mirar con el vag me sale esto.
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 C
Component: 1,8l R4/5V MOTR AT V04
Coding: 04030
Shop #: WSC 06435
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
P1326 - 35-10 - - - Intermittent
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 01M 927 733 AJ
Component: AG4 Getriebe 01M 2926
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 06435
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
00290- ABS Wheel Speed Sensor: Rear Left (G46)
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 919 860 A
Component: AB-KOMBIINSTR. VDO D07
Coding: 00142
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0T0052422
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 D
Component: ZV-Pumpe,Funk
Coding: 08768
Shop #: WSC 65535
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
End ------------------------------------------------------- QUE SON LAS COSAS QUE FALLAN?
borralas todas, la mayor parte son exporadicas ,las que mas guerra pueden dar son las del inmobilizador,las del cierre centralizado suelen salir a menudo ,
cuando las borres dale un repaso con el vag-com unos dias despues para ver que te sale
saludos
