Ya he arreglado lo del g85, ya le paso el autoscan y no me da ningun error, pero el tempomat sigue sin funcionar, ademas si le meto el codigo para anularlo si que me da error, osea que reconocerlo lo reconoce, pero porque no funcionara???
  • Respuestas 681
claro con la bateria quitada, que quieres que te de una captura del modulo 3(el del ABS)
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P38A119490 Mileage: 21090km/13104miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 RE HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1955
Revision: --H07--- Serial number: AUX7Z0GDFN40T0
Coding: 0000071
Shop #: WSC 06325 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 06314 000 00000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 223964 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007974915
Coding: A1880F07801410004F0000000000000000085E175C010000000000000000
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR000U66+
Coding: 0070612
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002022
Shop #: WSC 12345 123 12345
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 224DG003126294
Coding: 0006123
Shop #: WSC 00252 572 61421
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B290B0E
Coding: E9801F061002020100
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H22003 Serial number: AUX7Z0GDFN40T0
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000016
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002586D298505488A0167
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659740272690
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000016
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H01 0270
Revision: 00H01000 Serial number: AUZ1Z3G6860001
Coding: 0110211
End ---------------------------------------------------------------------
Metete en Engine (01), Measuring Blocks y vete al canal 6 (creo que es en este).
Teóricamente verás 4 campos. Prueba a ver si cambian cuando llevas la maneta a todas las posiciones. Prueba a ver si cambian algunos datos cuando pisas el freno y el embrague. En especial el campo 2. Es importante que cuando hagas algo veas si cambian cosas. Generalmente suele fallar algún sensor de pedal pisado.
006,2,Pedal Monitoring,,See Label File
; xxxxxxx1 = Brake Light Switch operated
; xxxxxx1x = Brake Pedal Switch operated
; xxxxx1xx = Clutch Pedal Switch operated
; xxxx1xxx = CCS enabled
; xxx1xxxx = ACC enabled
; xx1xxxxx = Main Switch
; 00xxxxxx = ACC/CCS Mode not active
; 10xxxxxx = Status override
; 01xxxxxx = ACC/GRA active
; 11xxxxxx = ACC blocked
006,3,Accel. Pedal Pos.,Sensor 1 (G79),Range: 0.0...100.0 %
006,4,Switch Monitoring,,See Label File
; xxxxxxx? = Stuck ON
; xxxxxx?x = Pressed OFF
; xxxxx?xx = Decelerate (-)
; xxxx?xxx = Accelerate (+)
; xxx?xxxx = Set (SET)
; xx?xxxxx = Resume (RESET)
; ?xxxxxxx = Stuck ON (Hardware)
Si ves que cuando haces algo SIEMPRE cambia algo, desconectas 5 minutos la batería y vuelves a conectarla.
SDS.
Editado por kantusjack
SDS.
ok voy a verlo gracias y perdona ser tan piñazo.
Pues o tienes algo mal conectado o la maneta que te han vendido esta fastidiada.
La verdad es que sin ver el coche no se me ocurre nada mas. Porque NO hay fusibles por el camino ni nada parecido.
SDS.
Pudiera ser, de todas formas viene marcado sobre el conector.
Las dos posiciones de pines grandes son la 1 y 2, después cuentas de la 3 a la 9 (creo ) y de la 10 a la 16
Yo creo que el cable está tirado, vamos al 99,99% de probabilidad
SDS.
SDS.
los de arriba son del 3 a 9 y los de abajo del 10 l 16 no??
