Buenas a todos.
Comentaros antes de nada, decir que estoy iniciandome en lo que es conocer el Vagcom, y que a lo que hago referencia no es imprudencia, ya que no he tocado nada de nada, solo el "Auto-scan".
Os copio aquí el Auto-Scan:
VAG-COM Version: Release 607.3-UD
Monday,21,May,2007,20:14:40
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: WAUZZZ8P*********
Address 01: Engine
Part No SW: 06F 906 056 BT HW: Hardware No
Component: MED9.5.10 G00 5340
Coding: 0000072
Shop #: WSC 03463
Part No: 06F 907 807 A
Component: NOX 0309080072 004 3608
06F907807A NOX 0309080072 004 3608
2 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 008 - Implausible Signal - Intermittent
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Coding: 058C4F0080141000000000000000000000
Shop #: WSC 00247
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00064784
Shop #: WSC 00247
2 Faults Found:
02104 - Light Detection Sensor (G399)
010 - Open or Short to Plus
00153 - Left Windshield Wiper Motor (V216)
004 - No Signal/Communication - Intermittent
Address 15: Airbags
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0010602
Shop #: WSC 06435
Address 16: Steering wheel
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H09 0020
Coding: 0000042
Shop #: WSC 03463
Address 17: Instruments
Part No SW: 8P0 920 930 G HW: 8P0 920 930 G
Component: KOMBIINSTR. VDO H25 0110
Coding: 0004103
Shop #: WSC 03463
Address 19: CAN Gateway
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Coding: 3D0F0300070100
Shop #: WSC 06435
Address 25: Immobilizer
Address 42: Door Elect, Driver
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000088
Shop #: WSC 06435
Address 44: Steering Assist
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.9 1202
Address 46: Central Conv.
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 188800186D288505484A016000
Shop #: WSC 06435
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass.
Part No: 8P0 959 802 A
Coding: 0000088
Shop #: WSC 06435
End --------------------------------------------------------------------------------------------------
Por favor, sé que lo tendré que llevar a la casa para que me lo miren y demás, pero me gustaría hacerme una idea de que va la cosa.
Os comento, para que pueda ayudar:
+ Tengo una alarma -no original- instalada en el coche.
+ Y que también, llevo 2 meses o así que el sensor que mide al arrancar la temperatura del coche, y hace saltar el motorcillo para que suba las revoluciones -en el caso de que este frio el coche- pues no lo hace y digamos que lo tengo que activar manualmente acelerando un poco.
Espero vuestras respuestas.
SALUDOS.
2 Faults Found:
Está claro que hay algo mal en esa sonda de Nox. La otra vez que le pasamos el "chequeo" salió ese error. Como ya me comentaste que esa sonda te la cambiaron en garantía, ve a la concesión a ver qué se puede hacer.
Del error 18104, de momento, bórralo y a ver si se reproduce. Parace que está provocado por una mala lectura.
2 Faults Found:
El error del detector de luces, no te extrañe, que haya salido cuando probamos los diferentes long codes. Acuérdate que int*****mos activar el leaving/coming home y hacía falta el susodicho sensor (que no tienes instalado). Puede ser una causa.
Sin embargo, el de la ventanilla se vuelve a repetir. Pensaría en una instalación no muy correcta de la alarma.
SALUDOS
  • 1 mes más tarde...
Buenas a todos.
Address 01: Engine
Coding: 0000072
Shop #: WSC 03463
2 Faults Found:
Coding: 0053894
Shop #: WSC 06435
Shop #: WSC 00247
Coding: 00064784
Shop #: WSC 00247
2 Faults Found:
Address 15: Airbags
Coding: 0010602
Shop #: WSC 06435
Coding: 0000042
Shop #: WSC 03463
Coding: 0004103
Shop #: WSC 03463
Shop #: WSC 06435
Coding: 0000088
Shop #: WSC 06435
Shop #: WSC 06435
Coding: 0000088
Shop #: WSC 06435
SALUDOS.
Yo tambien tengo este error:
diste con la solución?
un saludo
