fergar Publicado 25 de Junio del 2008 Denunciar Publicado 25 de Junio del 2008 Hola: Alguien me puede decir si he hecho bien el auto scan con vag-com 311.2N al coche que me quiero comprar? Audi A6 2.5Tdi Tiptronic del 2000. VAG-COM Version: Release 311.2-N Chassis Type: 4B - Audi A6 C5 Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56 Address 01 ------------------------------------------------------- Controller: 4B0 907 401 AC Component: 2.5l/4VTEDC G000AG D62 Coding: 01001 Shop #: WSC 03388 No fault code found. Address 02 ------------------------------------------------------- Controller: 4B0 927 156 BL Component: AG5 01V 2.5lTDI RdW 9419 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 111 AH Component: ABS/ASR 5.3 FRONT D10 Coding: 00011 Shop #: WSC 03646 No fault code found. Address 08 ------------------------------------------------------- Controller: 4B0 820 043 P Component: A6-Klimavoll Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 4B0 919 880 G Component: C5-KOMBIINSTR. VDO D10 Coding: 05160 Shop #: WSC 00000 IMMO-IDENTNR: AUZ7Z0W0842164 No fault code found. Address 35 ------------------------------------------------------- Controller: 4B0 962 258 E Component: Zentralverrieg.,DWA D32 Coding: 04683 Shop #: WSC 02325 6 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch: Passenger Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01574 - Alarm triggered by Door Contact Switch: Right Rear 35-00 - - 01573 - Alarm triggered by Door Contact Switch: Left Rear 35-00 - - Address 45 ------------------------------------------------------- Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 02325 No fault code found. Address 55 ------------------------------------------------------- Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00005 Shop #: WSC 02325 No fault code found. End ------------------------------------------------------- Q veis? Yo creo q no ha encontrado nada, osea, q no se ha comunicado con el coche. Saludos. Responder
Tolo Publicado 25 de Junio del 2008 Denunciar Publicado 25 de Junio del 2008 En el único módulo que no ha podido entrar es en el del Klima, fallo bastante común. Podrías probar con otra versión o bajando la velocidad, etc. Algún truco hay... Lo demás bien, borra los fallos de la alarma y prueba otra vez. Saludos. Responder
fergar Publicado 25 de Junio del 2008 Autor Denunciar Publicado 25 de Junio del 2008 Gracias Tolo!!! Me persigues, te persigo....jejeje, soy el del balon, jaja. Le ves algo raro ademas de los sensores de las puertas? Gracias. Responder
