Portugues Publicado 12 de Agosto del 2008 Denunciar Publicado 12 de Agosto del 2008 Buenas.He estado trasteando por la red para un cambio de fuente,y me he encontrado con esta informacion: Para cambiar de sintonias americanas a españolas,tener en cuenta esto:"How do I change the radio settings so that it can receive European/Australian FM frequencies? If you are in Europe or Australia, the FM radio will be set to receive only odd frequencies (97.1, 97.3). To change it to receive even frequencies, do the following: Between the chassis of the player and the circuit board is a piece of card to stop the connections from shorting out. Remove the chassis and the card and the switch should be visible underneath, there may be a hole punched in the card and the chassis but they do not line up so the switch may not be not visible. Once this switch is changed to "Europe" settings, you will be able to change the radio frequency "steps" as noted in the instructions manual." Que viene a decir,que quitando un carton que esta bajo la tapa,se cambia un switch de posicion, y se modifica la recepcion de frecuencias de radio y se reciben las fecuencias europeas... Alguien sabe si es cierto?,ya que las dos fuentes que me planteo poner son o la DEX-P90rs,o la deh-p88rsII... Un saludo.Portugues. Responder
queroseno Publicado 13 de Agosto del 2008 Denunciar Publicado 13 de Agosto del 2008 Buenas.He estado trasteando por la red para un cambio de fuente,y me he encontrado con esta informacion: Para cambiar de sintonias americanas a españolas,tener en cuenta esto:"How do I change the radio settings so that it can receive European/Australian FM frequencies? If you are in Europe or Australia, the FM radio will be set to receive only odd frequencies (97.1, 97.3). To change it to receive even frequencies, do the following: Between the chassis of the player and the circuit board is a piece of card to stop the connections from shorting out. Remove the chassis and the card and the switch should be visible underneath, there may be a hole punched in the card and the chassis but they do not line up so the switch may not be not visible. Once this switch is changed to "Europe" settings, you will be able to change the radio frequency "steps" as noted in the instructions manual." Que viene a decir,que quitando un carton que esta bajo la tapa,se cambia un switch de posicion, y se modifica la recepcion de frecuencias de radio y se reciben las fecuencias europeas... Alguien sabe si es cierto?,ya que las dos fuentes que me planteo poner son o la DEX-P90rs,o la deh-p88rsII... Un saludo.Portugues. Hola, yo he visto algún modelo de radios que lleva ese switch para cambiar la posición y modificar la recepción de frecuencias, usease que es cierto S2 Responder
Portugues Publicado 13 de Agosto del 2008 Autor Denunciar Publicado 13 de Agosto del 2008 Gracias por responder.Pues entonces casi que me tiro de cabeza,ya que la diferencia en los modelos que cito llega a 200€...y no pago mas por lo mismo... Un saludo.Portugues. Responder
Puffy Publicado 29 de Agosto del 2008 Denunciar Publicado 29 de Agosto del 2008 Pero esto es así para TODAS las radios o solo para ciertos modelos? Responder
