Hi Westforce,
Sorry no Spanish ...
Did you have ant problems with DIS showing bulb out ?
Please see my thread on front LED DRL's
http://www.tyresmoke.net/ubbthreads/showfl.../page/0#1232510
Thanks
Andy
These are the resistor that we have:
Resistor leds
the problem is that they warm too much, we are looked for a solution to the problem¡¡
A greeting¡¡¡
  • Respuestas 224
Hi Westforce,
Thanks
Andy
Resistor leds
A greeting¡¡¡
I have not had a problem with heat, they do get hot but it does not seem to bother anything ...
To get better LEDS see here
www.v-leds.com
They have a lot of SMT LEDs which are brighter and last a long time ... I use 27 SMT's as my DRL's
IMPRESIONANTE!!! :notworthy::thumbsup::unsure::p :P
Yo nunca podria hacer eso, no todos tenemos esa habilidad. No hay la posibilida de comprarlos hechos? Si no recuerdo mal para el A4 B5 habia unos.
Gracias, creo que no, pero no creo que tarden mucho en sacarlos a la venta.
Hello
Can you give an exactly instructions for rebuilding your lamps.
Where you have described every step.
At least in englisch.
Sorry, but the instructions for the assembly are those that you could have seen in this post in Spanish. Regards.
Hello
I am French and I don't speak very well Spanish.
Congratulation for your adaptation of fires to leds A6 on A4.
I want to make the same thing, but I don't know how to connect the led.
Can you help me please?
In fact there is only one wire to supply the night light and the stop. :thumbsup:
How to make? :thumbsup:
Thanks for your answer.
Hello
In fact there is only one wire to supply the night light and the stop. :ph34r:
How to make? :lol2:
Hello hondalex2000, Steps to continuing later:
1º- Pass a cable of the left wings to the large door connected in the light of brake---red - white Cable and brown cable.
2º- To connect to the cables red and black of the beacons of the large door.
3º- Of The cables of the antifog:
The black cable with the gray and white cable you it connect to the light antifog, another cable together with the black cable you connect it to a resistance of 50w and 20 ohms.
Regards.
  • 1 mes más tarde...
hola foreros,soi nuevo aki y apasionado de audi,molan un huevo esas opticas traseras y me gustaria poder hacer lo mismo en mi coche,el mismo modelo en berlina,espero respuestas y ayuda sobre este tema :flwrs::lol2: <_<
En berlina el faro es diferente, asi q ahi no sabemos decirtelo con seguridad.
ke kedaria mejor¿?faldones laterales rs4 o moldura inferior en la puerta s4 :p :cry1: :drooling:
Eso a gustos, las del RS4 estan menos vistas, pero no se si valdran las originales por el ancho de via del RS4¡¡
si le añadieses el intermitente en led seria ya la o****
Todo se andara........ :thumbsup:
