Manual Instalación de Tempomat, Audi A3 (8P) - Regulador de Velocidad
kantusjack
  • Respuestas 677
claro con la bateria quitada, que quieres que te de una captura del modulo 3(el del ABS)
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P38A119490 Mileage: 21090km/13104miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 RE HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1955
Revision: --H07--- Serial number: AUX7Z0GDFN40T0
Coding: 0000071
Shop #: WSC 06325 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 06314 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 223964 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007974915
Coding: A1880F07801410004F0000000000000000085E175C010000000000000000
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR000U66+
Coding: 0070612
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002022
Shop #: WSC 12345 123 12345
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 224DG003126294
Coding: 0006123
Shop #: WSC 00252 572 61421
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B290B0E
Coding: E9801F061002020100
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H22003 Serial number: AUX7Z0GDFN40T0
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000016
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002586D298505488A0167
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659740272690
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000016
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H01 0270
Revision: 00H01000 Serial number: AUZ1Z3G6860001
Coding: 0110211
End ---------------------------------------------------------------------
Metete en Engine (01), Measuring Blocks y vete al canal 6 (creo que es en este).
Teóricamente verás 4 campos. Prueba a ver si cambian cuando llevas la maneta a todas las posiciones. Prueba a ver si cambian algunos datos cuando pisas el freno y el embrague. En especial el campo 2. Es importante que cuando hagas algo veas si cambian cosas. Generalmente suele fallar algún sensor de pedal pisado.
006,2,Pedal Monitoring,,See Label File
; xxxxxxx1 = Brake Light Switch operated
; xxxxxx1x = Brake Pedal Switch operated
; xxxxx1xx = Clutch Pedal Switch operated
; xxxx1xxx = CCS enabled
; xxx1xxxx = ACC enabled
; xx1xxxxx = Main Switch
; 00xxxxxx = ACC/CCS Mode not active
; 10xxxxxx = Status override
; 01xxxxxx = ACC/GRA active
; 11xxxxxx = ACC blocked
006,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
006,4,Switch Monitoring,,See Label File
; xxxxxxx? = Stuck ON
; xxxxxx?x = Pressed OFF
; xxxxx?xx = Decelerate (-)
; xxxx?xxx = Accelerate (+)
; xxx?xxxx = Set (SET)
; xx?xxxxx = Resume (RESET)
; ?xxxxxxx = Stuck ON (Hardware)
Si ves que cuando haces algo SIEMPRE cambia algo, desconectas 5 minutos la batería y vuelves a conectarla.
SDS.
Editado por kantusjack
SDS.
ok voy a verlo gracias y perdona ser tan piñazo.
Pudiera ser, de todas formas viene marcado sobre el conector.
Las dos posiciones de pines grandes son la 1 y 2, después cuentas de la 3 a la 9 (creo ) y de la 10 a la 16
Yo creo que el cable está tirado, vamos al 99,99% de probabilidad
SDS.
SDS.
los de arriba son del 3 a 9 y los de abajo del 10 l 16 no??
