yo me apunto a esa minikdd madrileña con Julito para ver tu coche eh!! :clap1: :clap1:
precioso y mas que lo va a estar........ :clap1:
Romulo, creo que cualquiera que lea tu contestación, se ve claramente que no eres un "tocahuevos", al contrario, es con criterio y por ayudar, esta clarito :clap1: :clap1: :clap1:
bueno,la correa de la distribucion dificil que se le rompa,lleva cadena si no me equivoco
sober el coche,a mi personalmente me parece ....bueno...ajjaja ,espero que no te ofendas
Aunque siendo regalado,la cosa cambia
Por cierto,esta homologado para seis plazas
5.7L SPFI ENGINE - 1994, 1995, & 1996 only
Trade Name: LT1
Number of Cylinders: 8 cylinders - 90 degree V
The 1995 model year marked the eightieth year of the Cadillac V8 engine.
Net Power: 260 bhp (194 kw) @ 5000 rpm
Net Torque: 330 lb-ft. (447 Nm) @ 3200 rpm
Redline RPM: 5500 RPM
Power to weight ratio: 0.060 (260/4369)
Pounds per Horsepower: 16.8
Displacement: 349.9 cu. in. (5.7 liter/5735 cc)
Bore: 4.00 in. (101.6 mm)
Stroke: 3.48 in. (88.39 mm)
Compression Ratio: 10.5:1
Cylinder Block: Cast Iron
Cylinder Head: Cast Iron
Intake Manifold: Cast Aluminum
Lifter Assembly: Hydraulic
Valvetrain: Over Head Valve (OHV)
Intake Valve: 1.94 in. (49.3 mm)
Exhaust Valve: 1.50 in. (38.1 mm)
Pistons: Cast Aluminum
Firing Order: 1-8-4-3-6-5-7-2
Left Bank: 1-3-5-7
Right Bank: 2-4-6-8
Crankshaft: Cast Iron
Main Bearings: 5
ENGINE LUBRICATION SYSTEM
Oil Pressure: 6 psi (41 kPa) @ 1000 rpm
Type of Intake: Stationary
Filter System: Full-Flow
ENGINE COOLING SYSTEM
Surge Tank Cap Relief: 15 psi (104 kPa)
Thermostat Starts to Open: 180 degrees F (82 C)
Water Pump Type: Centrifugal (spur gear driven by the camshaft)
Drive Belt: Serpentine Belt
Radiator Core: Hi-Efficiency Aluminum
Type: Reverse Flow Cooling System
Coolant: Dex-Cool (unique orange color - rated to last 100,000 miles or 5 years. AKA Havoline Extended Life Antifreeze).
Radiator Cooling Fans: Dual Electric Fans with a 150-watt primary (RH) fan and a 100-watt secondary (LH) fan - Primary (RH) Fan ON 225 F (107 C), Secondary (LH) Fan ON 232 F (111 C)
Radiator Cooling Fan (Heavy-Duty): Mechanical belt driven Centrifugal thermostatic clutch fan (primary) and 240-watt (LH) electric fan (secondary).
FUEL SYSTEM
Induction Type: Sequential Port Fuel Injection (SPFI)
Idel Speed: PCM (Powertrain Control Module) Controlled
Filter Type: Paper Type Element
Fuel Pump: Electric (in tank)
Fuel Required: Unleaded (87 octane)
AUTOMATIC TRANSMISSION
Trade Name: 4L60-E
Type: 4-speed automatic with electronic shift control, overdrive, torque converter clutch
Fluid Required: Dexron-III
Ratios: 1st 3.06:1, 2nd 1.62:1, 3rd 1.00:1, 4th 0.70:1, Reverse 2.29:1
REAR DRIVE AXLE
Description: Semi-Floating Hypoid
No. of Differential Pinions: 2
Drive Wheel Bearing Type: Roller
Axle Ratio (Fleetwood): 2.56:1
Axle Ratio (Brougham): 2.93:1
Axle Ratio (V4P Trailer Towing Option): 3.42:1
Axle Ratio (Coachbuilder): 2.93:1
EMISSION CONTROL SYSTEMS
Air Injection: Air Injection with Computer Command Control (CCC)
Exhaust Gas Recirculation: Controlled Flow
Catalytic Converter: Warm-Up 3-Way
Evaporative Emission Control: Charcoal Canister
Crankcase Emission: Positive Crankcase Ventilation (PVC)
Electronic System: Closed Loop
EXHAUST SYSTEM
Type: Dual with Crossover Pipe
Muffler: Two-Reverse Flow
Resonator: Two-Straight Flow
Exhaust Pipe: Stainless Steel
Intermediate Pipe: Stainless Steel
Tail Pipe: Stainless Steel
ELECTRICAL SYSTEM
Battery (V/CCA): 12.8 VCD / CCA
AC Delco Model: 78-7YR 770 CCA 960 CA 120 RC
Voltage: 12 vdc
Ground: Negative
Generator: 140 amps
AIR CONDITIONING SYSTEM
Refrigerant: R-134a 1.75 lbs. (0.79 kg)
FLUID CAPACITIES
Auto Trans (4L60-E) Pan Removal: 5.0 quarts (4.7l)
Auto Trans (4L60-E) Overhaul (298 mm Torque Conv.): 11.2 quarts (10.6l)
Engine Oil & Filter Change: 5.0 quarts (4.7l)
Engine Cooling: 14.0 quarts (13.2l)
Engine Cooling with A/C: 15.1 quarts (14.3l)
Engine Cooling Heavy-Duty: 16.8 quarts (15.9l)
Fuel Capacity: 23.0 gal. (87 L)
Power Steering: 1.4 quarts (0.65l)
Rear Axle: 4.3 pints (2.0l)
TIGHTEN TORQUE
Spark Plugs: 11 lb-ft. (16 Nm)
Oil Filter: 14 lb-ft. (19 Nm)
Oil Pan Drain Plug: 30 lb-ft. (30 Nm)
Wheel Lug Nut: 100 lb-ft. (140 Nm)
Rear Axel Filler Plug: 26 lb-ft. (35 Nm)
VEHICLE DIMENSIONS
Wheelbase: 121.5 in. (3085 mm)
Length: 225.1 in. (5717 mm)
Width: 78.0 in. (1982 mm)
Width (mirror to mirror overall): in. ( mm)
Height: 57.1 in. (1451 mm)
Ground Clearance: 5.5 in (139.7 mm)
Front Overhang: in. ( mm)
Rear Overhang: in. ( mm)
Turning circle (curb to curb): 44.5 ft. (13564 mm)
Turning circle (wall to wall): ft. (mm)
Front Tread: 61.7 in. (1568 mm)
Rear Tread: 60.7 in. (1542 mm)
Head Room (Front): 38.7 in. (984 mm)
Head Room (Rear): 39.1 in. (994 mm)
Head Room wih Sunroof (Frt/RR): in. ( mm)
Leg Room (Front): 42.4 in. (1079 mm)
Leg Room (Rear): 43.9 in. (1116 mm)
Shoulder Room (Front): 64.2 in. (1632 mm)
Shoulder Room (Rear): 64.0 in. (1626 mm)
Hip Room (Front): 59.2 in. (1504 mm)
Hip Room (Rear): 59.7 in. (1518 mm)
Luggage Capacity: 21.1 cu. ft. (598 L)
Trunk Liftover Height: in. (mm)
Passenger Volume: 145.9 cu. ft. (4131 L)
Passenger Volume with Sunroof: cu. ft. ( L)
Shipping Weight (Fleetwood): 4,369 lbs. (1,982 kg)
Shipping Weight (Brougham): 4,389 lbs. (1,991 kg)
Curb Weight is the weight of a car as delivered, including all options, that have at least a 33 percent penetration with fuel and lubricant levels full.
Weight Distribution (Frt/RR): 55%/45%
Domestic Content: 95 percent
Note: The interior volume is measured using SAE Recommended Practice J1100 as per EPA Fuel economy regulations, reg. 40 CFR 600.315-82 "Classes of Comparable Automobiles."
PERFORMANCE
EPA Fuel Economy: 17 mpg city, 26 mpg highway
EPA Fuel Economy (Brougham): 17 mpg city, 25 mpg highway
EPA Fuel Economy (with V4P Trailer Towing Option): 17 mpg city, 23 mpg highway
EPA Fuel Economy are laboratory fuel economy tests administered by the Environmental Protection Agency using simulated weight and drag to re-create real driving conditions. The city fuel economy test, also used to test emissions compliance, is based on a drive though the typical Los Angeles urban traffic of about twenty years ago. The highway test uses a higher, steadier speed, averaging 49.4 mph.
(Note: avoids a $1,000 gas guzzler tax by .1 mpg!)
Fuel Range: 575 miles
Skidpad (g): 0.77 G
0 to 30 mph Acceleration: 3.4 seconds (with 2.56:1 Rear Axle)
0 to 60 mph Acceleration: 8.5 seconds (with 2.56:1 Rear Axle)
0 to 100 mph Acceleration: 22.6 seconds (with 2.56:1 Rear Axle)
Standing 1/4 mile: 16.6 seconds elapsed time at 86.6 MPH (with 2.56:1 Rear Axle)
30 to 50 mph Passing: 5.4 seconds (with 2.56:1 Rear Axle)
50 to 70 mph Passing: 5.5 seconds (with 2.56:1 Rear Axle)
Top Speed: Internal RPM limiter set at 108 mph (Fuel shut-off) - Probably is drag-limited to about 140 mph.
Braking Distance 60-0 MPH: Feet ( M)
Coefficient of Drag: 0.36 Cd
Frontal Area: 25.9 Sq. Ft.
Max towing capacity: 5,000 lbs.
Max towing capacity with V4P Trailer Towing Option: 7,000 lbs.
INTERIOR SOUND LEVEL
Idle: dBA
Full-throttle acceleration: dBA
35-mph cruising: dBA
35-mph coasting: dBA
55-mph cruising: dBA
55-mph coasting: dBA
70-mph cruising: dBA
70-mph coasting: dBA
Exterior Sound Level, Moving Vehicle, Pass-By: dBA
STANDARD EQUIPMENT
INTERIOR
6 Way Power front seat adjusters/recliners * Assist handles (4) * Cigar lighters: (1) front/(2) rear * Front/rear door armrests w/ (1) front/(2) rear ash receivers * Door pull swing handles * Front seatback pockets * Air bags, driver and front passenger * ETR AM stereo/FM stereo w/cassette & Equalizer-inc: seek-scan, search/repeat, auto tone control, auto reverse, music search, (6) speakers * Auto-dimming inside rearview mirror * Automatic door locking system with anti-lockout * Carpeted Front & Rear Floor Mats * Carpeted Trunk Mat & Cargo Net * Cloth Split Bench Seats * Column shift * Controlled-cycle wipers * Cruise control * Digital Clock * Digital instrumentation/fuel gauge/trip odometer * Electronic climate control w/CFC Free A/C * Flash-to-pass headlamps * Front visor vanity mirrors, illuminated * Illuminated entry * Illuminated Visor Mirrors * Interior lights: glove compartment, map, and luggage compartment * Message Telltale Center * Outside temp display * On-board computer diagnostics * PASS-Key II security * Power door locks with anti-lockout * Power front seat adjusters/recliners * Power windows, drivers express down * Pre-wired for cellular phone * Reading lamps, front/rear * Rear window defogger * Rear doors child security locks * Lockout rear windows * Remote Controlled Trunk Release with Power Pull Down * Remote keyless entry/key fob * Retained accessory power * Side Glass Defoggers * Solar-Ray tinted glass * Tilt-adjusting wheel, leather-trimmed * Traction Control on/off switch * Twilight Sentinel Headlights
EXTERIOR
Clearcoat paint * Front/rear bumper guards/rub strips * Bright unique lower body-side molding * Brake/transmission interlock * Compact spare tire with cover * Daytime Running Lights (DRL) * Electronic Level Control (ELC) * Front/rear crush zones * Front cornering lights * Lamp monitor, front/rear * Rear license plate mounting provision * Door edge guards * Power antenna, rear mounted * Power deck lid pulldown * Power, Heated Folding Sideview Mirrors * Steel safety cage * Trunk, power pull-down * Trumpet Horn * Tungsten-halogen headlamps * Underhood lamp * Warning Tones
MECHANICAL
5.7L SPFI V8 engine * Platinum tipped spark plugs * 4-speed automatic transmission w/Over Drive, torque converter clutch, electronic shift control * Brake/transmission shift interlock * Full-range traction control w/on/off switch * Rear wheel drive * 140 amp alternator * Long-life engine coolant * Fully independent front Short/long arm suspension w/coil springs * Four link rear suspension w/coil springs * Power Front Disc Brakes with Front & Rear Anti-Lock * Front & Rear Stabilizer Bars * Speed-sensitive electronic variable power-assist steering * 15" Cast Aluminum Wheels * Anti-lock braking system (ABS) * Automatic parking brake release * 23 gallon fuel tank * Stainless steel dual exhaust system
Antilock brakes and traction control are deleted on Limousine (V4U) and Funeral Coach (B9Q) options.
OPTIONAL EQUIPMENT
BROUGHAM PACKAGE ($2465.00)
Articulating headrests * Center rear armrest/cupholder * Eight-way memory driver's seat * Heated front seats * Full Padded Vinyl Roof (delete at no additional charge) * Rear Seat Illuminated Vanity Mirrors * Stylized aluminum wheels * 2.93:1 Rear Axle Ratio
TRAILER TOWING PACKAGE ($215.00)
Goodyear Eagle GA P235/70R15 * Heavy-Duty Cooling System * Rear Axle, 3.42:1 Ratio * Ride Handling Suspension System (FE2) * Trailer Wiring Harness
SECURITY PACKAGE ($360.00)
Audible Theft Deterrent System * Automatic Locking Fuel Filler Door
FLEETWOOD/BROUGHAM, OPTIONAL
Cellular phone, portable * Chrome finish wheels * Full-size spare tire with cover ($95.00) * Leather seating areas ($785.00) * Solar reflective windshield [sun Shade Tinted] * Sunroof ($1550.00) * Three-channel garage door opener / Gate Opener [HomeLink transmitter] ($135.00) * Engine Coolant Heater * 7000 lbs. Trailer Towing Package ($215.00) * Full Padded Vinyl Roof ($925.00) * AM Stereo/FM Stereo w/ Cassette and Single-Slot CD Player ($200.00) * Trunk Mounted CD Changer * Heavy Duty livery Package ($150.00) * Coachbuilder Limousine Package ($755.00) * Heritage of Ownership Badge ($25.00)
All MSRP prices listed are in US Dollars unless otherwise noted.
NORMAL MAINTENANCE REPLACEMENT PARTS
Air Cleaner Element: AC Type A1096C (25096932) / Fram CA6479
Battery: 78A-72
Fuel Filter Element: AC Type GF-624K (25121978)
Engine Oil Filter: AC Type PF52 (25160560) / AC Delco Ultra-Guard UPF-52 / Mobil1 M1-201
PVC Valve: AC Type CV895C (25095452)
Spark Plugs (Gap 0.052 in.): AC Type 41-906 (5614244)
Serpentine Drive Belt: 10186120
Upper Radiator Hose: 10260864
Lower Radiator Hose: 10237350
Lower Radiator Hose (Heavy-Duty): 10237349
Surge Tank Cap: 10244485
Thermostat: 10128336
BULB CHART
Ashtray Illumination: 1445
Backup Lamps: 2057
Center High-Mounted Stoplamp: 1156 (1141)
Cornering Lamp: 2057
Door - Courtesy: S214-2
Door - Roof Rail: 192
Front Parking and Directional Signal: 2057NA
Front Side Marker Lamp: 194
Glove Box: 194
Headlamp High Beam: 9005
Headlamp Low Beam: 9006
Headllamp Switch: 8Q245-35003A
HVAC Control: OL4186NW Type TL5
Instrument Panel Illumination: PC194
Instrument Panel Warning/Indicators: PC118
License Plate Lamp: 194
Map Lamp: 168
Parking Lamp: 2057
Rear Side Marker Lamp: 194
Stop, Tail and Directional Signal Lamp: 2057
Trunk Lamp: 920
Underhood Lamp: 561
Vanity Mirror: TS-14V1CP
Window Switch Floodlight: 74
un saludo!
Editado por supercanedas
Esas 2 ultimas fotos que a puesto Supercadenas se corresponden exactamente con el coche, en color y todo... No es que sea precioso ni mucho menos pero es totalmente distinto y exclusivo cuantos como este ves por la calle??? eso es lo que me gusta y me hace gracia todo el mundo lo mira y se queda impresionado. :innocent::lol2::lol2::az:
Ayer lo estuve limpiando y me lleve la camara para hacerle unas fotillos, cd termine y le fui a sacar fotos no tenia bateria jajajajajaja menudo desastre que soy. Pero el viernes me lo trae un amigo en grua a casa y aqui le sacare todas las fotos...
Ahh una curiosidad cuando fui a ver el deposito de la gasolina, no tenia c*** de encontrarlo....... donde estaba????? a lo mejor alguno lo sabeis pero yo tarde 15 minutos en encontrarlo, debajo de la matricula, es decir tiene dos bisagras y tienes que tirar de la matricula para ver el tapon :innocent::lol2::lol2:
Ahh una curiosidad cuando fui a ver el deposito de la gasolina, no tenia c*** de encontrarlo....... donde estaba????? a lo mejor alguno lo sabeis pero yo tarde 15 minutos en encontrarlo, debajo de la matricula, es decir tiene dos bisagras y tienes que tirar de la matricula para ver el tapon :lol2::lol2::az:
eso es muy comun en los coches americanos
tio,yo creo qeu cuando vas con ese coche te miran porque se creen que va una novia dentro :innocent:
Hola, enhorabuena tio por el regalito. Me gusta, es diferente. Yo soy de madrid, ya te mandare un privado y me lo enseñas un finde. Saludos.
