Pongo aqui los fallos del test con el vag com a ver si alguien ve algo, no entiendo nada.
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CK
Component: 1,9l R4 EDC G400SG 1343
Coding: 00002
Shop #: WSC 06435
WAUZZZ8L42A003039 AUZ7Z0A1884649
2 Faults Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 932 L
Component: KOMBI+WEGFAHRS. VDO D07
Coding: 07140
Shop #: WSC 00310
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15179
Shop #: WSC 06435
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
End -------------------------------------------------------
17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
[edit]Possible Causes
Alternator faulty
Voltage Regulator faulty
Wiring and/or connections faulty
[edit]Possible Solutions
Check / Replace Alternator
Check / Replace Voltage Regulator
Check wiring and connections
Check the fuse box that is in the battery tray, it might be burnt, the fuse or the complete plastic box (pretty common failure on Sharan because it carries so much electrical load). If so, change the complete fuse box, it is not too expensive fix if this is the cause
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
[edit]Possible Symptoms
Reduced power output
Limp mode
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
