Este es el resultado de mi scan..
Engine:
Address 01: Engine Labels: None
Part No SW: 03C 906 056 CP HW: Hardware No
Component: MED9.5.10 00 7956
Coding: 0000072
Shop #: WSC 06314
3 Faults Found:
006418 - Pressure Sensor for Brake Boost (G294): Short to Plus
P1912 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 9
Mileage: 21551 km
Time Indication: 0
Date: 2007.05.22
Time: 09:34:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 63.0°C
000406 - Engine Oil Temp. Sensor (G8): Implausible Signal
P0196 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 23244 km
Time Indication: 0
Date: 2007.08.07
Time: 13:38:15
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
005241 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 23653 km
Time Indication: 0
Date: 2007.08.22
Time: 07:45:46
Freeze Frame:
RPM: 2280 /min
Load: 49.4 %
Speed: 28.0 km/h
Temperature: 87.0°C
Readiness: 0000 0001
Luego, en central eléctrica..
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Coding: 058C4F078014100000000000000000000008FE175C0100
Shop #: WSC 06314
Part No: 8P1 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
01499 - Bulb for High-Beams; Right (M32)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 23381 km
Time Indication: 0
Date: 2007.08.12
Time: 21:36:00
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Can Gateway
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D0F0342070100
Shop #: WSC 06314
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 28
Mileage: 21551 km
Time Indication: 0
Date: 2007.05.22
Time: 09:34:11
Ahí debe ser que como no llevo la radio de casa, cero patatero..
Alguien me podría comentar los errores que me dió? Y causa solución?
Gracias.
Yo siempre he dicho que un error no es tal hasta que no se vuelva a repoducir. Por lo que, para evitar quebraderos de cabeza, te invito a que los borres y, dentro de 15 días, vuelvas a hacerle un escaneo.
SALUDOS
Vale ok, gracias.
Otra cuestión, cuando me meto con el VAG y me voy a los Grupos, que cuando cierras sólo se enciendan los intermitentes, creo que 0 es desactivado, 1 intermitentes (como lo tengo) 2 el claxon según mi pobre inglés, y el 3 Intermitentes y el claxon, cuando le quiero poner 3, no me deja guardar, como se puede cambiar eso?
Si mal no creo recordar, era el grupo 002.
Nadie me puede ayudar o no es posible eso¿?
a ver si me dan mi coche ya, y quedamos un dia y le echamos un ojo al tema...
ASí, a ver si entre tu inglesh, y mi compañia (que ya es mucho :laugh:) nos ayudan a arreglar tu problema y a hacerle al mio alguna cosita... :clap1:
sigo en espera de alguna pieza que falta por llegar al taller... :clap1:
s2!!
Editado por eassun
