codigos vag com
zoli
hola
a ver si alguen me aclara
que significa esto
muchas gracias
VAG-COM
Windows Based VAG/VAS Emulator
Version: Release 311.2-N
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Monday, 30 April 2007, 20:57:51
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00003
Shop #: WSC 63351
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04255
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 01100
Shop #: WSC 00330
Address46 -------------------------------------------------------
Controller: 8E0 959 433 AH
Component: Komfortgerát T1B 0619
Coding: 06730
Shop #: WSC 63351
1 Fault Found:
01616 - Signal Wire to Interior Monitor
49-00 - No Communications Address
56 -------------------------------------------------------
Controller: 8E0 035 152
Component: chorus II GRO 0007
Coding: 00002
Shop #: WSC 63351
End -------------------------------------------------------
Enlace al comentario
Compartir en otros sitios web
bueno tienes varios errores
en este modulo (climatizador)
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
es un fallo
Servomotor para la trampilla de retención de aire -V71, parece un fallo intermitente...si te sigue saliendo, tendras que cambiarla
y luego tienes otro fallo en el modulo comfort 46
Coding: 06730
Shop #: WSC 63351
1 Fault Found:
línea de señales para vigilancia espacio interior (sin comunicacion)
este supongo que sea de la alarma volumetrica...pero la verdad es que de fijo no lo se.
borralo, ya he visto varios coches que tras cambio de bateria o desconexion de la misma da este tipo de fallos
