majimo Publicado 18 de Septiembre del 2008 Denunciar Publicado 18 de Septiembre del 2008 HOLA AMIGOS!! Hacya loe tiempo pregunte si alguno de vosotros sabiais algo del motor ecologico de aud, en el a3 montan y bicheando por internet encontre esto. ¿sabeis algo más vosotros, sobre precios y cuando se pondra en el mercado? gracias . Esta en ingle, pero viene e decir que este motor con los mismos caballos gastará sobre 4,8 l /100 y menos CO2 As soon as we confirmed that we we’re actually looking at the 2008 Audi A4 and not its predecessor (…), we noticed that one of the vehicles on Audi’s Frankfurt Show stand was badged as the “A4 e Concept”. Apparently “e” stands for both efficient and eco-friendly as the concept is equipped with a brand-new 2.0 TDI turbo-diesel engine, consuming a mere 4,9 litres of fuel for every 100 Km (48,8 mpg). At the same time the “A4 2.0TDi e” features CO2 emissions of just 129 g/km -that's less than the E.U.'s 2012 limit. -Continued after the jump Other highlights on the “A4 e Concept” include the newly developed 6speed manual gearbox with reduced internal friction, the start/stop system and the recuperation system that converts kinetic energy into electrical energy as the vehicle decelerates. Despite its eco-friendly and frugal nature, the “A4 e Concept” manages to sprint from 0 to 100 km/h (62 mph) in 9.3 sec while it achieves a top speed of 215 km/h – 134 mph. Expect Audi to introduce a production version of the A4 e in mid 2008. Press Release Just 129 grams of CO2 – the 2.0 TDI e Concept With the new 2.0 TDI e Concept, Audi is showing just how effective its new Modular Efficiency program is. The sporty middle class saloon undercuts the consumption limit of five litres per 100 km. The A4 2.0 TDI e Concept needs just 4.9 litres for 100 km on the EU cycle. This means CO2 emissions of just 129 g/km – less than the limit that the European Union aims to introduce for vehicle fleets from 2012. With an output of 105 kW / 143 bhp and a peak torque of 320 Nm, the A4 2.0 TDI e Concept is a powerful saloon – for Audi, a dynamic character always goes hand in hand with low consumption. In this vehicle, Audi has realised a whole package of innovative engineering solutions. Some of these are already in series production on the new Audi A4. Others, such as the start/stop system or the energy recuperation system, will be introduced in the near future. TDI marries efficiency with dynamism The 2.0 TDI in the new Audi A4 presents itself in an essentially enhanced form. A common rail injection system supersedes the unit injection pumps used to date, its piezo injectors supplying fuel with a pressure of up to 1,800 bar, allowing extremely fine atomisation in the combustion chambers. This improves fuel combustion and smooth running. The refined engine develops a powerful 105 kW / 143 bhp of output. Even in the speed range between 1,750 and 2,500 rpm it puts a bullish 320 Nm of torque onto the crankshaft – this mighty pulling power at low revs is a one of the great strengths of the TDI principle. Modified piston geometry improves the thermodynamics in the combustion chambers. Other measures to reduce internal friction and for temperature management further increase fuel efficiency. On the A4 e Concept, the 2.0 TDI engine is supplemented by the ultra low emission system. That means that this engine not only works highly efficiently, but it is also exceptionally clear and absolutely future-proof: Even today, it undercuts the strictest European emissions levels, which are not expected to come into force until 2014. The ultra low emission system, which makes the TDI the world's cleanest diesel, will go into series production in 2008 as an option on the new Audi A4 3.0 TDI. Low-friction gearbox The TDI's power is transmitted onto a newly developed six-speed manual gearbox that is characterised by greatly reduced internal friction. It has been specially tailored for the high-torque of the TDI engine – its transmission ratios are slightly longer in third to sixth gears. Like all Audi gearboxes, its gear changes are playfully light and extremely precise. The gear change indicator in the driver information system encourages an economical driving style. It indicates which gear is selected and if another gear is judged to be better while driving steadily, it will show this as a recommendation. An especially fast and smooth start Another important contribution is made by the start/stop system. It avoids the engine running inefficiently when the vehicle is stationary. This is important because much of our day-to-day driving is made up of trips that are shorter than ten kilometres, and these are interrupted by numerous stops at traffic lights. As soon as the A4 2.0 TDI e Concept comes to a standstill, the gear lever is moved to neutral and the driver takes his foot off the clutch, the TDI is automatically switched off. The engine is restarted when the driver depresses the clutch. The TDI runs up while he is engaging the gear. It has reached idling speed by the time he releases the pedal. A specially developed starter motor turns the engine in little more than two tenths of a second – 60 percent faster than a conventional part, and yet especially comfortable acoustically. Microhybrid gathers energy when coasting and braking The recuperation system on board the A4 2.0 TDI e Concept converts kinetic energy into useful electrical energy as the vehicle decelerates. An innovative gel battery is used as the power source for the vehicle electrical system. This is extremely robust even at high loads and when it is heavily discharged, allowing it to achieve a particularly long service life. When the A4 2.0 TDI e Concept is coasting or braking, the secondary voltage from the D/C converter is run up. The alternator is now able to convert the kinetic energy into electrical energy that is tempor######ly stored in the gel battery. When the saloon subsequently accelerates again, the battery feeds the energy back, relieving the load on the alternator. The power steering has also been thoroughly modified – its effectiveness has been improved by around 50 percent because it is now fed hydraulic energy by a demand-controlled vane-cell pump. In contrast to conventional power steering pumps, which constantly recirculate large volumes, it only pumps as much oil as actually needed at that very moment. On the automatic air conditioning system, Audi uses an innovative, thermostatically controlled refrigerant circuit with an internal heat exchanger. Along with intensive precision work on other components, has greatly improved the efficiency of the system – the new automatic air conditioning system requires 20 percent less fuel that its predecessor model did. Sporty performance yet highly efficient The A4 2.0 TDI e Concept glides smoothly and effortlessly through the wind. Its body is fundamentally extremely aerodynamic. Its boot lid has been given a slight additional separation edge. Specially designed alloy wheels improve the airflow across the wheels and wheel arches, while a sporty tuning has lowered the body by 20 millimetres. This modification reduces the frontal area, improving air resistance. For Audi, efficiency means exactly the same as dynamics. For example, the tyres are configured for light running, but still have a sporty performance – they have the wide, visually attractive 225/50 R17 format. Yet the most impressive evidence of the potential of the A4 2.0 TDI e Concept is found in its performance figures. The middle class saloon sprints from 0 to 100 km/h in just 9.3 seconds. Its top speed is 215 km/h. A spurt from 80 to 120 km/h in 5th gear needs just 8.7 seconds. Responder
davigar Publicado 19 de Septiembre del 2008 Denunciar Publicado 19 de Septiembre del 2008 Yo de este tipo de motores y tecnologías no hago mucho caso. En la mayoría de los casos son modelos que sin apenas cambios se anuncian como ecológicos, puesto que ahora está de moda lo ecológico. Y como está de moda, las marcas han encontrado un filón para aumentar las ventas. A mí esto no me parecen soluciones. ¿De qué sirve gastar medio litro menos? ¿Qué solucionamos con ésto? Me mantengo mucho más abierto a otro tipo de motores con combustibles mucho menos dañinos para el medio ambiente. Por ejemplo hablando del etanol. El etanol se puede extraer de resíduos forestales, de resíduos de fábricas donde se fabrica azúcar, etc, etc.... El problema es el coste. Nada puede igualar el coste de producción del petróleo. El petróleo podemos decir que es una fuente de energía casi gratis, porque su coste de fabricación es bajísimo comparado con cualquier otro combustible elaborado. Si tuviesemos la posibilidad de fabricar etanol a partir de plantas a un precio similar o algo más bajo que la gasolina, este sería sin duda el mejor combustible a utilizar. No envía gases contaminantes a la atmósfera, salvo el CO2 que todos respiramos y expiramos y que en gran medida sería absorbido por las plantas de las que se extrae dicho alcohol. Además no tendríamos que adaptar los coches, ni tampoco deberíamos a adaptarnos a otro tipo de conducción. Se puede utilizar en motores con turbo obteniendo unas prestaciones excelentes y con un consumo de sólo un 20% más. Por lo que he visto en otras marcas, este tipo de mecánicas se basan en bajar el consumo utilizando neumáticos con menos agarre y menos anchura, bajando incluso la suspensión para que la resistencia al viento sea menor, o parando el motor en los semáforos. Esto a mí me parece un engaño en toda regla. Un saludo Responder
