El esquema del sintonizador es este.
y aparecen las referencias de los "primeros" pins q son los ocupados por el Navi para controlar y recibir la señal del propio sintonizador analógico, pero ni idea de cuales son los pins de los AVs (entradas) auxiliares masa, sonido etc.
Si alguien dispone de esta información y quiere compartirla le estaré eternamente agradecido.
he encontrado esta info en un foro "foraneo".. aun no está contrastada ni nada pero por algo se empieza.
Version 1)
Contacts which are not listed are not used.
1 – Ground
2 - CAN Bus Low (BOSCH) (from RNS-E Infotainment)
3 - CAN Bus High (BOSCH) (from RNS-E Infotainment)
4 - Audio screen (front) (not used)
5 - Audio output (right front)
6 - Audio earth (not used)
7 - Audio output (left front)
8 - Audio earth
9 - Screen earth (front)
10 - Video screen (front)
11 - Video output sync. (front)
12 - Video earth
13 - Video output (blue, front)
14 - Video earth
15 - Video output (green, front)
16 - Video earth
17 - Video output (red, front)
19 - Terminal 31
20 - Terminal 30
21 - L-diagnosis
22 - Audio output (–), rear right (not used)
23 - Audio output (+), rear right (not used)
24 - Audio screen (rear) (not used)
25 - Audio output (–), rear left (not used)
26 - Audio output (+), rear left (not used)
27 - Screen earth (rear) (not used)
28 - Com. Sync. (–), rear (not used)
29 - Com. Sync. (+), rear (not used)
30 - Signal (–) blue, rear (not used)
31 - Signal (+) blue, rear (not used)
32 - Signal (–) green, rear (not used)
33 - Signal (+) green, rear (not used)
34 - Signal (–) red, rear (not used)
35 - Signal (+) red, rear (not used)
36 - Video screen (rear) (not used)
40 - Audio input (–), rear left (not used)
41 - Audio input (–), rear right (not used)
42 - AV earth input (rear) (not used)
43 - S-VHS input (Y) rear (not used)
44 - S-VHS input © rear (not used)
45 - CVBS input rear (not used)
46 - Complete screen AV input rear
47 - Audio input (–), front left (not used)
48 - Audio input (–), front right (not used)
49 - AV earth input (front) (not used)
50 - S-VHS input (Y) front (not used)
51 - S-VHS input © front (not used)
52 - CVBS input front (not used)
53 - Complete screen AV input front
Version 2)
1 - CAN bus ground
2 - CAN bus Low
3 - CAN bus High
4 - Audio ground front
5 - Audio right front, positive
6 - Audio right front, negative
7 - Audio left front, positive
8 - Audio left front, negative
9 - A/V complete display front
10 - Video monitor front
11 - Not assigned
12 - Not assigned
13 - Not assigned
14 - Not assigned
15 - Video -C- front, positive
16 - Video -C- front, negative
17 - Video -Y- front, positive
18 - Video -Y- front, negative
19 - Vehicle Ground (GND)
20 - Terminal 30 (continuous B+)
21 - Not assigned
22 - Audio right rear, negative
23 - Audio right rear, positive
24 - Audio ground rear
25 - Audio left rear, negative
26 - Audio left rear, positive
27 - A/V complete display rear
28 - Not assigned
29 - Not assigned
30 - Not assigned
31 - Not assigned
32 - Video -C- rear, positive
33 - Video -C- rear, negative
34 - Video -Y- rear, positive
35 - Video -Y- rear, negative
36 - Video ground
37 - internally assigned
38 - internally assigned
39 - internally assigned
40 - Audio left rear, external connection option
41 - Audio right rear, external connection option
42 - Audio/Video ground rear, external connection option
43 - Super Video System rear, external connection option
44 - Super Video System rear, external connection option
45 - CVBS rear, external connection option
46 - Complete audio/video shielding rear, external connection option
47 - Audio left front, external connection option
48 - Audio right front, external connection option
49 - Audio/Video ground front, external connection option
50 - Super Video System front, external connection option
51 - Super Video System front, external connection option
52 - CVBS front, external connection option
53 - Complete audio/video shielding front, external connection option
54 - Not assigned
Bueno te doy la información que dispongo, es mas sencillo comprar el adaptador, que lo acoplas y dispones de todos los cables en rca. lo tienes en este enlace: http://www.stagemotion.com/index.php?page=...t&Itemid=27
Te adjunto archivo word con las explicaciones para hacerlo con permiso de AudiMB.
Un saludo y espero haberte ayudado.
auxiliar.doc
