¿Alguien me podría indicar el procedimiento, paso a paso, para reponer en el menú el estado de carga de la batería?
He leído que se debe seleccionar 07 DISPLAY/CONTROL UNIT, cambiar el valor del canal 2 a valor 32 o sumarle 32 (tengo duda sobre esto). El problema es que no he utilizado nunca el VAG y me da un poco de miedo desconfigurar algo. Si hay alguien que pueda guiarme (desde el menú principal seleccionar opción tal, pinchar tal recuadro, cambiar tal cifra, etc.)
Gracias de antemano.
Teóricamente, sumarle 32. Eso si, ya me diras que LOGIN usas para entrar en adaptation.
SDS.
De la Wikipedia
Coding
* 00?0x0x: Start Screen
o 0 = Audi A6 (4F)
o 1 = Audi S6 (4F)
* 00x?x0x: Chassis Type
o 0 = Limousine (Sedan)
o 1 = Avant (Wagon)
o 3 = Allroad
* 00x0?0x: Mute
o 0 = Mute-Wire inactive
o 1 = Mute-Wire active
o 2 = Soft-Mute active (for Special Purpose Vehicles with Radio)
o 3 = Soft-Mute and Line-In active (for Telephone Retrofitting)
* 00x0x??: Language
o 01 = German
o 02 = English (GB)
o 03 = English (US)
o 04 = Spanish
o 05 = Italian
o 06 = French
o 07 = Portuguese
o 08 = Japanese
o 09 = Chinese
o 10 = Dutch
o 11 = Greek
o 12 = Russian
o 13 = Polish
o 14 = Hungarian
o 15 = Croatian
o 16 = Turkish
o 17 = Slovene
o 18 = Slovak
Adaptation
Channel 001: Installation List I (MMI Functionality)
* +00001 = Adaptive Cruise Control installed (PR-8T4)
* +00002 = Ambient Lighting installed (PR-QQ1)
* +00004 = Acoustic Parking System Front installed (PR-7X2)
* +00008 = Acoustic Parking System Rear installed (PR-7X1/7X2)
* +00016 = Tire Pressure Monitoring System installed (PR-7K3/7K4/7K5)
* +00032 = Sunroof installed (PR-3FE/3FR)
* +00064 = Adaptive Air Suspension installed (PR-1BK)
* +00256 = Rain Sensor installed (PR-8N3)
* +01024 = Seat Adjustment Front installed (PR-3PN)
* +02048 = Seat Adjustment Rear installed (PR-5Z1)
* +04096 = Multi-Function Steering Wheel installed (PR-1XW)
* +08192 = Lane Change Assistant installed
* +16384 = Lane Holding Assistant installed
* +32768 = Back-Up Camera installed
Channel 002: Installation List II (MMI Functionality)
* +00001 = Left-Hand-Steering (LHD) [standard]
* +00002 = Vehicle Identification Number (VIN) available
* +00004 = Avant (PR-K8D)
* +00008 = Oil Level Display available
* +00016 = Digital Radio (DAB) Video Transmission
* +00032 = Battery Status Display active
Channel 006: MMI After-Run Time
Time between shut-off and automatic shut-down of the MMI.
* 00 = Telematics / No Telephone installed
* 16 = Mobile Phone Base Plate installed
Channel 011: Additional MMI Options
* +00001 = Owners Manual available
* +00032 = Climate Control Comfort available
* +00064 = Auxiliary Heating available
Channel 012: Telephone Type
* 0 = No Telephone
* 1 = Permanently installed
* 2 = Mobile Phone Base Plate installed
* 4 = Telematics installed
Channel 111: MMI System Restart
An MMI system restart may be necessary to activate recoded or adapted values. To initiate the restart save '1' as new value.
Ups,
De rebote, me va a servir.
Me acaban de dar una A6 avant y no lleva el display de ma bateria en el MMi, en mi anterior A6 sí que salía.
Por cierto sabeís cómo hacer que las ventanillas suban sin mantener apretada la llave cuando cierras?
He probado en el modulo 46, Kanal 61 y no encuntro la opción
Un Saludo :laugh:
SDS.
De la Wikipedia
Coding
o 0 = Audi A6 (4F)
o 1 = Audi S6 (4F)
o 1 = Avant (Wagon)
o 3 = Allroad
* 00x0?0x: Mute
* 00x0x??: Language
o 01 = German
o 02 = English (GB)
o 03 = English (US)
o 04 = Spanish
o 05 = Italian
o 06 = French
o 07 = Portuguese
o 08 = Japanese
o 09 = Chinese
o 10 = Dutch
o 11 = Greek
o 12 = Russian
o 13 = Polish
o 14 = Hungarian
o 15 = Croatian
o 16 = Turkish
o 17 = Slovene
o 18 = Slovak
Adaptation
* 0 = No Telephone
De perlas, gracias por la info, estaba buscando este tema. :laugh:
Por cierto sabeís como subir las ventanillas sinmantener apretado el mando cuando se cierra?
He intentado Modulo 46, Kanal 61, pero no hay forma.
SDS.
De la Wikipedia
Coding
o 0 = Audi A6 (4F)
o 1 = Audi S6 (4F)
o 1 = Avant (Wagon)
o 3 = Allroad
* 00x0?0x: Mute
* 00x0x??: Language
o 01 = German
o 02 = English (GB)
o 03 = English (US)
o 04 = Spanish
o 05 = Italian
o 06 = French
o 07 = Portuguese
o 08 = Japanese
o 09 = Chinese
o 10 = Dutch
o 11 = Greek
o 12 = Russian
o 13 = Polish
o 14 = Hungarian
o 15 = Croatian
o 16 = Turkish
o 17 = Slovene
o 18 = Slovak
Adaptation
* 0 = No Telephone
Hey, :laugh:
de rebote me sirve tu post, gracias.
En mi nuevo A6 avant no aparece la bateria, habeís probado el nivel de aceite?
POr ciero estoy intentendo hacer que las ventanillas suban solas sin mantener apretada la llave cuando cierras.
Modulo 46, Kanal 61, pero no hay forma, sabeís como?
Saludos. :conf:
Gracias Kantusjack por despejar la duda. No obstante, ¿me podríais especificar más al detalle los pasos a dar para realizar el cambio?. Soy novato con el VAG y no quisiera desconfigurar nada (pinchar SELECT, luego saldrá la pantalla TAL, eligir la opción CUAL en la siguiente pantalla, etc).
Gracias a todos por la colaboración. :p
