Makymon09 Publicado 13 de Marzo del 2008 Denunciar Publicado 13 de Marzo del 2008 Hola a todos, le acabo de hacer un scan a mi coche y me salen los siguientes errores, podria decirme alguien que es lo que le pasa por favor. Thursday,13,March,2008,23:25:59 VAG-COM Version: Release 607.3-UD Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 ------------------------------------------------------------------------------- Address 08: Auto HVAC Part No: 8E0 820 043 Component: A4 Klimaautomat 0912 Coding: 00000 Shop #: WSC 63351 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q Component: RNS-E HIGH EU H73 0600 Coding: 0301717 Shop #: WSC 06335 3 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 250 Reset counter: 142 Freeze Frame: Mileage: 655350 km Count: 1303 Clock: 18:37 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 Date: 2008.01.17 Time: 14:30:13 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 Date: 2008.01.17 Time: 14:30:18 Un saludo y gracias. Responder
style Publicado 13 de Marzo del 2008 Denunciar Publicado 13 de Marzo del 2008 01274 - Air Flow Flap Positioning Motor (V71): Faulty Possible Causes Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty Positioning Air Flow Flap Positioning Motor (V71) blocked Positioning Air Flow Flap Positioning Motor (V71) faulty Possible Solutions Check Air Flow Flap Positioning Motor (V71) See Measuring Value Blocks (MVB) Perform Output Test Perform Basic Setting Check/Repair Wiring and Connectors ese es el primer fallo Responder
Makymon09 Publicado 13 de Marzo del 2008 Autor Denunciar Publicado 13 de Marzo del 2008 01274 - Air Flow Flap Positioning Motor (V71): Faulty Possible Causes Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty Positioning Air Flow Flap Positioning Motor (V71) blocked Positioning Air Flow Flap Positioning Motor (V71) faulty Possible Solutions Check Air Flow Flap Positioning Motor (V71) See Measuring Value Blocks (MVB) Perform Output Test Perform Basic Setting Check/Repair Wiring and Connectors ese es el primer fallo Hola style, gracias por la informacion, pero sabrias decirme que funcion hace la tapa esta. Responder
Tolo Publicado 14 de Marzo del 2008 Denunciar Publicado 14 de Marzo del 2008 V71 es la trampilla del aire fresco (exterior). Saludos. Responder
Makymon09 Publicado 14 de Marzo del 2008 Autor Denunciar Publicado 14 de Marzo del 2008 Gracias Tolo, la verdad que tan solo llevo un año con el coche pero no noto nada raro con respecto a esta trampilla, posiblemente no este efectuando la labor que debe y a mi me parece que esta bien. Por lo que pone en los errores a ti en que te parece que me debo fijar para apreciar que no va como debe. un saludo Responder
