001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 F Component: KLIMABETAETIGUNGH04 0110 Revision: 00000023 Serial number: 00000000061915 Coding: 0000150 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 B HW: 4F0 907 279 B Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0000101 Shop #: WSC 02335 785 00200 Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 5 Faults Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01111110 Fault Priority: 2 Fault Frequency: 56 Reset counter: 137 Mileage: 147536 km Time Indication: 0 Date: 2009.10.07 Time: 21:38:00 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 9 Reset counter: 177 Mileage: 121552 km Time Indication: 0 Date: 2013.09.26 Time: 07:57:00 01495 - Bulb for High-Beams; Left (M30) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 47 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:34:00 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 177 Mileage: 121552 km Time Indication: 0 Date: 2013.09.26 Time: 07:57:00 01499 - Bulb for High-Beams; Right (M32) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 47 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:34:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBD6016005 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655.lbl Part No SW: 4F0 910 655 D HW: 4F0 959 655 B Component: 33 AIRBAG AUDI8RH29 0250 Revision: 05H29000 Serial number: 0037LD044PLC Coding: 0013107 Shop #: WSC 00384 572 90104 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90022042650135 Coding: 0002041 Shop #: WSC 00233 572 96669 Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 900 S Component: KOMBIINSTR. M73 H09 0630 Revision: 00200000 Serial number: 4H+781R94 Coding: 0001143 Shop #: WSC 00233 572 96669 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 08008049240182 Coding: 6CFE73C41B0104 Shop #: WSC 02325 785 00200 1 Fault Found: 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 132 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:33:31 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 C HW: 4F0 959 793 C Component: TSG FA H10 0020 Revision: 00000000 Serial number: –t$ Coding: 0000522 Shop #: WSC 02327 785 00200 1 Fault Found: 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 177 Mileage: 122626 km Time Indication: 0 Date: 2013.10.06 Time: 12:13:18 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 D HW: 4F0 907 289 D Component: Komfortgeraet H14 0090 Revision: 00900014 Serial number: 01000872110000 Coding: 0000133 Shop #: WSC 02335 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-AS.lbl Part No SW: 4F0 910 223 G HW: 4F0 035 223 Component: Amp.-ASK H09 0350 Revision: 15S00001 Serial number: 00809040029043 Coding: 0000008 Shop #: WSC 02335 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000021633 Coding: 0001003 Shop #: WSC 02323 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 792 C HW: 4F0 959 792 C Component: TSG BF H10 0020 Revision: 00000000 Serial number: $R$ Coding: 0000522 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 D HW: 4F0 907 801 B Component: EPB CEFC0090 H05 0090 Revision: --H05--- Coding: 0000321 Shop #: WSC 00315 781 75399 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 352IY047564188 Coding: 0000001 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H11 0490 Revision: 00000000 Serial number: 00000000061391 Shop #: WSC 00384 572 90104 Part No: 4F0 915 105 D Component: von VA0 1409130773 Coding: 344630393135313035442056413031343039313330373733 Shop #: WSC 00000 384 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door,Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 795 A Component: TSG HL H09 0010 Coding: 0000002 Shop #: WSC 02327 785 00200 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 123 Reset counter: 137 Mileage: 121552 km Time Indication: 0 Date: 2013.09.20 Time: 19:33:29 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 794 A Component: TSG HR H09 0010 Coding: 0000002 Shop #: WSC 02327 785 00200 No fault code found. End ---------------------------------------------------------------------
