villarcayo Publicado 28 de Abril del 2007 Denunciar Compartir Publicado 28 de Abril del 2007 Os pego a continuación los fallos que me dió mi coche: A4 TDI 1900, 110cv, año96 (B5) Me ayudais a saber que quiere decir esTos fallos???? de psikiatria entiendo algo,pero de desto no,jejej, GRACIAS al que me ayude.. NEcesito saberlo cuando antes.. VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 CE Component: 1.9l R4 EDC 00SG 0803 Coding: 00002 Shop #: WSC 06335 1 Fault Found: 01237 - Fuel Shut-Off Valve (N109) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 033 A Component: B5-KOMBIINSTRUMENT D07 Coding: 00140 Shop #: WSC 12102 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0T7884819 D77 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 9 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal End ------------------------------------------------------- Os pego a continuación los fallos que me dió mi coche: A4 TDI 1900, 110cv, año96 (B5) Me ayudais a saber que quiere decir esTos fallos???? de psikiatria entiendo algo,pero de desto no,jejej, :x GRACIAS al que me ayude.. NEcesito saberlo cuando antes.. :silbar: :evil: VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 CE Component: 1.9l R4 EDC 00SG 0803 Coding: 00002 Shop #: WSC 06335 1 Fault Found: 01237 - Fuel Shut-Off Valve (N109) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 033 A Component: B5-KOMBIINSTRUMENT D07 Coding: 00140 Shop #: WSC 12102 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0T7884819 D77 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 9 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal End -------------------------------------------------------Os pego a continuación los fallos que me dió mi coche: A4 TDI 1900, 110cv, año96 (B5) Me ayudais a saber que quiere decir esTos fallos???? de psikiatria entiendo algo,pero de desto no,jejej, :x GRACIAS al que me ayude.. NEcesito saberlo cuando antes.. :silbar: :evil: VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 028 906 021 CE Component: 1.9l R4 EDC 00SG 0803 Coding: 00002 Shop #: WSC 06335 1 Fault Found: 01237 - Fuel Shut-Off Valve (N109) 31-10 - Open or Short to Ground - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 033 A Component: B5-KOMBIINSTRUMENT D07 Coding: 00140 Shop #: WSC 12102 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 F Component: IMMO AUZ9Z0T7884819 D77 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 9 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal End ------------------------------------------------------- pd:) ya he copiado lo mismo en la web de vagcom... Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Impulse S Publicado 28 de Abril del 2007 Denunciar Compartir Publicado 28 de Abril del 2007 MODO BROMA ON : todos esos fallos significan que tires el coche a la basura !!! que te ha salido malo jajajaja MODO BROMA OFF : siento no poder ayudarte mas que a subir el tema para que lo vean otros y te puedan ayudar.... SALUDOS Responder Enlace al comentario Compartir en otros sitios web More sharing options...
PAUL-A8 Publicado 1 de Mayo del 2007 Denunciar Compartir Publicado 1 de Mayo del 2007 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
