kAiS Publicado 13 de Diciembre del 2007 Denunciar Publicado 13 de Diciembre del 2007 Hola acabo de pasarle el vag-com ami a4 1.9 2001 y me da los siguientes errores y nose si son graves o no. Lo que mas raro me parece esque no me deja entrar en algunos modulos porque me dice Excessive Comm Errors. Haber si alguien me echa una mano aquí posteo lo que me dice el vag-com. VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 038 906 019 FP Component: 1,9l R4 EDC 0000SG 1438 Coding: 00002 Shop #: xxxxxxxx xxxxxxxxxxxxxxx xxxxxxxxxxxxx 2 Faults Found: 18043 - Powertrain Data Bus: Missing Message from A/C Controller P1635 - 35-10 - - - Intermittent 17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04255 Shop #: WSC 06435 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 B Component: int. Lastmodul RDW 1512 Coding: 00001 Shop #: WSC 63351 No fault code found. Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 F Component: Lenksáulenmodul 0302 Coding: 00011 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 930 G Component: KOMBI+WEGFAHRS. RB4 D15 Coding: 00000 Shop #: xxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxx 1 Fault Found: 01320 - Control Module for Climatronic (J255) 49-00 - No Communications Address 37 ------------------------------------------------------- Controller: Note: Excessive Comm Errors Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AQ Component: Komfortgerát T85 0214 Coding: 06720 Shop #: xxxxxxxxxxxx 5 Faults Found: 01320 - Control Module for Climatronic (J255) 49-00 - No Communications 01561 - Left Rear Door 59-00 - Can't Unlock 01561 - Left Rear Door 61-00 - Won't De-Safe 01331 - Door Control Module: Driver Side (J386) 80-10 - Single-Wire Operation - Intermittent 01560 - Passenger Door 61-00 - Won't De-Safe Address 56 ------------------------------------------------------- Controller: Note: Excessive Comm Errors End ------------------------------------------------------- Responder
