Buscar en la comunidad
Mostrando resultados para las etiquetas 'fallos s3 8p vag com autoscan'.
Encontrado 1 resultado
Hola, recientemente me llegó el vag com y probandolo he hecho un autoscan y me han salido estos fallos. Alguien me puede echar una mano?? Address 01: Engine 2 Faults Found: 012691 - Intake Manifold Runner Control P3193 - 002 - Open Stop outside of Valid Range - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 104571 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 80.0°C Temperature: 51.0°C Absolute Pres.: 990.0 mbar Voltage: 12.446 V 001602 - Sensor Reference Voltage A: Circuit P0642 - 002 - Low - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 104571 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 80.0°C Temperature: 51.0°C Absolute Pres.: 990.0 mbar Voltage: 12.446 V Address 25: Immobilizer 1 Fault Found: 16346 - Control Module - ROM Error 014 - Defective Address 37: Navigation 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 63 Mileage: 99237 km Time Indication: 0 Date: 2016.08.28 Time: 16:49:41 Freeze Frame: Voltage: 12.60 V Mileage: 655350 km Count: 65535 Clock: 255:255 Address 46: Central Conv. Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 2 - Part No: 1K0 907 719 C Component: Neigungssensor 005 0003 Subsystem 3 - Part No: 8P0 951 177 Component: Innenraumueberw.H04 0020 1 Fault Found: 00956 - Key 2 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Address 56: Radio 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 63 Mileage: 99237 km Time Indication: 0 Date: 2016.08.28 Time: 16:49:41 Freeze Frame: Voltage: 12.60 V Mileage: 655350 km Count: 65535 Clock: 255:255
