Os pego a continuación los fallos que me dió mi coche:
A4 TDI 1900, 110cv, año96 (B5)
Me ayudais a saber que quiere decir esTos fallos???? de psikiatria entiendo algo,pero de desto no,jejej,
GRACIAS al que me ayude.. NEcesito saberlo cuando antes..
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 028 906 021 CE
Component: 1.9l R4 EDC 00SG 0803
Coding: 00002
Shop #: WSC 06335
1 Fault Found:
01237 - Fuel Shut-Off Valve (N109)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 A
Component: B5-KOMBIINSTRUMENT D07
Coding: 00140
Shop #: WSC 12102
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T7884819 D77
Coding: 00000
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
End -------------------------------------------------------
Me ayudais a saber que quiere decir esTos fallos???? de psikiatria entiendo algo,pero de desto no,jejej, :x
GRACIAS al que me ayude.. NEcesito saberlo cuando antes.. :silbar: :evil:
Coding: 00002
Shop #: WSC 06335
1 Fault Found:
Readiness: N/A
Coding: 0273004132
Shop #: BB 24303
Controller:
Coding: 00140
Shop #: WSC 12102
Coding: 00000
Shop #: WSC 00000
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
End -------------------------------------------------------Os pego a continuación los fallos que me dió mi coche:
Coding: 00002
Shop #: WSC 06335
1 Fault Found:
Readiness: N/A
Coding: 0273004132
Shop #: BB 24303
Controller:
Coding: 00140
Shop #: WSC 12102
Coding: 00000
Shop #: WSC 00000
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
pd:) ya he copiado lo mismo en la web de vagcom...
