jotake Publicado 19 de Febrero del 2008 Denunciar Publicado 19 de Febrero del 2008 Tuesday,19,February,2008,18:34:53 VAG-COM Version: Release 512.4-UD Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN Number: WAUZZZ8E02A051820 ------------------------------------------------------------------------------- Address 01: Engine Part No: 038 906 019 FP Component: 1,9l R4 EDC 0000SG 1467 Coding: 00002 Shop #: WSC 63351 WAUZZZ8E02A051820 AUZ6Z0A0162498 2 Faults Found: 17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 8E0 820 043 Component: A4 Klimaautomat 0711 Coding: 00000 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Part No: 8E0 907 279 Component: int. Lastmodul RDW 0510 Coding: 00001 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 16: Steering wheel Part No: 8E0 953 549 F Component: Lenksáulenmodul 0304 Coding: 00011 Shop #: WSC 63351 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Part No: 8E0 920 900 GX Component: KOMBI+WEGFAHRS. RB4 D29 Coding: 02027 Shop #: WSC 03587 WAUZZZ8E02A051820 AUZ6Z0A0162498 1 Fault Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Part No: 8E0 035 192 D Component: RNS-E HIGH EU H70 0660 Coding: 0301111 Shop #: WSC 06325 2 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit 02454 - Microphone Unit (in Front Roof Module) (R164) 011 - Open Circuit ------------------------------------------------------------------------------- Address 46: Central Conv. Part No: 8E0 959 433 AQ Component: Komfortgerát T85 0214 Coding: 06720 Shop #: WSC 63351 Part No: 8E1959801B Component: Tõrsteuer.FS BRM 4.11 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 4.11 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Part No: 8E0 035 192 D Component: RNS-E HIGH EU H70 0660 Coding: 0301111 Shop #: WSC 06325 2 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit 02454 - Microphone Unit (in Front Roof Module) (R164) 011 - Open Circuit End -------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- Además encontré otro en el modulo del cierre: 01366 open due to crash signal 35-00 los del cierre y la radio o el navagador en cuanto los borro vuelven a aparecer. Sabría alguien orientarme un poco? Muchas gracias. Responder
motoraco Publicado 19 de Febrero del 2008 Denunciar Publicado 19 de Febrero del 2008 en realidad solo tienes un par de errores ,los mas importantes son 17664 - Engine Coolant Temp Sensor (G62) esta roto el sensor o la conexion falla 17978 - Engine Start Blocked by Immobilizer ,Tienes un problema en el transponder de la llave o del bombin de arranque 00858 - Connection; Radio ZF Output to Antenna Amplifier ,suele pasar cuando sacamos el conector del navy 02454 - Microphone Unit (in Front Roof Module) (R164) ,falla el cableado del micro o esta desencajado o desconectado 01366 open due to crash signal ,esto sale cuando el coche esta cerrado y recibe un golpe en marcha ,accidentes ? habria que saber si el rns-e fue montado original o es colocado despues para conocer este error y otros 01300 - Control Module for Navigation with CD-Rom (J401) BNS ,habria que recodificar este modulo para desactivar el navegador antiguo por Fis saludos Responder
jotake Publicado 19 de Febrero del 2008 Autor Denunciar Publicado 19 de Febrero del 2008 JUANTKO dijo: en realidad solo tienes un par de errores ,los mas importantes son 17664 - Engine Coolant Temp Sensor (G62) esta roto el sensor o la conexion falla 17978 - Engine Start Blocked by Immobilizer ,Tienes un problema en el transponder de la llave o del bombin de arranque 00858 - Connection; Radio ZF Output to Antenna Amplifier ,suele pasar cuando sacamos el conector del navy 02454 - Microphone Unit (in Front Roof Module) (R164) ,falla el cableado del micro o esta desencajado o desconectado 01366 open due to crash signal ,esto sale cuando el coche esta cerrado y recibe un golpe en marcha ,accidentes ? habria que saber si el rns-e fue montado original o es colocado despues para conocer este error y otros 01300 - Control Module for Navigation with CD-Rom (J401) BNS ,habria que recodificar este modulo para desactivar el navegador antiguo por Fis saludos Hola buenas, el rns-e lo puse posterior. Como puedo recodificar el tema del navi? Lo del golpe no me ha quedado muy claro. Gracias Responder
jmirus Publicado 20 de Febrero del 2008 Denunciar Publicado 20 de Febrero del 2008 01300 - Control Module for Navigation with CD-Rom (J401) Este error tambien le tengo yo y no se como quitarlo. A mi me sale en el A3 en el canal 19 can gateway. Un saludo. Responder
jotake Publicado 20 de Febrero del 2008 Autor Denunciar Publicado 20 de Febrero del 2008 jmirus dijo: 01300 - Control Module for Navigation with CD-Rom (J401)Este error tambien le tengo yo y no se como quitarlo. A mi me sale en el A3 en el canal 19 can gateway. Un saludo. Buenas, yo ya no se como poder quitar los errores del navi, porque el del circuito abieryto de la antena, por más q la reviso siempre me da el dichoso error. A ver si nos echan un cable amigo. Responder
