Hola! Al pasar el Vag-com en un golf gti (si, ya se que es VW) de un amigo que se compro de segunda mano le salen estos fallos. Los he borrado y despues de varios km no le ha vuelto a salir ninguno. ¿De que podrian ser originados? Ojo al tema de velocidades.....
Chassis Type: 1K - VW G/J Mk5
Scan: 01 02 03 08 09 0F 15 16 17 18 19 1C 22 25 36 37 3D 42 44 46
47 52 55 56 57 62 65 69 72 76 77 7D
VIN Number: xxxxxxxxxxxxxxxxxx
Address 01: Engine
Part No SW: 1K0 907 115 HW: 1K0 907 115
Component: 2.0l R4/4V TFSI 00 0070
Coding: 0403000318070060
Shop #: WSC 00028
4 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 5
Mileage: 47340 km
Time Indication: 0
Date: 2000.00.00
Time: 20:21:34
Freeze Frame:
RPM: 6046 /min
Load: 98.8 %
Speed: 205.0 km/h
Temperature: 89.0°C
Temperature: 39.0°C
Absolute Pres.: 920.0 mbar
Voltage: 14.097 V
012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 4
Mileage: 48054 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:07
Freeze Frame:
RPM: 2062 /min
Load: 17.6 %
Speed: 84.0 km/h
Temperature: 93.0°C
Temperature: 24.0°C
Voltage: 14.351 V
008200 - Intake Manifold Flap; Bank 1: Electrical Malfunction
P2008 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 4
Mileage: 48054 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:07
Freeze Frame:
RPM: 4802 /min
Load: 98.0 %
Speed: 163.0 km/h
Temperature: 89.0°C
Temperature: 26.0°C
Voltage: 13.843 V
000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
P0219 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 49613 km
Time Indication: 0
Date: 2000.00.00
Time: 20:02:56
Freeze Frame:
RPM: 7222 /min
Load: 100.0 %
Speed: 194.0 km/h
Temperature: 90.0°C
Temperature: 41.0°C
Voltage: 13.970 V
Readiness: 0000 0000
Mira, si has borrado los fallos y no vuelven a salir entonces es que está todo OK.
Pero, es preocupante este que aportas, porque lo que viene a decir es que has sobrepasado el límite de vueltas y la garantái del coche queda anulada!!!!! Los datos están claros:
Mileage: 49613 km
Freeze Frame:
RPM: 7222 /min
Load: 100.0 %
Speed: 194.0 km/h
Temperature: 90.0°C
Temperature: 41.0°C
Voltage: 13.970 V
Vamos, que iba en 5º a tope, ¿no? :notworthy: (presión del acelerador al 100%, 194 km/h, y a 7.222 rpm)
SALUDOS
Mileage: 49613 km
Freeze Frame:
RPM: 7222 /min
Load: 100.0 %
Speed: 194.0 km/h
Temperature: 90.0°C
Temperature: 41.0°C
Voltage: 13.970 V
Vamos, que iba en 5º a tope, ¿no? :plta: (presión del acelerador al 100%, 194 km/h, y a 7.222 rpm)
SALUDOS
Bueno! Por la garantia no hay problema puesto que ya se le acabo. Jeje! La verdad es que ese fallo es al que menos importacia le habia dado. Supongo que seria una fallo humano de ir en 5ª "a chapa" y al cambiar para s..ta meter 4ª sin querer. Aunque no es normal le puede pasar a cualquiera.... Gracias por la aportacion. Saludos...
