Hola a todos, me he comprado un cable obd2 para mi a4 b5 y ayer le estuve haciendo unos escaneos de errores al mio y al passat de mi padre. Los resultados fueron los siguientes, haber si alguien me dice por donde van los tiros:
AUDI A4 TDI 110 ( B5 )
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 35 -------------------------------------------------------
Controller: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00000
Shop #: WSC 65535
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
VOLSWAGEN PASSAT HIGHLINE
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Controller: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0008
Coding: 17000
Shop #: WSC 00028
3 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
35-00 - -
Address 17 -------------------------------------------------------
Controller: 3B0 920 827 A
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 05115
Shop #: WSC 00000
WVWZZZ3BZ3P198037 VWZ7Z0B5991173
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 04403
Shop #: WSC 00028
2 Faults Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
00853 - Loudspeaker(s): Rear
Gracias y un saludo
Editado por a4 NRG
Bueno, despues de borrar todos los errores en mi a4 parece ser q no han vuelto a salir, solamente este:
Haber si alguien me indica q puede ser, un saludo.
si lo pones en google y le das a buscar muchos errores te dice que son, este en concreto me parece que pertenece al modulo del aire acondicionado, en cuanto a la averia que tiene ni idea, hay dice que demasiados errores
