ANreZZ Publicado 11 de Enero del 2008 Denunciar Publicado 11 de Enero del 2008 Hola gente! pongo los errores que me da el vag-com, pueden ser debido igual a que no me deptecta el ipod (no llega ni corriente), es lo que me falta para que me funcione todo ya que en el fis me aparece toda la info, el rsn-e coge la información del coche, etc.. Friday,11,January,2008,14:43:40:55371 VAG-COM Version: Release 704.1 Data version: 20070422 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D VIN: WAUZZZ8P37A102025 Mileage: 25300km/15720miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 1010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 7D-Aux. Heat -- Status: OK 0000 Address 19: CAN Gateway Labels: 1K0-907-530.LBL Part No SW: 1K0 907 530 J HW: 1K0 907 951 Component: J533__Gateway H12 0160 Coding: 3D0F0B4A07000100 Shop #: WSC 06314 3 Faults Found: 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 75 Mileage: 24807 km Time Indication: 0 Date: 2008.01.02 Time: 19:34:02 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 75 Mileage: 25300 km Time Indication: 0 Date: 2008.01.11 Time: 14:24:19 01044 - Control Module Incorrectly Coded 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 4 Reset counter: 54 Mileage: 15172 km Time Indication: 0 Date: 2007.08.13 Time: 20:34:41 Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL Part No SW: 8E0 035 192 C HW: 8E0 035 192 C Component: RNS-E HIGH EU H53 0550 Coding: 0205113 Shop #: WSC 00000 10 Faults Found: 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 5 Reset counter: 75 Time Indication: 0 Date: 2008.01.02 Time: 19:41:58 Freeze Frame: Mileage: 25300 km Count: 1101 Clock: 14:39 00856 - Radio Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 51 Time Indication: 0 Date: 2008.01.02 Time: 19:40:35 Freeze Frame: Mileage: 655350 km Count: 301 Clock: 20:28 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 14 Reset counter: 75 Time Indication: 0 Date: 2008.01.02 Time: 19:32:09 Freeze Frame: Mileage: 25300 km Count: 1101 Clock: 14:39 00878 - Connection to Speaker Front Left 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 5 Fault Frequency: 2 Reset counter: 44 Time Indication: 0 Date: 2007.12.29 Time: 13:18:46 00878 - Connection to Speaker Front Left 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 49 Time Indication: 0 Date: 2008.01.02 Time: 19:40:25 00879 - Connection to Speaker Front Right 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 5 Fault Frequency: 2 Reset counter: 44 Time Indication: 0 Date: 2007.12.29 Time: 13:18:46 00879 - Connection to Speaker Front Right 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 49 Time Indication: 0 Date: 2008.01.02 Time: 19:40:25 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 32 Mileage: 25252 km Time Indication: 0 Date: 2008.01.10 Time: 18:27:05 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 206 Time Indication: 0 Date: 2007.12.13 Time: 11:14:44 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 72 Time Indication: 0 Date: 2007.12.13 Time: 11:15:00 Freeze Frame: Bin. Bits: 10111011 Bin. Bits: 10 A ver si me podeis ayudar. Gracias!! Responder
ANreZZ Publicado 13 de Enero del 2008 Autor Denunciar Publicado 13 de Enero del 2008 nadie me puede ayudar con estos errores?? Responder
jmirus Publicado 13 de Enero del 2008 Denunciar Publicado 13 de Enero del 2008 Yo ando parecido con los errores lo unico que he encontrado es un pdf con los errores que hay en otro post. Y lo que venga en la ppagina openobd pero es un poco antiguo. Un saludo. Responder
ANreZZ Publicado 14 de Enero del 2008 Autor Denunciar Publicado 14 de Enero del 2008 Yo ando parecido con los errores lo unico que he encontrado es un pdf con los errores que hay en otro post.Y lo que venga en la ppagina openobd pero es un poco antiguo. Un saludo. te agradecería si me pudieses pasas esos archivos... acomeron@hotmail.com Responder
