hola, me sale el siguiente fallo:
1 fault found
00153 left windshield wiper motor (V216)
004 No signal/conexion intermitent
El caso es que el limpia funciona bien, borro la averia pero vuelve a salir.
  FRANPOYO dijo:
1 fault found
00153 - Windshield Wiper Motor; Driver Side (V216): No Signal/Communication
Possible Symptoms
  • Front Wiper not functioning
Possible Causes
  • Engine Hood Contact Switch faulty
  • Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216) faulty
  • Windshield Wiper Motor Driver Side (V216) faulty
Possible Solutions
  • Check/Replace Engine Hood Contact Switch
    • See Measuring Value Blocks (MVB)
    [*]Check/Repair Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216)
    [*]Check/Replace Windshield Wiper Motor Driver Side (V216)
<A name=Special_Notes>
Special Notes
  • When found in VW Golf (1K): Central Electronics (in Combination with 02071), check for Aftermarket Xenon installation.
    • Aftermarket Xenon installations may destroy the Wiper Electronics, installations like this are usually illegal and use H7 Bulb mounts for the Xenon bulbs
Le has puesto kit xenon?
Si es así, hecha un vistazo a esto:
This is a common and known problem with 3rd party, inappropriate and
illegal xenon retrofits. VW/Audi has published a service bulletin
recently which tells the one and only solution is to replace the wiper
control module/motor.
Clearly, this has to be paid by the moron who installed that illegal
retrofit kit and is not a warranty expense. :fisch:
Sebastian
Shamil Fawzy wrote:
> Hi all
> I have a custmer proplem in Skoda Oktavia A5 model 2007, Petrol engine,
> 1600cc. The car was in good condition till the owner connect an external
> xenon light then the front windshield wiper motor (V216) deffected and the
> warning light plup in the enstrument cluster for deffective car lamps was
> on. I disconnected this external xenon light from the car and connect the
> original lights of the car and the warning light plup turned off but the
> front wipper motor still deffected.
> What the solution for these case.
> Thakns in advance
Si, efectivamente tuve puesto un kit de xenon y se me fue el motor del limpia pero, se suponen que en la Audi me lo cambiaron por otro nuevo y por supuesto el kit no lo volví a poner más.
Pero mi pregunta es :
Se queda registrado este fallo en alguna otra unidad que no sea la del motor del limpia?
Afecta al funcionamiento del limpia en un futuro? en mi caso ahora mismo fuciona perfectamente.
Por cierto la referencia de la unidad del limpia que tengo ahora es 8P1 955 119 B , mi coche es un A3 8p de3 2004 y me aseguraron en la Audi que habian montado una modificación de esta pieza porque ya habia dado problemas antes en otros vehiculos.
