Ragtop Publicado 16 de Febrero del 2008 Autor Denunciar Compartir Publicado 16 de Febrero del 2008 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Ragtop Publicado 16 de Febrero del 2008 Autor Denunciar Compartir Publicado 16 de Febrero del 2008 F430 y F430 Spider NOVITEC SPORT Bi-compressor F1 430 02 including 2 supercharger with separated oil-circuit, modified induction tract complete heat-insulated, watercooled intercoolers with additional watercoolers, pumps, reinforced v-ripped belts, injectors, oil cooler as well as modified ECU‘s performance: 468 kW (636 hp) / 8.200 rpm max. boost-pressure: 0,35 bar max. torque: 638 Nm / 6.250 rpm Vmax: 348 km/h (in combination with NOVITEC gear-ratio) 0 – 100 km/h: 3,7 sec By the installation of the NOVITEC Bi-compressor system, it could necessary to change wear parts according to the mileage. NOVITEC power stage 2 F1 430 05 consisting of an air flow optimising Carbon Airbox including two sport air filters as well as a new adjusted engine electronic with modified group of curves and higher cutoff speed to 8.850 rpm (thereby higher end-speed). In addition a stainless steel exhaust system in combination with sport metal catalysts (100 Zeller) with reduced exhaust back pressure performance: 382 kW (520 hp) / 8.600 rpm max. torque: 490 Nm / 5.350 rpm Vmax: + 6 km/h For this performance step new ECU’s can be purchased. The original ones would remain with the owner and would not be reprogrammed. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Ragtop Publicado 16 de Febrero del 2008 Autor Denunciar Compartir Publicado 16 de Febrero del 2008 575 M power optimized for 575 Maranello F1 575 02 Power upgrade through modified engine electronic as well as stainless steel exhaust system without flap-regulation in combination with pipe for replacing central silencer mounting including dyno-test before and after conversion performance: 392 kw (533 hp) / 7.250 rpm max. torque: 596 Nm / 5.300 rpm Responder Enlace al comentario Compartir en otros sitios web More sharing options...
