Pues eso, que ayer le metí el vag-com a mi fregoneta :huh: para ver que tal estaba, y salieron algunas "peguillas": todos son fallos eventuales, x lo que no me preocupa, menos uno, que sí me ha dejado un poco intraquilo: transcribo literalmente: 17571 - Fuel Temp Sensor (G81): Open or Short to Plus
P1163 - 35-00 - -
¿Os ha salido a alguno de vosotros?¿será grave? :(
Os pongo la lista completa:
AUTO SCAN A4 B6
VAG-COM Version: Release 303.1
Chassis Type: 8E - B6 Audi A4
Scan: 01,02,03,08,09,15,16,17,36,37,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 JT
Component: G000SG 1572
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E83A252334 AUZ6Z0B0325897
2 Faults Found:
P1163 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
0 Faults Found:
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
1 Faults Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00000
0 Faults Found:
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
0 Faults Found:
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 02100
Shop #: WSC 02976
1 Faults Found:
01176 - Key
07-10 - Signal to Low - Intermittent
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
0 Faults Found:
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 24446
Shop #: WSC 02976
2 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
End -------------------------------------------------------
  • Respuestas 49
Posted Images
Menos mal que no le he metido el VAG-COM a mi limousina :( , porque sino todo lo que escuchara cuando vaya en marcha me parecerian ruidos extraños :D:huh:
Parece que tienes el gasoil frio, calientalo un poquito pero no mucho por que a cierta temperatura arde. :lol::lol:
No sera nada Kyfran :D
JE,JE, supongo que tendré que enchufarle el encendedor del mechero para que entre en calor :lol:
Abuelo y Arroy gracias de todas formas :huh:
Ofren: un millón de gracias x tu valiosa información :blink: (¿de donde la sacas?)
X lo que veo, el tema puede ser grave, y puede suponer incluso una pérdida de potencia :blink: (aparentemente no he notado nada).
Como el coche está en garantía, pienso llevarlo al concesionario, pero aquí viene el problema: no puedo llegar diciendo que le he metido el vag-com y que me sale esa avería, ya que pueden entender que estoy manipulando el coche y lavarse las manos :blink: : x tanto, podría darles alguna escusa, esto es, algún problema que pueda estar relacionado con dicha avería:
Se me ocurre decirles que el coche a veces no me arranca a la primera, o que le cuesta arrancar, o que nada más arrancarlo se me ha parado (ésto último me ha sucedido pero solo 2 veces aisladas, y no le dí más importancia: giré la llave de nuevo y ningún problema).
Gracias de nuevo
Yo borraría el error y estaría pero que muy pendiente de si vuelve a salir o no. Si vuelve a salir se me ocurre como escusa para ir al conce diciendo que no se que día se paro el motor en un semáforo, lo arranqué y no le dí importancia. Pero que la semana pasada me volvió a pasar y ya estoy mosqueado. ¿que te parece?
Como la avería dice que hay parada del motor, por eso se me ocurre esta escusa. :blink:
Salu2
Mira lo que dice del error 17978:
Salida por la impresora del V.A.G 1551
17978 - Unidad de control de motor bloqueada
Posible causa de la avería
- Intento de manipulación
- Cortocircuito en el cable de comunicación
Posibles repercusiones
- El motor arranca y se vuelve a parar inmediatamente
Eliminación de la avería
- Adaptar la unidad de control para electrónica del motor al inmovilizador electrónico
- Verificar inmovilizador electrónico:
=> Grupo de reparación 96; inmovilizador electrónico: reparar
Ofrem: la verdad es que, como te decía, me sucedió + o menos igual: recien arrancado el coche, se me paró inmediatamente; así 2 veces.
No me atrevo a borrar la avería, ya que me quedan solo 9 meses de garantía, y no quiero correr el riesgo de que salga de nuevo pasado ese periodo: prefiero ir y que me lo vean, y si tienen que cambiar alguna pieza, que lo hagan: lo mismo les da a ellos por borrar la avería y decir que todo está bien :blink: .
Ya te diré
Muchas gracias de nuevo x tu información :blink:
Ya sabes Kyfran, cuando se te paró nada más arrancar fue por culpa del inmovilizador, que no llega a leer bien el código de la llave, pero no creo que tenga importancia.
En cuanto a la avería de verdad, pues supongo que podría ser un problema si hiciera demasado frío, pero no es el caso en esta época. Ya sabes, vete al concesionario y diles que te ha costado arrancar alguna mañana de frío. Lo mismo es una tontería y al cambiarte el filtro del gasoil han dejado el conector fuera de su sitio.
taluego, peri
...o, mejor, ve pensando en cambiar de coche...
:lol::lol: : descuida Pires, que cdo esté en tu misma situación - esto es, con los niños mayores y medio emancipados - pensaré en comprarme un deportivo de 2 puertas ;):D
Peri: gracias x tus consejos, y a los demás :D
